Question about Garden
Snowblowerwontrunwhenchokeisinrun newgas new oil
    Champion:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 256 Answers
Service your carb
Posted on Nov 23, 2014
Oil filter gasket
Your oil filter comes with a rubberized o-ring. When you take off the old oil filter, make sure you get the old oring with it. If you don't you'll have problems with the new one. Apply a light coat of clean oil to the new filters o-ting before installing. This helps the filter bond to the motor. turn the old filter counter clockwise to remove it. When installing new filter, fill filter with oil prior to installation. Turn clockwise to tighten. Tighten till snug, then give it an extra quarter turn for tightness. Again, make sure you remove the old o-ring from the motor if it does not come out with the old oil filter. No need to take new oring off new oil filter. Just fill, lubricate seal and install.
Jan 17, 2013 | 2000 Lincoln Town Car
Oil Pan Rusted and needs replaced
ok not to hard to replace you need to go to auto store and buy a new one. it may or may not come with new gaskett they can tell you what size you need if it dosent come with a new one. also you will need to drain the oil before removing the old pan so make sure to buy new oil for that.. your basicly doing an oil change so you may as well get new oil filter too. then after you have everything... new pan, oil, oil filter, gaskett.. just get under take out oil plugg drain oil in catch can. remove the oil pan bolts you may have too tap the oil pan in different directions to get it to drop off. clean away old gaskett if you need to, and replace new gaskett and oil pan, lay new gaskett ontop of new oil pan and hold in place to get a couple bolts started then start and tighten all bolts useing a cross bolt tightining pattern to make sure the pan is in place{ tighten one bolt then do opposit bolt} change oil filter, and refill with oil.. if you need to see this done youtube is an excillent place to find videos on this.. i hope this helps... remember to let the car cool before doing this so get everything you need and start the next day before you drive.. nothing worse that getting hot oil down you arm while your laying on the ground...
Jul 24, 2011 | 1995 Ford Windstar
I want to drain the old oil out so i can replace with new oil,, how do i empty it?
Under your car in the front should be the oil pan. It has a bolt on one of it's sides. Loosen this bolt and take it out. Don't forget to put something under your car to catch the old oil. Also, change the oil filter. You should see the oil filter while you are under your car. Before putting in new oil and filter, make sure you put the bolt back in the oil pan. Put a little new oil into the new filter and wipe some oil with your finger around the oil filter rubber gasket. Make sure you don't overfill with oil !
Dec 30, 2010 | Ford Futura Cars & Trucks
How do i change the oil filter on a 1991 cutlass calais? any special tools?
YOU NEED 4.5 QUARTS OF OIL WITH NEW OIL FILTER.YOU NEED OIL FILTER WRENCH YOU NEED WRENCH TO REMOVE OIL DRAIN PLUG.YOU NEED A DRAIN PAN CATCH OLD OIL.NEED LATEX GLOVES TO KEEP GETTING OIL ON HANDS.OIL DOES CAUSE SKIN CANCER.NOW YOU CRANK CAR UP LET IT IDLE 5 MINUTES TO LOOSEN UP OIL AND SLUDGE.TURN OFF ENGINE.SAFELY RAISE SUPPORT VECHICLE ON LEVEL SOLID GROUND USING JACK STAND.PLACE DRAIN PAN UNDER OIL PAN THEN REMOVE OIL DRAIN PLUG LET OIL DRAIN OUT UNTIL IT STOP DRIPPING. PUT OIL DRAIN PLUG BACK IN OIL PAN. THEN SLIDE DRAIN PAN UNDER OIL FILTER REMOVE OIL FILTER LET OIL DRAIN UNTIL IT STOP DRIPPING.TAKE CLEAN PAPER TOWEL WIPE OIL FILTER SEAL SURFACE MAKE SURE NO DIRT ON SURFACE.TAKE NEW OIL FILTER POUR NEW OIL IN FILTER UNTIL ITS ALMOST AT TOP THEN.RUB CLEAN OIL ON NEW OIL FILTER SEAL.THEN PUT NEW OIL FILTER IN PLACE HAND TIGHTEN IT.POUR 4 QUARTS NEW OIL IN ENGINE CRANK CASE USING A FUNNEL.WHEN DONE.CRANK THE ENGINE CHECK FOR LEAKS AT OIL FILTER AND OIL DRAIN PLUG.IF ALL IS GOOD JOB WELL DONE.
