Question about Hoover Candy Fridge Freezer Pcb Control Module 97922579
How do i get rid of smll from fridg
Nothing not sure what to do
  • 2,471 Answers
We set a dish of baking Soda in the fridge and it helps freshen it up.
Posted on Nov 21, 2014
I instal a new ice maker and a new solenoide valve to mi refrigerator but no ice in the ice maker i dont now Wath to do.
Make sure water is getting through and the water lines arent cracked or split.check for power to the water solinoid there are three pcbs that contol all the signals for water control.Like ive said before get rid of the fridge.Do not buy the fridges with ice makers they not worth the hassles.
Feb 28, 2012 | Refrigerators
How any fridge keep things cool inside it
are you asking the basics of refrigeration? if so here it is. refrigeration is the absence of heat. air inside the fridge is blown across cold coils. the freon inside those coils pick up or remove the heat from the air. the freon then takes this heat to the coils that are on the back of the fridge or under the fridge to get rid of it so it can pick up more heat inside he fridge and the process starts all over again. This is why it is so important to keep the outside coils clean. the outside coils have to get rid of the heat.
freon can not pick up heat inside the fridge if it can not get rid of the heat outside of the fridge.
Your homes air conditioning works the same way and so does any window air conditioners.
hope this is what you were asking for.
Jun 11, 2011 | Refrigerators
Kelvinator fridge freezer, fridge too cold frosting at back
Fridges that are less then 10 years old have a lot of POWER. To get rid of the frost, wait until you have eaten most of the food up (maybe a few days), then unplug the fridge and leave the doors open. This will take care of the frost after several hours.
From then on, make sure that when your fridge is full, use a higher setting, and when it is near empty or half way full, use a lower setting. Keeping the freezer at a mid to low setting all the time should be fine, because its usually the fridge part that gives people trouble.You will have to judge on your own which setting is best (i.e you can tell when its good based on how cold the juice is in there, etc).
By adjusting the setting based on the amount of food in your fridge, it should prevent frosting.
Hope that helps!
Mar 28, 2011 | Kelvinator KBM5100MB
How do i format sandisk 4gb micro sd hc
You shouldnt have to format it.Though it is possible. first check and make sure the drive is not locked. There should be a smll switch on the side of the sandisk. Second be Sure your device supports HC cards. Read This tip carefully If its your computer and it has a HD compatible slot insert the drive, open my computer , you should see its new icon as a drive. Right click on the drive and select Format from the list. But, as a reminder if your device supports the HC or XC format drive, it should work without a Format. Hope that helps ya, Gurvy
Sep 01, 2010 | SanDisk 4GB microSDHC Memory Card
When I power on my HP Pavilion a1220n, the HP symbol comes up on the monitor, then it goes to a black screen with a smll blinking cursor for a few seconds, then...NOTHING. The power stays on but the screen...
You could check to see if the memory chips inside have dirty contacts. Happens often, basically you unplug it, remove the side cover, find the memory chips, try to remove them but basically just work them in and out a couple times to clean the contact points, reinstall and it might work. This happened to mine this am, worth a try.
May 12, 2010 | HP Pavilion a1220n (A1220NED904AA) PC...
Freezer working but Fridge not cooling... Tried adjusting temp to max cool and nothing. Unblocked vents, still nothing... Pulled off back panel cover to vacuum and brush... still nothing... help??? In case...
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
Oct 26, 2009 | Amana ARB1917CSR Bottom Freezer...
Fridge goes from cold to warm
it seems like low gas in the system
Jun 16, 2009 | Refrigerators
Smelly fridge
Try heavy sprinkle of Baking Soda on the paper plate. Put this plate in the refrigerator. Sometimes it helps. Also, check under bottom tray(s). There maybe a drainage clogged up. It is usually there to get rid of condensation.
Hope this works.
Oct 02, 2017 | Refrigerators
Fridge running constantly and ice maker wont work
sound like it is low on freon ,,,, if so it runs all the time trying to get cold enough to shut down and it wont make ice ,,,, 1st check to make sure the fan inside is blowing, make sure the temp in freezer part is atleast +5 or below if it hasn't cooled right front the start then thats why they got rid of it ,,,,, leaking freon and it cost to much to repair that problem / larry
Nov 29, 2008 | Refrigerators
Hoover Candy Fridge Freezer Pcb Control Module 97922579 Logo
46 people viewed this question
Top Hoover Dishwashers Experts
Gil Shultz
Are you a Hoover Dishwasher Expert? Answer questions, earn points and help others
