Question about Sony Televison & Video
I have Sony w1900. I want to run the channel setup again. When I go to menu then setup, where it says Channel setup it is not lit up. How do I turn that on so I can proceed?
Nothing
    Top Expert:
  • Sony Master
  • 74,383 Answers
Refer its user manual for details. Electro help
Posted on Nov 22, 2014
How do I turn on channel set up on a Sony w1900. It is not lit up on setup menu.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Nov 21, 2014 | Sony Televison & Video
How to change the channel my Sony Trinitron TV turns on to?
hit menu button on your remote, navigate to channel setup menu. on the sub-menu, set channel fix to your channel that you require. now when your tv powers up this will be the default channel. if this doesn't fix your issue then try cycling through video inputs tv/video button on your remote.
Nov 10, 2013 | Sony FD Trinitron WEGA KV-24FS120 24" TV
I have lost all my channels on my tv but cant find how to search for them again
Try unplugging it and plugging it back in. It may prompt you to run a setup or channel scan. If not then go into your tv menu and look for setup or channel search.
Aug 11, 2011 | Televison & Video
Got rid of cable, how do I change from set channel 3 to open channel choices.
To perform Auto Program again
1 Press menu
2 Press right arrow to highlight Channel Setup Menu.
3 Press down arrow to highlight Cable. Press + to select.
4 Press up arrow or down arrow to select On or Off according to how you connected your TV. Press .
5 Press down arrow to highlight Auto Program. Press + to search for channels.
6 After performing Auto Program, press menu to exit.
This should pull in all of your over the air channels
Dec 02, 2010 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Auto search through
Tested and verified solution:
  1. Set Tuner Mode to "antenna".
  2. Run a channel scan. Should get zero channels found.
  3. Set Tuner Mode to "cable".
  4. Run another channel scan.
  5. Celebrate!
Aug 16, 2009 | Vizio VX37L Television
How do I tune in Sony Triniton tv please
Hello
The first thing is to try going in the tv's menu
It should be similar to this:
Menu>setup>channel setup
once you find something similar, run the channel setup and it should add in the channels
If that doesn't work, screw on the cable wire, unplug the tv for a good few minutes, then replug the tv and it should automatically scan
Hope this helps
-Chris
May 01, 2009 | Sony Televison & Video
Ghannel Fixed:3
Go to the on screen menu, select the third option from the left "channel setup"(CH), scroll down to "channel fix" select it and turn it "off".Exit menu and you should fix the problem.
Jan 29, 2009 | Sony FD Trinitron WEGA KV-20FS120 20" TV
TV forgets channels when unplugged
Has it always forgotten the channels when you unplug it or is this just a recent development? I know that on my old standard tube television or VCRs, the channel memory is always reset if they are unplugged - the same being true if the power goes out.
Jul 27, 2007 | Dell W1900 19 in. HD-Ready LCD Television
Problem with changing channel and volume
your TV is having problem in the power supply area or th secondary power supply where the micro processor is situated.take it to a qualified techn to be repaired.
Jan 20, 2007 | Dell W1900 19 in. HD-Ready LCD Television
Televison & Video Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
