How do I program for playing DVD's on the TV?
Tried to find it in the instruction manual. Had no problem with the last set but the remoter for this model is different.
    Sergeant:
  • 324 Answers
If the tv has a built in dvd player, you should simply be able to put a dvd in the drive and the tv will auto-switch to the dvd player.
If you have an external dvd player, ensure it is plugged into the tv.
On the remote you should have a button that says either "Source" or "Video"
Press this button until the video input your dvd player is plugged into is highlighted, then press "OK" or "enter" (some tv remotes have one button that highlights and also selects the input)
You may also press the "Menu" button and check in the "video" section if your tv supports "Auto input switching" This will allow your tv to automatically switch to whichever device (dvd player, game console) is turned on while the tv is on.
Please provide make / model of tv and possibly dvd player for further help.
Posted on Nov 21, 2014
  • 3 Answers
SOURCE: code to program polaroid vcr/dvd combo and a new sharp lcd tv
Try 1061 or 1020 hope it works.
Posted on Dec 20, 2007
SOURCE: Instructions for Programming Innovage Jumbo Universal Remote
You can download documentation for the Innovage remote here:
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/innovage/jumbo-manual.zip&area=other
Posted on Feb 12, 2008
FARADIO
  • 17 Answers
SOURCE: lg lcd tv remote code
HI,
BUY A NEW REMOTE FROM E-BAY OR PARTSTORE.COM,TRY A UNIVERSAL ONE IF STILL DOESN'T WORK TV INTERNAL IR INTERNAL RECEIVER IS FAULTY,THANKS.
Posted on Apr 09, 2008
circuitworld
  • 335 Answers
SOURCE: DVD won't play movies in color
RCA cable connectors (red,white, yellow) are usually for an analog setup. You could still use these for "component" setup, but know the difference with color stamps as follows:
Component color stamps are "blue, green, red" ( blue is marked Pb, green is marked Y, red is marked Pr)
RCA color stamps your using are "red, white, yellow"
Here are the proper hook up method for "Component" using your "RCA" connectors:
On both the TV and DVD component setup:
Plug the red RCA fitting in the component port marked "Pr (red)
Plug the white RCA fitting in the component port marked "Pb (blue)
Plug the yellow RCA fitting in the component port marked "Y (green)
Be sure this setup is the same for the TV's component input ports, and the DVD's component output ports.
i-Note:
For optimum picture quality you may want to purchase component cables as the gage is thicker giving better impedance match resulting in better picture and sound quality.
Posted on Jan 25, 2009
SOURCE: mikomi lcd/dvd icannot program the tv to any stations
Have the same problum they say my signal board went bad and I cant find a part to get it fix the com. went bankrupt.
Posted on Sep 15, 2009
Samsung DVD Player remote buttons activate Samsung TV settings
To do a reset of the remote control follow the instructions below.
1. Remove the batteries from the remote control.
2. Hold down the Power button for a full minute.
3. Once done, put the new batteries back in and test the remote control. Please power cycle the unit as well by unplugging it from the wall and leaving it of for a couple of minutes. Once done, test the remote control again. To delete the recorded programs, please follow the steps below
1. Press the BD button on the remote control then press Home. This should bring up the home screen.
2. On the Homescreen, choose AllShare Play and press the Enter Button.
3. On AllShare Play, scroll down to Recorded TV and choose ''HDD''.
4. Now the titles of the recorded programs will appear.
5. Press the Tools on the remote control and select ''Delete'' from the side menu.
6. Select the titles to be deleted by highlighting them, then press the Enter button on the remote control.
7. Select ''Delete'' from the side menu then confirm deletion.
To try and resolve this issue, please reset the remote control. To do so, please refer to the instructions below: 1. Remove the batteries from the remote control. 2. Hold down the Power button for a full minute. 3. Once done, put the new batteries back in and test the remote control. Please power cycle the unit as well by unplugging it from the wall and leaving it of for a couple of minutes. Once done, test the remote control again. To delete the recorded programs, please follow the steps below: 1. Press the BD button on the remote control then press Home. This should bring up the home screen. 2. On the Homescreen, choose AllShare Play and press the Enter Button. 3. On AllShare Play, scroll down to Recorded TV and choose ''HDD''. 4. Now the titles of the recorded programs will appear. 5. Press the Tools on the remote control and select ''Delete'' from the side menu. 6. Select the titles to be deleted by highlighting them, then press the Enter button on the remote control. 7. Select ''Delete'' from the side menu then confirm deletion.
Jun 27, 2017 | Samsung LA40A550 40 in. HD-Ready LCD TV
I have a Phillips universal remote and i can't get it to mate with tv and dvd player don't have the manual
Google the model number of the remote for "manual" to see if can find for free--will have instructions and a list of POSSIBLE codes---not all units can be programmed by certain remotes.......
