Question about Garden
Walbro carb will not take throttle after rerbuild
  • 1,169 Answers
THe following assume your carburetor is adjustable.
First make sure metering is set at the correct height. Depending on carburetor seat the mixture screws then turn 1-1/2 CCW as initial mixture setting. Once your engine is running and warmed up tune the idle mixture first half between too lean and too rich then do the same with the high speed at full throttle. Warning if the top speed exceeds the design top speed enrich to slow down. To set the max top speed it is best to a tach designed for small engines.
Posted on Nov 21, 2014
I have a 42' poulan riding mower w/ a 14.5 B&S engine, it has a Walbro carb...needing to replace the carb thats on it, I found that the Engine offered two different manufacturers of carbs?
i think walbro is a better carb. nikki is ok but just dont like them. it should be ok. why dont you just put a rebuild kit in the one you have? that is only $10.00 or $12.00
Jun 19, 2016 | Poulan Garden
Walbro carburetor diagrams
must be a small tiller to have a walbro carb on it most of these have a hole drilled in throttle cam ("D" looking thing on top) that the cable has a "L " hook that goes into it cable clamp must me loosed to allow a 45 degree entry of "L" hook into "D" plate
Jul 23, 2014 | Craftsman Garden
I rebuilt the Walbro carb on a Pioneer 1074
Go to: www.drystacked.com for a 12 page PDF document that describes, explains theory, and servicing this line of carburetors. Note the precaution on placing the gasket in the lower chamber. After presetting the H and L jet needles, start the engine and allow to warm up. Open full throttle and adjust the H needle CW to allow the engine to 4-stroke, but will immediately 2-stroke when starting to cut wood. Adjust L needle CW to allow fairly smooth idle, but will allow the engine to 'follow the throttle'. Hope this helps!
Apr 06, 2010 | Garden
Thottle will no stay in one position. There is a black spacer that slides over the throttle shaft between the shaft an the leaver. Will a new leaver come with that black spacer. Blower model wt200
Three (3) possible carbs were available on your machine.
If you have:
Walbro model WT-606 carb, the choke and throttle levers are available in kit form (which leads me to believe the spacer comes with them). Throttle lever kit part #530071726 and choke lever kit part #530071725.
If you have:
ZAMA model C1Q-W11 carb, the choke AND throttle levers are BOTH a part of the carb itself. (Would need a whole carb to get your part.) Complete carb part #530071465.
If you have:
ZAMA model C1Q-W11C carb, the choke and throttle levers are available in kit form (which leads me to believe the spacer comes with them). Throttle lever kit part #530071715 and choke lever kit part #530071716.
Hope this helps.
Oct 04, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Engine will not throttle up
the red and white screws are the air and fuel mixture needles they may need adjustment if you are getting plenty of fuel to the carb. note that newer walbro carbs these mix set screws can only be adjuted very little. they will break if you twist to much. but firt when you took the carb apart was the fuel metering diaphram crisp or was it still flexable? ( black gasket thing under side cover . it has a small metal botton in the middle of it. if this does not flex freely then you need a walbro carb gasket set. mabe 5 to 10 bucks.
Jun 08, 2009 | Ryobi Garden
Garden Logo
82 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
