Question about Air Tools & Compressors
Afternoon, I have a LeFoo LF14-4h pressure switch and took it off to check the valves and it came apart. Is there a diagram to put it back together or where can I find a new one..Local in Roxboro, NC
Afternoon, I have a LeFoo LF14-4h pressure switch and took it off to check the valves and it came apart. Is there a diagram to put it back together or where can I find a new one..Local in Roxboro, NC. Thanks a bunch
SOURCE: How do I put it back together?
buy a new one, look at it, put yours back together and return the new one.
Posted on Oct 13, 2007
SOURCE: wont build pressure over 25 psi after rebuild
cagey here i took mine in to be fixed and it was the piston and rings. they couldn't hold over 33psi of pressure.
Posted on Feb 26, 2009
SOURCE: i took apart my 66 powermaster bb gun and i cant
C66-OM
C66-EVP & PL 1 & 2
Powermaster. Pneumatic, BB repeater, .177 cal., single shot pellet. First variant w/zinc receiver. 1983-1988 Some parts are available. 66 pdficon.gif
C66-OM
C66-EVP
Powermaster. Pneumatic, BB repeater, .177 cal., single shot pellet. Plastic receiver. 1988-2001 Some parts are available. 66 pdficon.gif
C66CLIP-OM
C66CLIP-EVP
Powermaster. Pneumatic, BB repeater, .177 cal., single shot pellet. Plastic receiver and 5 shot manual clip. 2001-Present Some parts are available
HERE IS MANUALS I FOUND..HOPE THIS HELPS..
Posted on May 04, 2009
SOURCE: need wire diagram
A manual can be downloaded from the following link, the wiring diagram is located toward the end of the manual.
http://www.star-mfg.com/documents/Manuals/Star/Fryer/Electric/C_530TD_530TED_-_2M-Z6600.pdf
Hope this helps, please rate me!
Posted on May 12, 2009
  • 76 Answers
SOURCE: need to see a diagram on wireing fore elect starter
what brand and model machine are we talking about also if you have any patent # you could enter that at google pat. search may have exploded view dia.
Posted on Jun 23, 2009
I took a Lefod Mod LF10-1H Pressure Control switch apart and I'm now looking for a diagram on how to put it back together.
You silly person you should not have taken it apart if you are not capable of doing the job
Dec 18, 2015 | Washing Machines
I have a Makita MAC2400, it stopped working, didn't realize where the reset button was, took apart the on off switch thinking there may be a fuse, the spring made it all fall apart as soon as I took the...
The pressure switch is assembled by automation and is basically impossible to put back together by hand. Even if you did manage to get it back together, the adjustment if critical. Easier to replace with generic pressure switch. Order from ebay for about $15. Just pay attention to port size and cut-out pressure. Select a switch that has on/off ,several ports on bottom and cut-out from 125 -135 psi. Factory switch is too expensive and really not any better. Good luck
Sep 04, 2013 | Makita MAC2400 Electric Powered Air...
Lefoo pressure valve leak
Where is it leaking from? If the unloader hisses for a few seconds when the compressor shuts off, it is working fine. If it hisses all the time when the compressor is stopped, it is still fine, but your in-tank check valve is toast. If it hisses when the compressor is running, you need a new switch.
Mar 03, 2013 | Emglo LEFOO Pressure Switch LF10
I have a LEFOO LF10-4H pressure regulator that I tok apart and it fell apart before I had a chance to see where all the part went. Can you show me a diagram of the switch?
I too am looking for a diagram. I am still trying just fit it back together and I have tried to get a diagram from Lefoo, no response to my repeated emails. If I do get it together I will post pics.
Dec 29, 2012 | Air Tools & Compressors
Air compressor will not restart at cut in pressure. i have removed line from head and found no backpressure but motor will start every time. replaced switch with new unloader valve, still have same...
the start windings are probly burnt. does it hum when it his cut in. i had one the same. u bleed it down to nothing and it would start but slow. once its up to speed the motor switch snaps and u go to the other set of wires in the motor. it will work good till it cuts out. like u said no back pressure at the head. but wont anyway. well if u try to start it its not long and the short pipe to the check valve builds up if u start from empty the check valve can open and let the air out while it slowly speeds up if this sounds like ur problem then u need a new motor i had one i took apart and the start windings, the thinker shorter ones, were stuck together because the clear insulation melted together. i spit them apart using a screwdriver and gooped them up with that liquid black tape. put it together and nothing. found out i broke one. so i twisted it together good and put it all together again and pluged it in. it still works today. it was just a temp fix but i figure untill it stops working again im not going to replace it.
Nov 18, 2010 | Air Tools & Compressors
My SPST switch kit came apart during installation. Do you have a diagram that can show me how to properly put it back together?
If it came apart your best bet would be to purchase a new one. These switches take a lot of pressure on them as the door is constantly being opened and closed. If you did get it back together I do not think it would last long.
Sep 12, 2010 | Gardner Bender #GSW-SK Door Switch
Air Tools & Compressors Logo
120 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
