Question about LG Venice Boost Mobile
How do I fix my touchscreen phone to let me press my password in
I tried to hard reset it but it just keep powering on
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
    Problem Solver:
  • 16 Answers
Try fashioning a stylus out of a magnet.
Posted on Nov 22, 2014
Touch screen not working / not registering touch
Follow the steps mentioned below until your problem is sorted.
1. Restart Your Android Device It works 80% of the time. Screen locking/managing applications often make touchscreen unresponsive. In that case you need to restart your Android device. How can I reboot my tablet, the touchscreen is not working.. Good question!
  • Grab your Android tablet/phone
  • Press and hold the Power Button for 10 seconds or until the screen goes blank.
  • Wait a minute or two and then power on your device normally using the same button.
2. Eject Memory Card and Sim Shutdown your Android device and remove the Memory card and Sim(s) attached to it. Also, remove the battery for few seconds if possible.
3. Remove Any Cases Smart cases are good in protecting your device from scratches and damage. But their automatic screen wake/sleep feature sometime cause the device to malfunction. Remove the case, perform a restart.
4. Hard Reset your Android For advanced users. If everything else doesn't work, try doing a hard reset on your phone. This will wipe your phone/tablet and return it to its original condition. This usually involves holding down Volume-Up and Volume-Down button together and then pressing Power Button (every phone has different method). It starts your device in Recovery mode, you can do a Wipe-Factory-Reset from there. Use volume up/down buttons to navigate and press Power button to select. Be careful and don't mess with other options or you may brick your phone.
5. Knocking the Touchscreen (Not recommended) Remove the Screen Protector on your Android device if present. Now, gently knock every corner of your touchscreen to realign it. Sometimes continuous phone drops cause screen digitizer cable to loses its connection to device motherboard however, its a rare case.
If you are still unable to make touchscreen work maybe its time to claim warranty, Its a lengthy process but works. Also, post comments below to share other tips not mentioned in this article.
May 29, 2015 | Cell Phones
Tip
Any phone Hard reset
HARD RESETHard reset is an operation that turn the device into default manufacturer,like the first use a new phone, it will wipe and delete all of your software,data,sitting and virus.if you can't turn on or process device sitting,You still can do the hard reset by instruction below,hope it will help you.........All Hard reset process need to turn device off/except iPhone4 .Make sure that ur phone is full battery and turn off,you can release the battery if necessary.... HTC/Windowsmobile=>press and hold volume up and down,including press power on/off button.you will see an automatic operation press volume up to hard reset or other to cancel./was tried on HD2 and Touch2,work very well.HTC/Android =>While turn off process,hold home+back button,including power button.then release home and back button,you will see an android hard reset operations and follow the in struction...IPhone 3G,3Gs, IPod Touch,IPad...=>- Press-hold the Home button (big circle below the screen) and the Sleep/Wake button (on top of the iPhone) simultaneously .- Continue holding both buttons (Ignore the "Slide to power off") until the iPhone shuts off and begins to restart . You may release all button when you see the silver Apple logo .For IPhone4 is no need to turn off as normally=>-press and hold on/off+sleep/wake button to turn off,until see an automatic operation-slide across the red slider-hold two button above to turn on...* Don't be alarmed that it takes quite a while to load from the Apple logo to the main screen .Nokia/Touchscreen with keyboard/N97,N97 mini,...=>Press and hold button shift/left+space+backspace,including power button and follow in struction...Nokia Touchscreen nonkeyborad/5800,5530,5230,5233,5802,X6,C6...=>Press and hold green+red+camera shot button,including power on/off until boot up./was try on Nokia 5800 and 5530,no problem....* for N8 =>press volume down+camera+menu,including power button...Nokia nontouchscreen/N70,N71,N80,N95,N96,N82,N95,E52,E71E71x,E72,6300,5320,5220,5130,6120,6303,6500,6730,8800....../S60=>Press and hold green,*,3 button,including power on/off button.../was tried on Nokia N81 and,no problem,work very well.* For Nokia,if the operation require code,the default code is 12345.* S80 press and hold Ctrl+shift+F* S40 is not available hard reset by button.can do by type *#7370#,and available for S60 too.BlackBerry=>Press and hold Alt+Shift/right+Del,then follow the instruction...SonyErisson/Touchscreen with keyboard=>Press and hold right + left soft key,including press power button.../was try on X1i,no problem...SonyErisson/Nontouchscreen: Not available hard reset by button...need the future research.You should know that Hard reset is the last solution,if none solved ur mobile problem.Note: all above just a part and not 100% correct.No guarentee for data lose or any demage.Do by your own risk-kindly do not edit this document.... :)Research and Prepare by YEKCHHUNHOUR.Inform me if you see any wrong instructions,to improve this doc better and confiding.Via Email: Chhunhour.kh@hotmail.com27/12/2010 VOTE FOR ME PLZ..........
on Dec 31, 2010 | Lands Phones
My phone says I have a pin # to get in , but I did not set one, how to fix it?
Your only option here is to hard reset the device. There is no bypassing this. Keep in mind, this may trigger the Google security lock, where you will need to know the original Gmail login and password you used when you setup the phone.
