Question about Bosch Washing Machines
Door won't lock on washing machine
Had P27 message did what was suggested hold delay and spin selection turned knob left to cold and door opened. No door will not lock
    New Friend:
    Problem Solver:
  • 7 Answers
New lock ?
Posted on Nov 24, 2014
  • 1294 Answers
SOURCE: Maytag Neptune MAH5500B
Try some WD40 on the lock.
Posted on Jan 23, 2008
  • 351 Answers
SOURCE: Washing Machine LG WD-8013F
it may be the lock but this model is known for board faults,take of the top panel and remove the control panel and see if the board is burnt.there was a recall on some of these machines a while ago in australia not sure where you live
Posted on Apr 03, 2008
SOURCE: Door locked
After trying all the above, making sure that as much of the water has been removed as possible, you can always use the manual door release. This is located behind the soap powder tray.
Push to open as you would normally when adding more soap powder, pull the tray out as far as you can.
Press down on the yellow portion in the tray and this should enable you to then pull the soap tray completely out.
Once out you should see what looks like a small grey plastic circle with a rectangular hole (ideal for a screwdriver) turn this and your door should open.
Posted on Jun 22, 2008
  • 1462 Answers
SOURCE: Fixing broken door lock of Indesit W123X washing Machine
no easy way to open
disconnect from mains
take top off. feel down the front to where the door lock is and see if you can feel the door peg sticking thro the door interlock. force this with your fingers and with luck the door will open
if can't do this way, break handle off and lever peg with a small screwdriver
you can buy a handle kit complete. fitting this is not difficult - split the door and all will be revealed advise you make a carefull note of where springs go etc before you start stripping it down or take a few fotos if you have a digicam
Posted on Jul 10, 2008
  • 1294 Answers
SOURCE: washing machine door locked indesit WD12X
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 5 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped
Posted on Apr 02, 2009
Model EWF10843. How do I select diagnostic mode?
Electrolux Diagnostic Mode
* Press the Cancel button to enter standby mode and enable diagnostic entry.
* Within 10 seconds after pressing Cancel , press any button to wake up the control.
* Within 5 seconds of wake up, turn the selector knob to the far left cycle and press and hold Cancel and far left
button under the display simultaneously for 3 seconds to enter the diagnostic mode.
To save time at wake up, the Welcome screen can be bypassed by turning the selector knob.
1. Upon entering diagnostic mode, all lights should flash for 1¼"x2" display models and all lights on for the 1¼" x
4 3/4" display models.
2. Turn the program knob (1) click clockwise from the start position. The hot water solenoid will activate and hot water
should enter through the detergent compartment.
3. Turn the program knob (2) clicks from the start position. The bleach water solenoid will activate and cold water
should enter through the bleach compartment.
4. Turn the program knob (3) clicks from the start position. The bleach and the wash water solenoids will activate and
cold water should enter through the softener compartment.
5. Turn the program knob (4) clicks from the start position. The prewash solenoid will activate and cold water should
enter through the prewash compartment.
6. Turn the program knob (5) clicks from the start position. The door lock solenoid will deactivate and the loading door
can be opened. When the door is opened, the drum light should turn on.
7. Turn the program knob (6) clicks from the start position. The door lock will activate and the washer will fill then
tumble. Once tumbling has started, the boost heater will turn on.
8. Turn the program knob (7) clicks from the start position. The drain pump will activate draining out any water in the
tub and the washer will operate in high spin.
9. Turn the program knob (8) clicks from the start position. This is a free position.
10. Turn the program knob (9) clicks from the start position. The control will signal the last 5 error codes with E00
being no error.
11. Turn the program knob (10) clicks from the start position. Latest software version will be shown.
12. If applicable, turn the program knob (11) clicks from the start position. This is a free position
Exiting Diagnostic ModeA) Unplug the power cord, wait 5-8 seconds, then reconnect the power cord or
Turn the program knob clockwise back to the start position. Press the Cancel and far left button under the display
until the LED's stop flashing
Jun 08, 2015 | Electrolux Washing Machines
E:27 error on bosch 500 series washer
turn the dial to the off position. Hold down both the delayed start and spin select buttons and turn dial to the left one click (cold position). you should then here the door unlatch. let go of the buttons. you will see some other codes p 01, p 02. turn dial to off. it should work fine after this. it worked for me. this should be in the manual.
