Question about Saeco Talea Touch Plus Espresso Machine
Motor rotates in wrong direction and resets in wrong position
Tried to reset by switching off and on.
  • 43 Answers
Disconnect it from power, press the power button for 10 seconds to discharge it. Now reconnect to power and switch back on.
Posted on Nov 21, 2014
I was told by a previous repair man that there is a fuse in the beater bar that needed to be replaced.
Up to my experience in my Panasonic vacuum cleaner, if the beater bar is not working this could be because the 'Carpet/Floor' selector switch is in the 'OFF' or 'FLOOR' position. In both of these positions the beater bar will not rotate. Move the selector switch to the 'CARPET' position. When in this position the beater bar will rotate once the foot pedal is pressed.
If the selector switch is in the 'CARPET' position and the beater bar is still not rotating it could be that there is something entangled in the beater bar, or the belt is worn or broken.
To check this first unplug the vacuum cleaner
Inspect the beater bar and belts to ensure that there is nothing entangled in the beater bar and that the belts are intact and are not excessively worn. If the belts are excessively worn they may slip resulting in the beater bar not rotating.
The vacuum cleaners often have an overload protection system inside the nozzle, which stops the nozzle motor when the beater bar jams to prevent belt breakage. After clearing any lint build up or jamming you may need to reset the overload protection, by pressing the reset button on the top of the floor nozzle.
May 04, 2015 | Vacuums
There is micro switches on the gear wheel, the motor will move forward and hit a micro switch to stop to brew and then back to hit a switch to stop at park, it is not finding one of the positions so keeps turning, ohm to test switches or replace both
Nov 21, 2014 | Saeco Talea Giro Espresso Maker -...
Electrolux Z61a brush not rotating
There should be a rubber belt somewhere along that roller, probably in the middle, behind the bottom cover plate, Remove the plate. That belt may have just slipped off the motor shaft, but it may be broken.
The belt could possibly be installed in either of two ways. The motor shaft is not parallel to the beater bar (brushes), so the belt must twist to wrap around both the motor shaft and the beater bar. If it's twisted one direction, the beater bar will rotate the correct direction (as if drying to pull the vacuum forward). Twisted the wrong way, it'll rotate the opposite direction. Try it one way, then bump the power switch to verify that the brush is rotating the correct direction before putting the bottom cover plate back on.
Aug 10, 2014 | Electrolux Vacuums
Reset button inoperative
Sounds like 1 of 4 possibilities
1.The button next to your on switch is jammed.
2. The Motor has burnt out within the head unit
3. The PCB Unit is faulty wihin the head unit
4. The thin wires running down the inside of the machine to the head unit hve br
May 23, 2014 | Dyson Dc-18 "slim" Upright Model...
Service code interrupt
Error type T11 [Pressure-control motor lock]
T11-***
!!System Error!!
Press Reset Key
If Recovery has Failed, Call Service
Reset method Jam reset or switch on power again
Error point Error conditions
600
Timeout error for reducing pressure (OFF -> ON) during print-pressure home
positioning.
601
Timeout error for increasing pressure (ON -> OFF) during print-pressure home
positioning.
602 The print-pressure limit sensor does not change during print-pressure operation.
620 Print-pressure operation was called with the print-pressure motor locked.
621
Incorrect print-pressure operation timing (print-pressure operation command was
received when the print-pressure should not change).
622 Sensor A is ON and sensor B is OFF during movement from area A to area D.
623 Either sensor A or sensor B is ON during movement from area D to area A.
624 The current area data is undefined.
625 The target area data is undefined.
626 Timeout during relative print-pressure movement.
Error type T12 [Master-disposal-section motor lock]
T12-***
!!System Error!!
Press Reset Key
305
The master compression sensor does not go ON within 6.5 s after the master
compression motor operates in the return direction.
306
Master compression sensor does not go OFF within 2 s after the master
compression motor operates in the compress direction.
307
compression motor operates in the compress direction, and the mastercompression-
motor limit sensor cannot count up until the compression-limit
position.
309
The master-compression-motor limit sensor does not change within 200 ms
during compression operation.
hope to be of help
Sep 27, 2013 | Riso RP 3700
Kenmore model # 86470810 buzzes when I press start but won't run
The motors centrifugal switch may be stuck. Try having someone start it while pressing in the door switch while you rotate the drum with your hand by grabbing one of the drum vanes. I don't know which direction your drum rotates. Try both. This may start the drum turning on its own and resetting the switch
Sep 21, 2011 | Kenmore Dryers
My dryer makes a buzzing noise when i try to turn it on, but it won't turn on at all. What could the issue be?
The motors centrifugal switch may be stuck. Try having someone start it while pressing in the door switch while you rotate the drum with your hand by grabbing one of the drum vanes. I don't know which direction your drum rotates. Try both. This may start the drum turning on its own and resetting the switch.
Sep 20, 2011 | Kenmore 62722 Electric Dryer
Cobart Automatic Meat Slicer is not working on Automatic mode
To operate the slicer in Automatic mode . . . Rotate the Speed Selector Knob to the desired speed; make sure the Carriage is in HOME position (all the way forward); make sure the Lever is on the Manual position (pointing down); turn the slicer on; start the carriage drive unit by rotating the Lever to the Automatic position (up and to the right). Either of the two speed selections can be used to begin Automatic mode. The speed can be adjusted at any time by rotating the Speed Selector Knob. To stop the drive unit, rotate the Lever down and to the left - to the Manual position. ------------ If you slicer is set on proper automatic mode and still not running on automatic mode then the problem relates to internal motor or the selector knob. But try reset before this. Push the reset button underneath the slicer near the right-front foot if the carriage motor overloads. The reset helps in some problems.But if its not helping then internal connections of selector knob has to be checked.Of the same with motor,the connections of motor to the selector for automatic mode has to be checked.---------------- This will help.Thanks.Helpmech.'
Dec 15, 2010 | Microwave Ovens
Insinkerator stopped working. Cutting plate rotates freely. tHE RESET BUTTON IS STUCK IN THE "ON" POSITION.
If the reset button is stuck in the on position and can not be reset, the motor has an internal overload and will need to be replaced. Turn the power off to the motor via switch or circuit breaker, let it cool for awhile, the hit the reset button again to see if it resets. If it does, turn off the power at the breaker and leave it off. At this time, you need to dislodge a jam on the rotary vane that shreds the waste, there is something most likely stuck on the vane, causing the motor to overheat. There should be an allen wrench socket area in the middle of the underside of the motor housing, use an allen wrench and turn the motor manually back and forth, to release the jam. Again, be sure the power is OFF!!!
Dec 04, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Fan won't reverse to counter clockwise
I had a hampton bay fan that absolutely did not have a revers switch on the fan anywhere! MOST fans bought today will reverse. I was not about to give up. I scoured the net for an answer and could not find anything to help. I did however find a comment somewhere that said it could be done internally. After about six months I decided to search again (now). Nothing... so I started playing with the remote and the wall switch and Shazaam! I figured it out on my hampton bay fan. Turn the fan on high... Turn the wall switch off.... wait until the fan is pretty slow in rotation... hold the HI button on the remote.... Turn the switch back on. IT Worked for me! Hope this helps someone. SparqMark
Aug 10, 2009 | Hampton Bay 24750 Huntington III Ceiling...
Saeco Talea Touch Plus Espresso Machine Logo
51 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
