Question about Maytag Refrigerators
How to fix water leak n freezer
Mod#MF12665XEM7
  • Maytag Master
  • 744 Answers
Hello Sigifredo;
My name is Peter. I am a retired field service refrigeration technician.
The model number that you submitted is in error. It does not register with Maytag refrigerators.
Anyway, You either have a frozen defrost drain or a problem with your ice maker.
1.) Frozen defrost drain; Behind the back wall of your freezer there is a defrost drain. When your refrigerator goes into the defrost mode every 8-10 hours, your refrigerator completely shuts down with the exception of the lights. When this happens your defrost heater, located beneath your cooling coils turns on for about 20-30 minutes. The heater defrost the cooling coils into condensate. This condensate goes down the condensate drain. If the drain is frozen, the condensate has no where else to go except the bottom of the freezer. You can unplug your refrigerator to clear the drain, but the problem will reoccur The best way to do a permanent fix, unplug the refrigerator, remove the back cover. There is a bottom tray filled with ice. Using water collection rags and a hair dryer, patiently melt the ice. DO NOT USE ANY HARD TOOLS TO CHIP AWAY AT THE ICE. Having located the drain, use warm water and pour into the drain. Patience is the key.
Ok, the drain is clear and water flows down it.
Now, with a length of either 12 or 13 gage wire, strip one end about 2" long. Wrap this end around the defrost heater (A metal bar at the bottom of the cooling coil). Be extremely careful, the fins on the cooling coil are razor sharp. Extend the wire to the drain hole. Measure and strip the other end of the wire so 2" of bare wire are on the drain hole.
2.) Your ice maker may have a leaking cube mold, or a frozen fill cup. If you know how cycle your ice maker and observe the fill mode.
You have not provided a model number, so I can not give you more detail to accomplish these tasks.
Posted on Nov 22, 2014
    Novelist:
    Scholar:
  • 79 Answers
Some thing I would do if mine had a leak is secure the source of water. mine Is in the basement. it's a clear 1/4" tube with a small valve. once pressure is off I would try to isolate where it's leaking from.Usually water comes in on a high corner. My ice maker is on the left so the line comes in behind it. Tell me you have an ice maker. stop me if you don't have an ice maker... ok you do, good.
Now the supply branches off to cold water or ice maker. It gets the water cold as it passes through that area,then goes to the choice cut-out in the door. you may need to cheat the doors to watch things drip. Ask yourself is the water making the trip to the ice maker or has there always/recently been an issue. I had a weird prob last summer where the ice maker didn't work and there was water everywhere in front. Turned out the ice cubes mutated into an weird size that never let the small door shut; hot air from the room melted the weird size; next request for ice replaced the mutated size, keeping the small flap open and the vicious circle started again. Anyway that might not be your issue but (good memories) cheat the doors watch where it's dripping from. Get flashlight, it gets dark with the doors "shut" look for something to tighten. plus my big Cadillac LG came with a factory plug you could replace the filter with (is your filter installed correctly?) This plug Im talkin about seals everything off I believe, so It can be a useful tool to troubleshoot with... Good luck my polar friend~~~~SC door cheating refers to a way that the equipt thinks doors are shut so it acts normal, for troubleshooting only.
  • 180 Answers
SOURCE: whirlpool mod#et18pkxgwu top freezer,no ice maker.
The Water is coming from the defrost cycle melting the ice on the evap coil.  There is a drain that goes to a tray near the compressor where the heat from the compressor evaporates the water.  That drain is clogged.  Take the back panel off of the freezer and unclog the drain hole.  Most of the time it is iced over and the ice needs to be melted.  It could also  be clogged where it comes out at the compressor.
Posted on Oct 25, 2009
SOURCE: Frigidare Mod.FRS26H5AS Leaking water into bottom
I had the same issue.. I checked this web site and found the solution (on another post).. It was the drain of the fridge being blocked.. I didn't know the existence of such drain.. it turned out that it got blocked with some dust, therefore with every defrost cycle, the water was not going down to the evaporator tray, then going inside the fridge (eventually freezing), then overflowing to the outside doors.. Check on youtube for videos on how to open the fridge and clean this drain.. Have fun..