How to Hard Reset the LG L34C
  1. Turn off the phone completely.
  2. Press and hold the Power button and the Volume Down Key.
  3. When you see the LG logo release the Power key, but keep pressing and holding the Volume down button until the factory data reset screen appears.
  4. Once you see the reset screen release all of the keys.
Feb 15, 2015 | Andrews 4.0" Touchscreen Cell Phone GSM,...
I forgot 4 digit password ... plz tell me how i unlock my LG T375
You can perform a hard reset.
if you perform a hard reset,all user applications and user data will be deleted
please remember to back up any important data before performing a hard reset
1.turn the phone off
2.press and hold volume down + power + lock key at the same time
3.release the keys when the factory hard reset screen appears
4.read the warning and press the power/lock key to confirm.press any other to cancel
5.press the power/lock key to confirm once more or press any other to cancel
6.your device will perform a hard reset
Now, it will be just like brand new phone, except any software OS updates you may have installed during your use.
Nov 10, 2014 | LG T375 Cookie Smart Touchscreen Unlocked...
How do i reset my samsung model sch-s738c if i don't have my pattern password?
Because there is a pattern pw set up on the phone you will have to do a hard reset. Unfortunately a hard reset will erase all downloads, uploaded programs or any cool stuff that was added to the phone; so in essence you will be wiping it clean...like a brand new phone.
If you're still with me, please follow these steps:
    1. Turn off the device
    2. Remove the battery for about 10 seconds, remove sim card and sd card then reinsert all the battery being last.
    3. Press and hold Volume Up button and Power Button simultaneously till the screen turns up and Samsung logo blinks for two times.
    4. Then release the power key but keep the Volume Up key pressed till you see Android system recovery screen.
    5. select wipe data / factory reset using Volume Down key to highlight.
    6. Press home key.
    7. select reboot system now
    8. Press home key.
Sep 16, 2014 | Samsung Galaxy Centura SCH-S738C...
I NEED TO KNOW HOW TO UNLOCK MY VOICE MAIL CODE, CAN'T REMEMBER IT,CHOCOLATE LG TOUCHSCREEN?
Reset the Voice Mail Password from the Wireless Device
  1. Press *611 then press SEND (airtime is free).
  2. Listen to the instructions then when prompted, press 3.
  3. Listen to the instructions then when prompted say 'Reset voicemail password' or press 5.
  4. If prompted, enter the requested information for security verification.
  5. Follow the prompts to reset the password.
OR
  1. Call (800) 922-0204 (toll free) from any phone to reach the easy-to-use automated customer service menu.
Reset the Voice Mail Password Online
note.gif This method requires logging into My Verizon. To establish a profile, refer to Register for My Verizon.
  1. Navigate: My Verizon > My Device >
  2. Create New Password
  3. Confirm New Password
  4. Click Submit.
Reset the Voice Mail Password for a Prepay Number
  1. Press *611.
  2. Press SEND (airtime free) to reach a service center.
Apr 30, 2014 | LG BL40 Chocolate Black Label Series...
Touchscreen not working
Reset your device by following steps the issues would get fixed.
1.Power off the phone.
2.Press and hold Vol+ key and Power key simultaneously until several blue sentences appear on the screen which are reboot system now; apply update from sdcard; wipe data/factory reset; wipe cache partition.
3.Use Vol+ key and Vol- key to move the cursor to "wipe data/factory reset" and press camera key to confirm it.
4.There are many words "No" and one sentence "Yes -- delete all user data". Use Vol+ key and Vol- key to move the cursor to "Yes -- delete all user data". Press camera key to confim it.
5.The phone will finish the reseting by itselft after about 10 seconds later and then the cursor will be on "reboot system now" and press camera key to confirm it. The phone will reboot automatically.There is no unlock and password any more after the phone is on.
Dec 21, 2012 | ZTE Warp
ZTE Z990 when hard reset it says failure. package corrupt. How to fix?
The solution of your ZTE hard reset problem:
http://www.hard-reset.com/zte/
Jul 15, 2012 | ZTE Avail-Z990 Avail At&t Unlocked Android...
My phone isnt picking up the sense to touchscreen, everyone in my family has tried to unlock my phone but the touchscreen doesnt pick up a sense, and its just frozen it will power off and turn back on...
A friend of mine had this same problem with an LG Ally. Eventually he had to remove the battery from the phone and replace it before the screen would respond. Some other things to try if that doesn't work:
  • Remove any screen protector you may have put on the phone. It is rare, but sometimes these can interfere with touchscreens of certain types
  • Reset the phone to the factory defaults (steps below):
  1. Turn the power off.
  2. Press and hold: Home Key + Power Key + Up or Down Volume Key.
  3. Turn the power on, while keeping the three keys pressed.
  4. When the LG logo is shown, release the keys.
  • Failing the above, I would return the phone to the retailer from which it was purchased. It's possible that the touchscreen is simply flawed.
Mar 07, 2011 | LG Ally Cell Phone
LG Venice Boost Mobile Logo
53 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
