How to connect ps1 to my tv.?
Connected yellow to tv's component video, & red & white to audio but tv says nothing is connected.
  • 5,499 Answers
These are AV connections! When connected with the component phono leads turn on TV, then turn on the PS1 then select AV on the remote to select the AV channel!
Posted on Nov 21, 2014
SOURCE: TV connections- Wii, Direct Tv and DVD palyer
Hidden switch for output coonections on back panel of dvd player.
Posted on Dec 29, 2008
SOURCE: lcd tv hookup
Ive got 3 samsung tv's (lcd, plasma, DLP) and I use HDMI cables on all of them. Its the only way to get the full potential out of the tv. When you use the red/white/yellow RCA cables the signal is anolog aka "old technology". Component cables are good but HDMI is the best. HDMI is a digital signal and thats what all the components that go with the tv should be run on. If your dvd player does not have an HDMI output I would suggest getting one that has that output. As for the cable box most require you to upgrade to digital cable in order to get one with an HDMI output. If you dont want to spend the money on new components and run what you have now the picture will stay mediocre at best. Good luck hope this helped
Posted on May 11, 2009
vinnyq
  • 157 Answers
SOURCE: My wii connection is black and white
You are connecting it into the wrong input. The Wii comes with a RCA cables that should go into the Video (composite) input that has yellow, red, and white. The component input will not work with the RCA cable input. Plug your Wii into Video1 and you should get the right colors. There should be another HDMI on the side of your TV, there are inputs located both on the back and side of the TV for your convience.
Posted on Oct 10, 2009
SOURCE: connecting ipod to samsung lcd tv
how to connect I-pod to samsung lcd tv
Posted on Oct 16, 2009
ArnelM
  • 153 Answers
SOURCE: Components are in black and white instead of color
Wrong connection. Hook up the component output from DVD player or Wii to TV component input using component cable(red, green and blue plug)
Posted on Dec 29, 2009
Need manual for pelican system selector pro s-1037
The pelican doesn't upscale. If you have yellow white red connecting something to the pelican, you need yellow white red connecting the pelican to the TV, not just component cables.
Jul 05, 2012 | Pelikan Score System Selector Pro S-1037
Have connected cable (white, yellow, red) from Conia DVD player to TV as component 1 and connected Sony VHS cable (white, yellow, red) to TV as component 2. What other steps need to be taken for the...
component video needs Red, Green, Blue to be connected on the DVD end and to the TV for video to display, also the Red and White audio out needs to be connected to the TV for audio to work .
VHS has Red, White an yellow for Right Audio, Left Audio and video respectively.
You need to switch the inputs on the TV to the corresponding Component and Video inputs. Most TV's have a source or Input button to switch between the inputs. simply press the button until you have the input you are looking for.
Mar 13, 2011 | Televison & Video
Is i possible to connect a rca cable to the converter box from a dvd player and watch on the tv?
DVD players can have several outputs:
* coaxiable cable
* composite video (RED/WHITE for stereo audio, and YELLOW for video)
* component video (RED/BLUE/GREEN to video components, plus RED/WHITE for stereo audio)
* HDMI
TVs can have several inputs:
* coaxiable cable
* HDMI
Just use the correct tables to "match" the output to the input.
Feb 21, 2011 | RCA (DTA800B1) Video Converter
Which dvd connection go to which TV connection.On the dvd I have component(white), video(red),audio(orange), y(green),Pb(blue) and Pr(red)
Connect yellow video from DVD to TV. Connect white audio and red audio from DVD to TV. These will be next to yellow jack. That is all the connections you need for picture and sound. Use RCA cables available at Radio Shack or Wal Mart.
Aug 11, 2010 | Televison & Video
Trouble with 360 and hdtv
The cable your refering too are called Component leads.
The red and white are for your audio and the remainder are the video. All you need to do is connect the component leads matching up all the colour in the correct ports then using your av/source button change the tv to component
You will still have to connect the red and white audio cable to the tv as well.
that should sort your xbox out.
cheers
Little Dish Fitter
Sep 18, 2009 | Proscan PS36700 36" TV
How do i hook up a nintendo to my tv which cords go where and can someone walk me through it
Round peg into the round hole. Red peg on the red slot. etc. If the wire from the nintendo doesn't fit the slot on the tv then you're in the wrong slot. if the wire from the nintendo fits the slot on the tv (and is the same color if you are using red/white/yellow rca cables) then you're good. here's a hint on connection types (you will not mix): 1. RCA (red/white/yellow round connectors) Red=right audio sound White=left audio sound Yellow=video connect to the slots that look like they want some. 2. Coaxial (stiff cable with a pinner poking out of the end -- same cable that connects you to cable tv) just hook it up by itself; it carries audio and video. 3. Component (red/green/blue)(red/white) two 'bundles' red=red component of video green=green component of video blue=blue component of video red=right audio white=left audio 4. VGA + (red/white) VGA=video (computer monitor cable) red=right audio white=left audio 5. HDMI (flat hdmi cable. you spent $30 on this 3 foot ****) HDMI=audio and video 6. hugs and kisses hugs=video kisses=audio (both sides)
Jul 15, 2009 | Video Game Consoles & Games
From cable box component out to tv component picture is on no aud
You need to also connect the RCA audio out (red/white) from your source to the audio input on the TV. You do not need the yellow wire as that is for composite video. The component cable (red/green/blue) is only for video. Look at the input on the TV where you connected the red/green/blue cable. Right next to it, you should have another red and white connectors for the audio input. Connect that to the audio out on the cable box.
May 01, 2009 | Digimate DGL20 Television
Proscan 26LB30Q Vs PS2 = HELP
The red white and yellow cables are composite connections. The red/green/blue connections are component connections.
The playstation's composite connections consist of two audio connections- red & white, and a composite yellow video connection. The TV's white connection is the audio, and the red/green/blue are component video. You need an adapter that will connect the one yellow(composite video) to the three red/green/blue (component video) connections
Feb 28, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
I HAVE A RCA TELEVISION, MODEL F20632. I CANNOT FIND THE MANUAL TO HELP ME SET UP MY VCR. I HAVE A 4-PLUG VIDEO CABLE (YELLOW, BLACK, GREEN AND RED). CAN YOU TELL ME WHICH CONNECTIONS ON THE TV I NEED TO...
the yellow rca input jack( not the output one ) is for video in (by itself ) and the red and white rca jack inputs are for the right and left audio that is also required when using the yellow video jack
the red and white audio jacks are also required when using the component video inputs ( BLUE , GREEN & RED ) rca jacks
but only one type of connection is required ( yellow video jack , red and white audio jacks ) or ( the blue , green and red component video jacks and the red and white audio jacks )
you will need the yellow video input and the red and white audio inputs
Jan 05, 2009 | RCA F20632SE 20" TV
How to hook up video game to my lcd samsung 1080p
on the ps1, connect the cable that has the Red, White, and Yellow connections on one end to the black connection that looks flat (or both ends if you have the model with the Red, White, and Yellow connections on the back of the PS1).
connect the other end (red, white, yellow) to the TV with the same colors, on the same row. Note the input name (video 1,2... or aux 1,2...).
turn on the PS1. On the TV, change to the input name that you just connected the ps1 to.
you should see the ps1 menu.
Aug 24, 2008 | Televison & Video
Televison & Video Logo
47 people viewed this question
Top Televison & Video Experts
Electro Med Services...
