Question about Technics Audio Players & Recorders
Safe to use 4 speaker with Technics Receiver?
Hello, does anyone know if it is safe to connect and play X4 Wharfedale Diamond Speakers simultaneously with my Technics SA-GX350 Receiver? The Wharfedale Speakers are rated at 6 ohms impedance. The Maual for the Technics Receiver states that when X2 speakers are connected they can be between 4-16 ohms, but when connecting/playing X2 PAIRS of speakers their ohms must be between 8-16 ohms. Hence my concern ad the speakers are 6 ohms. Would this set up cause the Teceiver to overheat ? Would really appreciate any advice please? Stephen.
  • 1 more comment
  • Stephen Murphy
    Stephen Murphy Nov 23, 2014
    Thanks for your efforts so far. The problem is that the receiver manual States NOT to connect speakers LESS THAN 6 Ohms when using 4 speakers at the same time. ALL 4 of my speakers are only 6 Ohms. I need to know will connecting and playingALL 4 speakers SIMULTANEOUSLT cause damage to the Receiver AND/OR THE 4 speakers ? Many thanks, Stephen.
  • Stephen Murphy
    SORRY I MEANT TO WRITE "LESS THAN 8 OHMS AT THE START OF MY COMMENT.
  • Stephen Murphy
    Thanks FastHarley but the Wharfedale Diamond 10.1 speakers definitely are 6ohms impedance. It states this in the manual and historically the vast majority of Wharfedale speakers have rated at 6 ohms impedace. Still not sure if I should risk trying this but it would be great to see how great it might sound. It's a but like having a turbocharged engine with the turbo but being inaccessible! Many thanks thus far. Stephen.
  • 637 Answers
The best thing to do is place a VOM meter to confirm that there are 6 ohm speakers
Posted on Nov 23, 2014
On back panel impedance for 2 speakers is 4-16 ohms. I run a pair of 6 ohm speakers with receiver and this is find. I want to connect 4 speakers all 6 ohms impedance and need to know if this is safe for...
Stephen, it may depend on how the system is protected, but generally the protection is designed to prevent the transistors from overcurrent. This would happen if you turn the volume up too high. If your receiver is newer--say built after 2005 or so, it will likely protect itself. You can hook up your speakers and see if it works. It will likely trip the internal protection at high volume, depending on the amplitude of the music signal. My main warning would be to not run the volume high for long periods and make sure there is nothing blocking the cooling vents on the unit.
Jan 14, 2015 | Audio Players & Recorders
Compatibilty
If what you say is true, you should be fine.
Where you get into trouble is having an amp of higher power than your speakers. That means you will likely blow your speakers.
Nov 12, 2014 | Audio Players & Recorders
Technics receiver SA-GX350 Receiver Manual states to be only used with 8 ohms speakers. I've used 6ohm speakers with this receiver for over 20 years. Please explain is it safe to do so?
its not safe but manageable.if the speaker impedance is too low, the amplifier will tend to overheat and more power is used up in the amplifier than is delivered to the speaker. Too many speakers on a solid state amp can burn up the power output section.
Oct 26, 2014 | Audio Players & Recorders
Marantz NR1402 AV receiver Going to standby Mode
There could be a short in one (or more) of the speaker connections. Try disconnecting all speakers and turning on the receiver. If it still switches to standby, there may be an internal problem.
Mar 03, 2014 | Marantz Nr1402 Av Receiver
I won't bore you with the long, tedious reasons for the question, but I need help in connecting the amplifier cables to my Wharfedale 8.3 speakers. There are 4 connection points on the speakers: two...
Leave them in, do some reading on Bi-Wiring (BUY Wiring), chuckle to yourself and enjoy the sound. Connect one positive to a positive and one negative to a negative. With the jumpers in place there is no electrical difference.
Jul 29, 2011 | Wharfedale Diamond 8.3 Main / Stereo...
I just brought some wharfedale one-three speakers and have them hooked up as the rear speakers. Can i get the sub to play still and do i hook the speaker wires in the top or bottom?
Do you mean "Modus 13"?
See picture 6...
http://www.freeads.co.uk/uk/av/audio/hi-fi/speakers/8402337/wharfedale-modus-one-three-speakers-black-rare-bi-wire-quality/view
Put the jumpers back in as shown. Hook your speaker leads to either top or bottom. The entire array of drivers will be active.
Make your receiver aware they are LARGE for the purposes of bass reproduction so some bass will get out to them. FYI, many AVR's will only allow Large Rear speaker selection if you also have Large Fronts. Refer to the manual(s).
Mar 07, 2011 | Wharfedale Diamond 8.4 Main / Stereo...
Can't get the back off of my Wharfedale Diamond's. Model 7.1
Sometimes the back does not come off, but the speaker comes out from the front...
Mar 22, 2010 | Wharfedale Diamond 8.3 Main / Stereo...
"Low Imp"
Low Impedance is not a suggestion, it is a WARNING. Your receiver is telling you it senses TOO LOW a load and it's trying to protect itself from damage.
Speakers A& B are running in parallel, so their combined impedance, X, is found by using the formula: 1/X = 1/A + 1/B.
In other words, two 8-ohm speakers in parallel would yield a 4-ohm load.
If your speakers are identical, try running them in series on one speaker output pair. That would keep the impedance safely high.
Feb 15, 2010 | Technics SA-AX540 Receiver
Speaker connection from Denon AVR 2105 to Wharfedale suround
The spkrs sound like they are bi-amp spkrs, meaning you have multiple terminals on the backs of each spkr, the jumpers on the spkrs should be connected as such. Now you just connect the spkrs according to the Denon spkr conection diagram. Do not use the surround back unless you have 6 or 7 pair of spkrs
Jan 27, 2009 | Denon AVR-2105 Receiver
Harman Kardon AVR 245 Receiver PROTECT Error Message/Shutting Down All Equipment
could be your receiver only, it has tripped due to discrepancy on the output stage of your amp. that cracking sound in one of your speakers could have caused the trouble. it is possibly shorted. but in your case it could have damaged already the amp that;s why it would not turn on. normally it will first trip, turn on then turns off. but to stay off and not to turn on again is major problem of the amp. or maybe it emanated from miscabling, probably the ceiling speakers got connected to a high output or main amp. but try removing all speakers first then turn the unit on. see if it does power up.
May 22, 2008 | Harman Multimedia AVR 245 7.1 Channels...
146 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
