Question about Flotec Automatic Sump Pump Float Switch
Where can I purchase a Flotec float switch no.ps17-162 for my model pump FP18OODCC-01
3 Suggested Answers
SOURCE: Flotec Sump Pump Tethered Float - Float seems faulty. Easy fix?
I have the same problem. It's not the float but the switch. My float goes up but not with enough pressure to flick the switch. I am trying to find a fix for this now.
Posted on Mar 07, 2010
  • 24 Answers
SOURCE: I have a Flotec pump model #FPSC4550A that will
Sounds like the contact inside the float is stuck. It can be corroded and not letting the circuit open and that will keep the pump running.
If it had been fine but just started doing this, that is what I'd check. If someone could have accidentally wired it incorrectly when they were trying to fix it, perhaps they accidentally bypassed the float switch and have it "running hot" all the time.
Posted on Feb 08, 2011
Pump will not stop runningmjn
This seems like a switch problem resulting in dry cycling. Can you turn on/off the pump by lifting the float switch? Is your switch attached or plugged in to your pump? I believe your on your model it is hard-wired. If so, bring it back to the retailer/wholesaler from whom you bought it.
Feb 18, 2011 | Flotec Automatic Sump Pump Float Switch
I have a Flotec pump model #FPSC4550A that will not stop running even though the float falls down. Any ideas?
Feb 04, 2011 | Flotec Automatic Sump Pump Float Switch
I have a flotec model 1m03w fp053200a-o8 1.5 hp sump pump. It run all the time now, the only way it shuts off is if its unplugged. Do I need to replace it, or can it be repaired? Thanks for your time
If you have the pump pictured, there is a float switch in the big round thing that floats. When this float drops, the switch should open and pump should shut off.
Make sure that the pump plug is plugged into the piggyback type float plug.
Jan 03, 2011 | Flotec FP0S3200A-01 1/2 HP 3,200 GPH...
Flotec FPUS1860A utility sink pump won't stop running
Either the float is stuck or the float went bad...
give it a kick and make sure the float has dropped down and is not hung up...
If that don't work then unplug it and replace the float switch...
heatman101
Sep 17, 2010 | Flotec 1/4 Hp Automatic Utility Pump
Flotec Float switch did not automatically shut off,enginburn out
Hi Lamont .. I would first check test the float switch and make sure that it is faulty, set it up in a tub of water and manually move the float switch. see if it cycles on and off. sometimes the float will get hung up on its support or on the edges of the sump pit. If the float switch is faulty then YES it can be replaced,. try a building supply store like home depot or the pl;ace where you got the switch originally.
Please Vote !!
Jun 01, 2010 | Flotec 13 Hp Automatic Submersible Sump...
Flotec 3200a sump pump sensor not working
Check the connections in the float switch (sensor). Give it a bang it may be stuck
Jul 02, 2009 | Flotec FP0S3200A-01 1/2 HP 3,200 GPH...
Pump not kick in
the float has a mercury switch and that is what will make it turn on and off.  this ball sounds like it is not working correctly.  you will have to replace it.  just the ball
Jun 22, 2009 | Flotec 1/4 Horsepower Sink Pump System
Switching off too soon.
you don't need to replace the switch just raise the upper stop up higher so the float can go higher before turning the pump on, it should have a rubber gromet on it slide it up the rail
Jun 21, 2009 | Flotec 3.4 Hp Floodmate Submersible Sump...
it sounds like it could be a bad float switch but most of the time the water isn't high enough for the pump to turn on. it takes alot of water to turn on a tethered float. the other pumps they sell at lowes with a real float (like the one in the toilet) are adjustable and also replicable. .
Apr 11, 2009 | Flotec Simer//Omni 2957 Submersible Sump...
Flotec Automatic Sump Pump Float Switch Logo
60 people viewed this question
Top Flotec Electrical Supplies Experts
Craig Butler
Craig Butler
Paul Nielson
Paul Nielson
Are you a Flotec Electrical Supply Expert? Answer questions, earn points and help others
