Question about Capresso Jura Impressa J9.3 One Touch TFT, Silver
Jura J9.3 Shows ERROR 1 when powered on. Tried "everything" but it won't start. Changed TRIAC
Got an Error 1 on my Jura J9.3 - changed the TRIAC on the power board, still no go. Thermal sensor is ok measuring 10KOhm at 18C. Thermal cut-out is ok. Heater element seems OK. Machine always asks me to rinse the water tank when powered on. I can't measure any AC power at the heater element at any time. Any ideas?
I get code e06 on a samsung p1005j Ken
Hi there
Here are all the error codes and what you should do:
General Error Codes
E1: Water Supply Error
-Display Shows 'E1'
-Water Supply Error occurs when water level frequency does not show changes more than 100Hz or water is not supplied up to the water level presetting for 20 minutes or more at the time of initial water supply.
-To help fix this problem please check the Hot and Cold water intakes, there is a filter screen in each input valve, remove and clean these filters. ** Make sure you replace the filters, they are very important for the operation of the Washing Machine.**
-The error status can be cleared by turning POWER S/W OFF and resuming the POWER ON initial status.
E2: Water Drain Error
- Display shows E2
- In case the water level frequency is 25.5Hz or less in the initial phase of UNB-detecting cycle.
- Water Drain error can be cleared by turning POWER S/W OFF and resuming the POWER ON status.
E3: Over-Flow Error
- Display shows E3
- Over-Flow error occurs when the water level is too high. It can be cleared by turning POWER S/W OFF, turn POWER S/W ON and then run the drain cycle for 2 minutes. Water is drained prior to POWER S/W OFF and it is forced to be drained for 2 min if a frequency of more than 25.24 KHz is detected
Door Open Error:
- Display shows door
- This can fixed by closing the door
E4: Unbalance Error
- Display shows E4
- Laundry load is unbalanced; loosen any tangled laundry.
- If only one item of clothing needs washing, the final spin result might be unsatisfactory and an E4 error message will be shown in the display window.
- Unbalanced error is cleared by POWER S/W OFF and by resuming the POWER ON initial status
E6: Please see "Eb" at end of list.
E7: Pressure S/W Error
- Display shows E7
E9: Water Leakage Error
EA: Tacho Error
- Display shows EA
- This is error can be cleared by turning the power off and then on again.
Eb: Motor Triac Short Error
- Display shows Eb
E6-EB can only be corrected through Service. Please contact Customer Service Department at 1-800-SAMSUNG (option 1-1-2) to schedule an on-site service call for english service.
Thank you for using FixYa. Have a nice day and please remember to rate this solution as 356ebb3.png if it helps you.
Kind regards
Dustin Ellse
Jul 03, 2008 | Samsung Washing Machines
How to fix malfunc.8 of the jura impressa s90
Error 8 is a general error for not being in sync. There is a encoder disk that tracks where all the mechanical pieces are during the process. When they are not where they are supposed to be its an Error 8. This can be caused by a jamb, being dirty, faulty sensor... lots of stuff. Probably means your unit needs to be disassembled and cleaned.
The quick way to clear this is pulling the cord out of the wall and wait a few seconds and plug it back it. This will cause everything to reset and usually clears the error... until you can clean it.
If you need help, parts guru has videos on youtube, parts and will rebuild you brew group for you. I have repaired mine 2x.
Nov 09, 2013 | Coffee Makers & Espresso Machines
Malfunction
Error 1 is a defect in the steam heating unit.
Possible solutions:
Thermal sensor is defective -replace.
Cable to the thermal is broken or contact pins are corroded - replace, repair.
Heating or thermal cut-out are defective - measure and replace parts if required.
Triac on the power board is defective. The heater heats up triggering the overtemperature protection - Replace the overtempereature protection (thermal cut out) and the power board or the single triac.
Oct 08, 2013 | Jura Capresso Impressa F9 Espresso Machine
What is an error code E5 mean?
Error code 5 means : Required temperature not reached.
Causes/Trubleshooting
Thermoblock has blown - replace thermoblock.
Power electronics is defective - replace the triacs of the power board or the whole power board.
Attention - determine resistance value of the Thermoblock to avoid subsequent errors.
Jul 09, 2013 | Jura Capresso Jura-Capresso J6
Jura impressa s9 is displaying error 1
The Owner Manual for the Jura Impressa S9 One Touch identifies Error 2 as being too cold and disabled for safety, but simply instructs to "Turn the IMPRESSA off at the power switch. Contact Customer Support in your country." for all other errors.
See Online Manual: http://content.costco.com/images/Content/Misc/PDF/OwnerManual-671992.pdf
Apr 29, 2013 | Jura Impressa S9 One Touch
Zanussi washing machine ZWF 14581 error code 43 is showing up. How can I reset the machine so that it works normally?
Zanussi code 43 states 'problem with the door interlock triac', sorry- likely service call ;-0(
Good luck
John C.
Oct 08, 2011 | Zanussi ZWF1430W Front Load Washer
Jura f70 error 8 solution
There is a Jura Error Guide that says:
  • Turn machine off, turn the main power switch off and unplug machine for at least one minute.
  • Turn machine on again. If the error message comes up again, try one more time.
Dec 31, 2009 | Jura Capresso Impressa Z5 Espresso/Coffee...
Capresso Jura Impressa J9.3 One Touch TFT, Silver Logo
61 people viewed this question
Top Capresso Saws Experts
Bill Boyd
Tom Chichester
ray gallant
Are you a Capresso Saw Expert? Answer questions, earn points and help others