Nov 04, 2012 | Televison & Video
Ingot my Philips remote programmed on my tv and DVD player. It works but when using DVD player the buttons don't function as its proper function. For example the play button puts the tv on mute,
It is a common problem with any universal remote controls. Try an other code for your device. Select one code which has maximum functionality. Than is the only thing have to do.
Sep 21, 2012 | Philips SRP4004 Remote Control
Unlock Region Code/Instructions - Request
Just spoke with Soniq's help line in Australia. They gave me the instructions below. I have not tried them yet as I have boxed up the TV already and I am moving out of the region. Good Luck.
Unlock instructions for Soniq L37V11B
  1. Turn on TV
  2. Set to DVD Mode
  3. Press Open/Eject
  4. Leave DVD door open
  5. Press 5168 on remote
  6. This should open a Factory Menu, scroll up/down to Region Settings
  7. Change Region to 0, press Enter
  8. Press Open/Eject on remote to close the DVD door.
Soniq Help line in Australia 1300765663, option 2 then option 2
Jul 07, 2012 | Televison & Video
Is there any way to get my tv channel back on 4 with no remote?
Try after amke a factory reset to your tV. Normally, aits remote control is needed to make it channel-4.
Apr 29, 2012 | Televison & Video
Rm-995 instruction
That Sony remote may if batteries removed erase what it was programmed for (several minutes) and should have program instructions on it--if not try to Google the model number of the remote for "manual" which will among other things tell you how to do what you want---Sony on their consumer site may have that manual for free or direct you to a place that does.
Apr 11, 2012 | Televison & Video
Apex DVD/Tv combo GT2015DV won't play dvd's
Something is wrong..crbr799 your DVD-TV has a TV-DVD button on the right front to switch from TV to DVD play...OPEN button on left side ,place DVD in tray, close & press PLAY...
I something simulator that needs the remote control for the SPECIAL functions....by the way the ORIGINAL r\c is $135 to $155, a replacement ($35) will turn the TV\DVD on ( which you can do without the r\c) and NOT function with anything else.
P.S. they will try to sell you universal r\c that work with the CABLE boxes, the ones that you pay a monthly fee!!
Aug 11, 2011 | Apex Digital Televison & Video
I have a Panasonic DMR-ES30V. I've only ever recorded from what I'm watching on the TV to a DVD. I now have a VHS tape that I'd like to record to DVD. I tried starting the dvd to record...
Most Combo Recorders (VHS and DVD) will prevent you from
recording a Copyrighted VHS tape program onto DVD.
Try recording a TV program onto your VHS tape, then
transfer it to your DVD and see if your new DVD recording
will work or not.
Jul 16, 2011 | Panasonic DMRES30V DVD Recorder/VCR Combo
Hi my samsung remote is damaged.I have a one for all tv universal remote & have lost the instuctions to program the remote to the tv. I need the instructions program my one for all tv remote to my...
Hello
These are the programming proceedings for a one for all universal remote control.
[1] Turn on a desired device (e.g.,VCR or
DVD player) and, if applicable, insert
media (e.g., cassette or disc).
NOTE: Please read steps 2 through 4 completely
before proceeding.Highlight or write down the
codes and device you wish to program before
starting step 2.
[2] On the remote control,press a device key
once (i.e., TV,PVR,DVD, CBL/SAT,AUD,or VCR).
NOTE: To program control of a cable box or
satellite receiver, press CBL/SAT once.
NOTE: To program control of a CD player or
audio receiver, press AUD once.
NOTE: To program control of a TV/VCR Combo,
press VCR once.After programming, you will be
able to control channel selection, volume, and
VCR functions.
NOTE: To program control of a TV/DVD Player
Combo, press DVD once.After programming,
you will be able to control channel selection,
volume, and DVD functions.
[3] Press and hold SET until the LED (red light)
blinks twice, then release SET.
[4] Use the Manufacturer's Codes to locate the type of device and
brand name and then enter the first fourdigit
code for your device. If performed
correctly, the LED will blink twice.
NOTE: If the LED did not blink twice, repeat steps
2 through 4 and enter the same code again.
[5] Aim the remote control at the device and
press POWER once.The device should turn
off. If it does not, repeat steps 2 through 5,
trying each code for your brand until you
find one that works.
NOTE: If the device does not have a POWER
key, press the (Play) key.
[6] Repeat steps 1 through 5 for each device you want to control.
OK.
Jul 03, 2011 | Televison & Video
Need a code for my audiovox tv to program my bigmatters jumbo universal remote.
Copy this link and paste it into your web browser. Click on Download File, and you will have the instructions needed to program this remote to your Audiovox TV set. Cheers.
http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=brookstone&dv=universalremote&md=supersizedtvremote538744&kw=big+matters+universal+remote&st=&ar=&dt=&so=&pg=1&file=others/brookstone/supersized-manual.zip
Feb 09, 2010 | Audiovox FPE1506DV 15 in. LCD TV/DVD Combo
Televison & Video Logo
60 people viewed this question
Top Televison & Video Experts
