Question about PfaFF Creative 7570
When winding the bobbin the needle continues to move.Whats wrong, I have done as is instructed...
    New Friend:
  • 80 Answers
Loosen the knob in the center of the wheel you turn to move the needle manually this dissingages the needle drive
Posted on Nov 21, 2014
Testimonial: "Been there, done that, as is normal and in the operating manual, which still doesn't work!!The needle continues to move when filling the bobbin!! What next!!!"
3 Suggested Answers
SOURCE: Bobbin Winding
How do I wet wind a 2 inchs long bobbin using varnish.
Thanks
Gholam
Posted on Mar 14, 2009
  • 980 Answers
SOURCE: Locking disk on handwheel won't lock and I can't wind a bobbin
If the stop motion wheel is stuck and you can't free it the best way to do it is to stand at the end of the machine, get something that looks like a chisel or something that has a flat end even a screwdriver, put the end of the screwdriver in a slot on the left hand side of the stop motion and give it a sharp thump down, it worked for me for years, the only problem you may have is if you do not have any slots or grooves to put the screwdriver in.
Posted on Nov 01, 2009
Just received a singer futura II model 920 which seems to sew just right. When I tried to wind a bobbin, I just can't get it done.
If it is a new machine, take it for warranty service. Sounds like perhaps something is misaligned with the release lever. In the meantime, a standalone bobbin winder can be purchased at JoAnn's, Hancocks, or Amazon.com for about $35 (helps reduce wear & tear on your machine).
It's very difficult to say whether it is worth the price of repair. On the other hand, what would you do with a machine that doesn't work? It could be something very simple that can be repaired for a small price, or it could be something expensive. (However, since you indicate it is only the bobbin winder that is faulty, otherwise the machine works with that one exception, you can save up to get the bobbin winder fixed.) FWIW, a standard check, clean & oil could cost around $100 (based on what I currently pay for my machines). However, you could ask what it would cost to fix the bobbin winder only.
From a search on eBay:
http://www.ebay.com/sch/i.html?_nkw=singer+futura+920
You can track similar machines and their sales prices to determine if it would be worth fixing your machine. Even if you don't, you can still purchase the standalone bobbin winder and continue to use the machine anyway. A working machine is better than none at all.
Feb 02, 2016 | Singer Sewing Machines
Why always in bobbin-winding mode?
bobbin winder still engaged. try moving it.
Aug 14, 2014 | Sewing Machines
Pfaff 2046 tension problems, needle breaks
Needle breaks
1.the needle is damaged
2.the needle is not correctly inserted
3.wrong size needle for the fabric
4.the wrong foot is attached
5.the needle clamp screw is loose
6. Top tension is too tight--loosen off one letter or number till the stitch
looks normal
7.make sure that every thread guide is used when winding the
bobbin,, so that the bobbin will wind tightly, if this doesn't help,,
then it's possible that the bobbin winder needs adjustment,, it needs
to be taken to a sewing machine shop
Aug 15, 2012 | Sewing Machines
I only want to know if the wheel must be loosened to wind the bobbin and if so with direction, to the front or backwards and press and turn or pull and turn.thanks
Which make and model sewing machine do you have?
None of my sewing machines need the wheel to be loosened for bobbin winding. The Singer Touch & Sew bobbins are filled in place. Use the handwheel to get the needle into the highest position (just turn the wheel). Wrap the top thread around the screw that holds the presser foot; open the slide plate part way and press the bobbin wind button. Hold the top thread and then begin winding by stepping on the foot pedal.. The thread should break after a few winds.
The Kenmore and the Husqvarna Vikings both get wound at the top. Place bobbin on winding pin. With the needle up and metal presser foot in place thread the top thread up to the bobbin (through the guides) and up through the hole in the bobbin. Slide the bobbin winding switch over towards the bobbin. Hold the thread tightly and begin winding (step on the foot control). After a few winds are on the bobbin, cut the thread that you were holding flush with the top of the bobbin. Continue winding the bobbin. (The newest Viking in the group has a computer screen; on that one, do not press OK until done winding the bobbin.)