May 15, 2012 | Bosch WFVC6450UC 500 Series Vision Front...
E:27 on 500 series bosch washer
Door lock error code unplug the unit for 7 minutes if the error code does not clear you will have to replace the door lock assembly in the unit. If you have any further questions message me back. Note by unplugging the unit for 7 minutes an the unit not having power this causes the control to reset. I await your reply if you have any further questions.
Thank you
Rick
May 15, 2012 | Washing Machines
My wife hit pause during the wash cycle to remove BBs from my sons pocket. She opened the door removed the BBs closed the door and hit Play/Start when she got the error E27. I have unplugged the unit for...
  1. Hold down the "Allergy rinse" button, "Spin Selection" button at the same time.
  2. Turn the Wash selection knob to the left on "Cold". Result: You should see different codes flashing on screen, this is resetting the machine's error, and is exactly what we want.
  3. After a few seconds turn Wash selection knob to "Off".
  4. Turn machine back on.
Result: Your mashine should work
cheers
Aug 31, 2017 | Bosch WFVC5440UC Washer
Bosch 500 series front load washer less than 6 months old. Getting code E27 when turning it on... suggestions before I call service?
E27 means there is a problem with the door lock.
Unplug the machine for 30 minutes and try again. If the error code returns you will need to replace the door lock assembly. Open and close the door two or three times to reset the sensor. Sometimes the door has been closed too hard and the sensor reading fails.
Replace the door lock assembly on the washer. Refer to your washer manual for the correct part numbers.
Check to see if your Bosch washer is still covered under warranty. If so, you could receive free replacement parts and service for the faulty door locks.
Hope this helps (remember to rate and comment this answerr).
Jul 16, 2011 | Bosch Evolution 500 Series B20CS51SNW 20.2...
Have a BOSCH 300/500 series washing machine. showing E27 error code. WHAT is it? Why don't they provide error codes?
The door locking mechanism has malfunctioned and/or is overheating. It is recommended that remove power from the appliance (unplug it) for 30 minutes and try again. If the problem persist, you will need to replace the door lock assembly.
Nov 26, 2010 | Bosch Washing Machines
Bosch 500 series washer E:27 error code?
turn dial to off. hold down both delayed start and spin select buttons and turn dial to the left one click, to the cold position. keep holding button until you here a click. let go of buttons and turn dial to off. Every thing should go back to normal. Just fixed mine and all is good.
Nov 21, 2010 | Bosch WFVC5400UC Washer
Won't spin
Close the door firmly and make sure the machine is turned on. Press and hold the Chime and Extra Rinse keys until the control beeps to enter Service Mode. All indicator lights will turn off except the "Door Lock' indicator signifying the door is locked.
Press the Rinse & Spin key then rotate the cycle selector knob in either direction to display the most recent error codes if there's any. Press and hold the cycle selector to display the number of cycles since the error occurred. List down at least five most recent codes and post it here for us to determine what the problem could be. Press and hold the Delay and Chime keys for three seconds to clear the list. Press the Rinse & Spin key again to exit diagnostic codes list.
Press the Spin Only key while in the Service Mode to begin the Board Input Test. Set the rotary cycle selector to Super Wash then press it to display the position of the door switch. "OP" will be displayed if the door switch is open or "CL" if it is close. Replace the door lock/switch assembly (part #34001265) when "OP" is displayed even the door is close. Press the Spin Only key again to exit the Board Input Test.
Press the Spin Speed key while in the Service Mode to begin the Board Output Test. If water is present in the tub, set the rotary cycle selector to Quick Wash then press it to turn on the drain pump and drain the water. Press the rotary cycle selector again when the water is fully drained to turn off the drain pump.
Press the Delay button to turn on the motor and the Delay indicator light. The machine should tumble clockwise then counterclockwise with 5 second durations each and 2 second intervals. Press the Spin Speed key again to exit the Board Output Test.
Press Off or press and hold Chime and Extra Rinse keys for three seconds to exit Service Mode. Unplugging the washer will also exit Service Mode.
Perform the tests above and let us know the results for us to determine the cause of the problem or the necessary action to undertake and give you the specific and detailed instructions on how to fix it.
Mar 03, 2010 | Maytag Neptune MAH9700 Front Load Washer
Washing Machines Logo
27 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
