Question about Keurig Coffee Makers & Espresso Machines
Keurig Elite B40 Coffee Maker water runs through when power turned on.
Fill water reservoir and turn power on, and the water pumps out, without stopping or warming.
  • 3 Answers
The problem is the water valve. The valve is either stuck open due to lime and scale build up or the valve has gone bad and needs to be replaced. The cheapest and easiest thing to do is clean it. Get a gallon of white vinegar and fill reservoir 3/4 of way with vinegar and rest with water. Make sure you put a big enough pot under it to retrieve the poor out. Run this through 2 to 3 times and if it is because of lime and scale this should clean it out and it should start to work again. Do this at least once a month but then you will only need to run it through once. Keurig does sale a solution just for this but white vinegar is cheaper and works just the same and will not hurt your unit. If this does not work then you need a new valve and in most cases it is cheaper to buy a new machine if you can not do it yourself. Hope this works for you and enjoy your coffee.
Posted on Dec 01, 2014
4 Suggested Answers
cmccune04
  • 213 Answers
SOURCE: need parts list for ELITE B40 KEURIG coffee maker
Should be listed in your manual. If you need parts check this out.
This is actually an ebay store. They have any Keurig part you could possibly need! It's the only steady keurig part business operating right now. Prices are fair products are in great condition. Seller has 100% positive feedback with 100's of satisfied customers who voiced their opinions of them.
They have parts for Keurig B30 mini, B40 Elite, B60 Special Edition, B70 Platinum, and B77
http://www.igotsweetdeals.com or
http://stores.ebay.com/Igotsweetdeals
Posted on Apr 14, 2010
tgmusicgirl
  • 92 Answers
SOURCE: Elite B40 Coffee Maker: I NEED FOR MY KEURING B 40 THE WATER RESERVOIR...
start looking at ebay...
Posted on May 06, 2010
vetteman3002
  • 2299 Answers
SOURCE: Problem with the Keurig Elite
Keurig is having a big problem with this. When you turn it on, pick up the reservoir and place it back down. What you are hearing is the unit trying to pull the water through and it won't. It will try for a minute and then shut itself off. So power on, lift and lower water unit and it should be good. CALL KEURIG and tell them about the problem. If enough of us call then maybe they will do something.
Posted on Oct 27, 2010
My Keurig Elite 40 (B40) beeps continuously when I turn it on.
Heating element may be damaged...return for exchange asap
Mar 05, 2013 | Keurig Elite B40 Coffee Maker
Keurig b40 pump out of sync
PLugged exit port tube. Manual Page 18
Jun 24, 2012 | Keurig Elite B40 Coffee Maker
How do I dissassemble a b40 keurig coffee maker?
Pull plug, reset factory settings and Prime again.
Jan 15, 2012 | Keurig Elite B40 Coffee Maker
My Keurig Elite brewer is not brewing. When I turn it on, it makes this weird buzzing noise, but it will not fill with water. None of the other lights are on either. What could be the problem?
Aug 31, 2010 | Keurig Elite B40 Coffee Maker
How to clean the Keurig coffee maker.
fill the reservoir with distilled white vinegar and leave the brewer on for 4 hours (leaving the auto off option OFF). after the 4 hours, run the entire vinegar filled reservoir through the machine.
refill with water and repeat twice. your machine is now cleaned and descaled.
Apr 05, 2010 | Keurig Elite B40 Coffee Maker
Descaling light on
Per Pages 9 and 10 of Keurig Model B40 Use and Care Guide,
1) turn off the "Auto Off "feature
2) fill empty water reservoir with 48 ozs of undiluted white vinegar.
3. Place ceramic cup on the drip tray and run a brew cycle. Do not use a K-cup!
4. Press the large mug Button
- let Keurig coffee maker fill mug with vinegar & empty in sink.
5. Repeat brew process until water reservoir of vinegar is empty. (remember to open and close lid between each cycle so large mug Button will flash.
6. Rinse the water reservoir thoroughly and fill with fresh water.
7. FINAL STEP RINSE CYCLE
a) place a ceramic cup on the drip tray
b) run regular brew cycles WITHOUT using a K-cup.
c) pour rinse water into sink each time.
d) repeat brew process until water reservoir is empty.
d) perform additional rinse cycles if you notice any residual vinegar taste.
e) if the red "De-scale" light remains illuminated after completing descale and rinse cycles, repeat the descaling procedure above.
Otherwise - you're good to go!
Apr 16, 2008 | Keurig Elite B40 Coffee Maker
Coffee Makers & Espresso Machines Logo
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
