What can I use to remove a stain of SOYSAUCE in a carpet?
I have tried Resolve , WD40, Pine Sol and an Electrolux carpet cleaner.
    New Friend:
    Problem Solver:
You can use a solution of vinegar and baking powder. I use the same for my Hospitality Carpets.
Posted on Dec 18, 2014
  • 2,355 Answers
1. Mix one tablespoon of liquid hand dishwashing detergent with two cups of warm water.
2. Using a clean white cloth, sponge the stain with the detergent solution.
3. Blot until the liquid is absorbed.
4. If the stain remains, mix one tablespoon of ammonia (Caution: Never mix chlorine bleach and ammonia - the resulting fumes are hazardous) with 1/2 cup of water.
5. Sponge the stain with the ammonia solution.
6. Blot until the liquid is absorbed.
7. Sponge with cold water and blot dry.
Posted on Nov 22, 2014
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 8 Answers
To remove stain you can use the following steps:
1. Hot water: Hot water works wonders in the cleaning process of carpets. Heat is a factor which is highly considered by professional carpet cleaning companies.
2. Detergents: Detergent acts effectively in the attraction of dust and dirt particles.
After using this also if stain is their than you must take professional help as they use chemical and easily remove the stain. I always prefer carpet cleaning Bexley because they have fully trained end of tenancy cleaners who have done a professional job for thousands of customers over the years.
Posted on Apr 04, 2017
How can you get rid of wd 40 stain on carpet
Spray the stain with WD-40, wait a minute or two, and then use your regular carpetcleaner or gently cleanse with a sponge and warm, soapy water. Continue until the stain is completely gone.
WD-40 Uses - Amazing Ways to Use WD-40 ' Reader's Digest is saying you use wd40 to get rid of a wd40 stain. How can you get rid of wd 40 stain on carpet Google Search
Dec 06, 2016 | Vacuums
What is the best way to clean a fresh blood stain from a wool carpet?
Cold water on a clean cloth, blot with damp cloth, then with dry cloth, repeat, repeat, repeat until you do not see any red coming out. If you have a carpet cleaner flush it with lots of cold water sucking it up with your carper cleaner or extractor. A good professional carpet cleaner can prevent your spot from becoming a stain. Often you can use enzyme cleaners to remove blood but NOT on wool carpets.
Apr 07, 2016 | Vacuums
How to flatten a stretched area of berber carpet?
You are not likely to get it lay again unless/until the WD40 fully evaporates and even then you may have caused a chemical reactin in the carpet that cannot be undone.
Oct 15, 2014 | Heating & Cooling
How do I flatten a streched small area of a berber carpet?
The only way I know of to stretch carpet tight is to use a puller ND reset it on the tack board pulling from the loose area towards the closest edge
Oct 14, 2014 | Heating & Cooling
How does the carpet cleaner work
Resolve carpet cleaner is a cleaner specifically designed to work on carpets. Resolve comes as a steam concentrate, a powder, a foam spray, or liquid spray. Before using the carpet cleaner you should vacuum the carpet. Resolve carpet cleaner works by being applied to the carpet then worked in with a soft bristled brush. Depending on the cleaner, it will be sprinkled or sprayed onto the carpet. Use the brush to work the cleaner down into carpet fibers. There is a waiting period for the cleaner to work, then you vacuum the cleaner out of the carpet.
Apr 25, 2014 | Electrolux Sanitaire SC688A Upright...
How to clean car carpets?
Rinse the plastic down one more time with the hose, and then dry with a towel. Spray upholstery with cleaner. Turn your mats around so the fabric side is facing upwards. Purchase a carpet cleaning formula, or use laundry detergent.
Jan 19, 2014 | Heating & Cooling
How to clean spots off carpet
It depends on what the spots. They may actually be stains. Spots will come out if you use the correct cleaning process and cleaners but stains are permanent unless bleached or dyed. If you are not sure it may be less expensive to call a professional carpet cleaner that knows what they are doing (not all of them do)
Dec 30, 2013 | Vacuums
Best way to clean a laminate "wood" floor. I use Pine Sol and lately have been noticing streak marks and dullness.
The old standby of glass cleaner should do the trick. Use a spray bottle, and spray a small 4x4 section at a time, let it sit for about 2min. , then wipe up with rags. Do NOT let it dry on the floor. You have a buildup of product on the floor. The pine cleaner has a small amount of oil in it and it builds up over time. For a good glass cleaner- I would suggest ZEP glass cleaner. For daily cleaning- I would suggest white vinegar 1 part vinegar to 3 parts HOT water. It will sanitize, and also remove salt stains from the floor left by winter boots and dog footprints.
May 19, 2017 | Vacuums
Cleaning spots on carpet my pet throws up on carpet
Robert, I take care of that problem two ways. First I take a very wet cotton towel and put it in the microwave for about 1 minute. After that time I remove it while wearing a GOOD pair of gloves, as you are dealing with steam. Go to the spot and rub the heck out of it with the cloth. You may have to repeat, but do NOT forget the gloves. Also, there is a spray bottle product of a cleaner called Awsome. I find it helps clean these spots as well.
Aug 27, 2010 | Vacuums
Would like to remove urine stains on carpet with steamer. Do not have any instructions. Please help
You should not try to remove the stains with the steamer. Removing stains with a steamer can cause a chemical reaction that will bond the urine to the carpet.
Mar 15, 2010 | Electrolux Envirosteamer 370A Canister...
Heating & Cooling Logo
306 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