Posted on Aug 14, 2010
Testimonial: "Worked fine!Everythings working perfect again. I shut off Freezer for about an hour then I used a thin copper wire to unplug the drain hole. Thanks!"
walesarumi
  • 6993 Answers
SOURCE: water leak from freezer into
To correct the problem, you must locate the drain and inspect it for blockage. Often, you'll find it frozen, but it's usually always solid debris blocking the flow of the water that's CAUSING it to freeze: and that must be removed from the drain or it WILL happen again.
Where is the Drain?
After unplugging the fridge from the AC power, go ahead and pull the unit out where you can access the back. This is also a GREAT opportunity to clean dust off of the condenser coils and compressor, which will GREATLY lower your energy costs! (Use a Vacuum with brush attachment)
Depending on the model of refrigerator in question, the drain port can be located in several places. The most likely location is just under the freezer, which is actually the top of the fresh food compartment: The tube usually comes out there, and down the outside of the refrigerator; (On Back) However, it can also be under the coils behind the false back and/or side walls. At any rate, when looking for it, keep in mind that its' sole function is to drain water away from the evaporator coils when the unit is defrosting itself; Therefore, it's almost ALWAYS just under the freezer at the end of a "channel" that directs all of the water into it.
Cleaning the Drain... Depends on what's causing the clog.
If it's iced up, the quickest way to thaw it is with a hairdryer. It takes just a minute with the hairdryer set on max.
Before you get happy and close everything up though, ALWAYS check the tube for debris.
About 95% of the time, I've found something in a frozen drain line. Remember: It wouldn't have been frozen in the first place if the water had been able to drain off!
After checking the pan under the freezer for debris in the pan and exit hole, you'll need to check the tube itself. The best test is just to blow through it like you would a straw. If it's clogged, you'll feel some resistance.
To clear a clogged pipe: There are numerous ways, but the most efficient is to use a can of electronics duster. (ONLY the kind that comes with a nozzle extension tube) WITH A PAIR OF CLOTH OR LEATHER WORK GLOVES ON BOTH HANDS!: Stick the nozzle extension down into the drain tube. Wrap one hand around the top of the tube and the nozzle to form as tight a seal as you can, and press the trigger. The clog should be blown right out: if not repeat as necessary. Reconnect it all, then pour a little water through it and check for leaks.
Hope this helps!
Good luck.
Posted on Jan 28, 2011
SOURCE: my GE mod#tfx20jrxd 19.7 cu. ft. is leaking water ...
water is leakinf from the frnt right bottom of my refrigerator model TFX20JRXD
Posted on May 08, 2011
imufo2
  • 3773 Answers
SOURCE: water is leaking from bottom
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Posted on Aug 26, 2011
I have a whirlpool refrigerator model m#EB9FVBRWS05 and the water leaks from freezer, freezer not defrosting and frost buildup . How do I fix this problem?
There are three main components in a defrost circuit, the heater, the thermostat and the control device(either a timer or and ADC board). One of these are not working.
Dec 24, 2015 | Whirlpool Refrigerators
Water is leaking from bottom of freezer two door bottom freezer mod#596.79329010
Leo Ponder
imufo2
Aug 24, 2011 | Kenmore Refrigerators
Hi there, I have a MAYTAG MSD2758DR Refrigerator and every night water is leaking from front left and floor is getting wet. The amount of leaked water is nearly a cup of water.
If your chest freezer is showing signs of age, it may begin leaking. There are a few methods for troubleshooting faulty chest freezers but knowing some of the obvious signs of why it might leak can be very useful if you need to fix it yourself. Leaking is not limited to older models so be aware that certain maintenance procedures can help prevent leaks in newer models.
Understanding Changeable Parts Prior to Troubleshooting There are not that many serviceable or changeable parts inside a chest freezer. A chest freezer works on a very simple basis. It contains evaporator coils, condenser coils, a compressor, a compressor overload, a relay and a thermostat. These are the basic moving parts of a chest freezer but some of them are not serviceable.
The condenser coils condense the water and the evaporator coils disperse excess water caused by the freezing process. The compressor is a heating component which compresses excess water and recycles it through the system.