However, if the handwheel is not turning and the needle is down, first find out why it isn't turning properly. This could indicate a tangle of thread somewhere in the system. (The older Husqvarna sewing machine in my home has a non-functional handwheel. The machine will still sew but you have to use the needle up/down switch that forces the needle to stop in the up position before you run out of bobbin.)
Please add a comment with the specifics of your sewing machine and I'll be glad to add additional information.
I hope this helps.
Feb 28, 2012 | Sewing Machines
I am a beginner sewer, I just purchased the Emerald 203...I can't remember how to get the bobbins threaded, I looked in the manual, but it doesn't say how to thread it or how to thread a bobbin, which is...
The Husq Vik. machines have a raised white arrow that guides you in threading and winding bobbins. There are 2 ways to wind a bobbin. The one that I prefer is by threading the machine.
Begin by raising the needle to the highest position. This is done by turning the fly wheel towards you until the needle is at highest point.
Next, Place your spool of thread on the thread spool, with the thread coming over the top like a roll of toilet paper. Make sure you have a spool cap at each end of the spool. (your mannual will tell you what the parts are if you do not know what I am talking about).
Next, take your thread to the left, you should see a "track to follow". You will go left for a very short distance, then straight down (still following in the track), when you get to the bottom of the track, you make a "u-turn" up moving the thread to the take-up-lever. If you do not see the take-up-lever, you do not have the needle in it's highest position. Hook your thread around the take-up-lever from right to left.
Then follow the track down to the needle. You have a thread guide that hooks to the left just at the top of the needle - slip the thread in that guide by moving left to right. Thread the needle from front to back.
You should have it threaded now and ready to wind a bobbin. Simply take the thread under the presser foot and to the right - make sure the presser foot is raised. Also, always make sure to use a metal, not a plastic, foot when using this method.
Hold your bobbin with the writing side (crown on it) facing up. Wrap your thread around it clockwise about 4 times. Place bobbin on the bobbin winder. (top far right of machine close to fly wheel.) Make sure it is snapped down.
Push bobbin up to engage and lock. Slowly step on foot pedal. Bobbin should begin winding. Do not wind too full. Leave about 1/16 around to allow the bobbin to move freely in the bobbin case.
If you always keep the bobbin with the writing facing up, you will never have to worry about getting it wound the wrong way.
Hope this helps
Feb 14, 2011 | Husqvarna Viking 1
I have a Singe 3116. The needle not working
the clutch is out. that allows you to wind a bobbin. take it out of bobbin mode and put it in sew mode (clutch in)
Feb 26, 2010 | Singer 3116 Simple
Wind bobbin on Decor Excel 5018
Once you have the thread guided and the bobbin is on the thread winder spindle, push the bobbin to the right.  The machine will not sew again until the spindle is in the left position.
Feb 03, 2009 | Janome D'cor Excel 5018
I have a Singer XL5000 machine, the normal looking bobbin is not spinning with the shaft and wont wind what have I done wrong?
Is your bobbin case holding in place right? See if you can jiggle it back and forth to see if it moves. If it does move, it may have unattached itself in it's inner-casing.
My bobbin case would just go back and forth in the casing. Make sure that your needle plate is inserted right, as it locks the bobbin case in. You may have to unscrew the needle plate, take out the bobbin case, place it back in - pushing it to your left as you glide the needle plate back into place. (go from front to back while inserting). It should catch your bobbin case and lock it into place. Hope this helps. If not I would suggest you take it in for repair. Good luck.
Jan 14, 2009 | Singer Quantum XL-5000 Computerized Sewing...
The needle wont move at all?
Hello we had the same problem with our sewing machine. After playing with it we found there is a bobbin winding assembly lever that moves back and forth. By moving it the needle moved. This helped us. Hope it helps you. embreyR97@yahoo.com if you have questions.
Jan 05, 2009 | Brother XL-5130 Mechanical Sewing Machine
Bobbin Winding
Thanks
Gholam
Jun 16, 2008 | PfaFF Creative 7570
Sewing Machines Logo
136 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