Aug 11, 2010 | 1991 Oldsmobile Cutlass Calais
I do not have the manual for this saw, Poulan pp3816 pro 38cc, could not get it to rum, not sure how log it has been since it last ran, put newgas hose on due to it was broke. Saw will start when primed...
A manual can be found here:
Poulan.com/CurrentModels
http://www.poulanpro.com/node4043.aspx
Type just the model numbers (choose the suffix after the list is provided).
It sounds as though the fuel system is plumbed in reverse, it should be similar to this.
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 01, 2010 | Poulan Pro Chain Saw 46cc 20"
Changing the oil
Buy four quarts of oil, oil filter, you'll need couple sockets, oil pan, jack stands, hoist, and strap wrench.
(1) Park vehicle on flat surface.
(2) Open hood and unscrew oil filler cap.
(3) Take oil pan and yourself under vehicle and unscrew drain plug to allow old oil to drain out of vehicle.
(4) As oil is draining from vehicle, go ahead and prepare new oil filter by applying some oil to the rubber "O" ring on new filter. Thats therubber ring on the filter that butts up against the block when thefilter is screwed and tightened into place.
(5) Now that the new filter is ready to be used go ahead and put drainplug back into vehicle oil pan at this point all old oil should havebeen drained out.
(6) Go ahead and use oil filter wrench to take off old oil filter, youmay be able to use your bare hands to take this off as these arejust hand tightened let old oil drain from oil filter housing for a fewminutes. Wipe area clean with a rag before putting new filter on. Nowyou can install new oil filter remember to hand tighten new filter onlyyou won't need to use oil filter wrench to tighten oil filter
7) Now you can add new oil by pouring it into the same place you took off the oil filler cap.
(8) After pouring in oil check oil dipstick to make sure you havepoured the proper amount, this is usually done by making sure new oilis at the top of of the crossed section that is at the bottom of thedip stick.
Dec 29, 2009 | 2006 Chevrolet Malibu
Change oil filter honda civic 2003
buy new oil filter, oil, and a new drain plug and gasket. the used plug is prone to leakage. remove drain plug and drain in a big enough pan for all the oil. oil filter is located on rear of engine. easier to remove from the bottom of the car. put oil on the seal of the new filter and hand tighten. replace oil plug with new gasket and plug and tighten to 33 foot pound. add oil that is required and start car. when oil light goes out shut car off and check oil add oil as needed.
Oct 12, 2009 | 2003 Honda Civic
Need instructions for doing an oil change.
For doing on oil charge need to waste oilbasin ,new oil filter ,new oil canister.After that you need to run genine whith oil cleaner atleast 10 minutes,after wentilaiting ,stop the engine ,open drain plug and drain derty oil in waste oil basin,close drain plug, replase old oil filter ,fill in new oil.
Aug 09, 2009 | 2005 Mazda Tribute
Engine will not turn over to start. new battery, spark plugs. car sat for about 6 months. put octane boost in with newgas and also used starter fluid near the fuel injectors.
Can you hear clicking or anything when you try to start it? If you hear clicking or grinding, you may just need a jump to boost amps if your starter is going out.If you hear nothing and you still have power to instrumentation and dummy lights, you may have a bad connection from the batt. to the starter. Before you go buy a new starter, try tapping on it with a small hammer on the solenoid.( the small round thing on the side of the starter) There is a magnet in there that sometimes gets hung up, especially if its dusty. Make sure that all connections are corrosion free on the battery as well as the starter. Don't forget the ground to the frame, as they can get corroded and/or loose too! Start with the batt. connection and work to the starter. Hope this helps!
Jul 22, 2009 | 2002 Chevrolet Cavalier Coupe
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