Defrosting Remove the contents of your chest freezer and place them in an alternative area to keep them frozen. Unplug and defrost your chest freezer before you do any troubleshooting or maintenance. Wipe and clean the inside of the freezer so that when you plug it back in it, will free of any grime or loose bits of debris. A clean freezer will also help to promote visibility when it comes to fixing leaks.
Where is the Leak? Once you have defrosted your freezer, you need to establish which part of the freezer the leak is coming from. It could be coming from the inside of the freezer and this would indicate a thermostat issue. Alternatively, it could be coming from the freezing unit at the back of the freezer. Water always finds a way to escape so your leak could be restricted to one place but the actual cause could be elsewhere. Locate the drain tube which is normally found at the back of the freezer. You will probably have to unscrew or unclip the backing panel.
Check the Drain Hole If the drain hole on your chest freezer has become blocked for any reason, you will need to clear it thoroughly to continue getting the best performance from your chest freezer. The drain hole is a component within the lower works of the freezer through which excess water runs to be recycled.
Compressor Issues Your chest freezer contains a compressor which evaporates the excess water from the freezer. The freezer will defrost excess ice and the water flows down the drain tube to a pan where the heat of the compressor evaporates the water. If your compressor has failed, the leak will be caused by the water failing to evaporate. Have a repair contractor replace your compressor or, if this is not cost-effective, you may need to buy a new freezer.
Thermostat If your freezer is not freezing at all and is dispersing water in several places, you may well have a thermostat failure. Check that your freezer is cycling correctly prior to making changes or altering the thermostat. Only if the freezer is not cycling are you likely to need to change the thermostat. If you have checked all the parts of your freezer and you still cannot locate the leak, calling in a service technician might be the best answer. Take care in solving the problem....
Aug 18, 2011 | Maytag MSD2559XE Side by Side Refrigerator
My drip pan under the frig over flows with water then on to my floor. both fans work. Air flow from freezer to frig and back seams good. Tube going to drip pan is clean. Seals looks good and clean. MOD...
I had a similar problem with my Whirlpool model 6ED25DQFW side by side refrigerator/freezer with ice maker/water dispenser. Water was slowly pooling under the refrigerator under the freezer section. The defrost drain pipe was not blocked, the condenser fan was running, the drip pan was not leaking.
The source of the leak was found to be the icemaker solenoid block plastic body which had a pinhole leak.
To fix requires either plastic welding, or replacement of the solenoid block plastic body.
To access the solenoid block firstly requires removal of the cardboard cover, located at the lower rear of the refrigerator.
Aug 16, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water leaking inside around the drain from the freezer, water collects in the bottom under the drawers
Defrosting
Where is the Leak?
Compressor Issues
Thermostat
Hope this will help in solving the problem...
Aug 04, 2011 | Amana ATB1504AR Top Freezer Refrigerator
Our Kenmore Elite fridge mod 596.76252702, leaks about a cup of water on floor, 1-2 times a month
The condensate drain that takes the defrost water out of the fridge is blocked.
Pour some warm soapy water down the freezer drain and this may clear it
Apr 04, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
GE PROFILE MOD. TNX22PRCBRWW....SER# MA 900839V....WATER LEAKING ON FLOOR...MANUAL SAYS TO CHECK DRAIN IN BOTTOM OF FREZZER DONT SEE DRAIN
There should be a bottom plate on the freezer, youhave to remove it and then you have to remove the evaporator cover. There should be two coils (the evaporator) below the evaporator there should be a drainpan with a hole in it.tocheck it poor a little water in the pan to see if it drains if it doesn't you can use a small round hose or tube and push it through the drain hole.
Mar 02, 2011 | GE GTS22KBP Top Freezer Refrigerator
Whirlpool mod#et18pkxgwu top freezer,no ice maker. water leaks from freezer down intt the bottom ver. bins.
Oct 25, 2009 | Refrigerators
Water leaking on floor from under Mod#TPH21PRS;TPH21PBS
I you dont have any water hooked up for the ice maker or for water at the door, about the only thing left is your freezer drain. Look in the back under the freeser side and look for a drain... see where it drains.. over flowing? anyway water could get out from where in drains to?
Aug 21, 2007 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
isaac johny
isaac johny
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
