Question about Crate Music
I have a Crate g120 cxl guitar amp. it is switching between channels on it's own. (no footswitch)
Tore it down for visual inspection only. I have limited skills in this area. but it can't be rocket science if ya ask the right guy... right?
  • 28 Answers
Hello Jamie.
Your right, it is not rocket science, this is way bigger and funnier!
Now, that you took apart the chasis fron the cabinet, you may try testing if the channel switching occurs when you hit the Printed Circuit board with some tool like the handle of a screwdriver. you can try with light hits and different places of the PCB while watching what happens in the front panel light. also you can try bending the PCB with your hand to see what happens, if the switching occurs, maybe you have a cracked solder on the pedal jack or in any component related to the switching circuit, in this case, you will have to pull out the pcb, and re-solder those points that can be cracked. Using a magnifiying glass is very helpful in looking for those cracked solders.
Good luck and best wishes.
Posted on Nov 26, 2014
  • jamie
    jamie Dec 10, 2014
    nope. both boards are in fine shape. not sure what the answer is? i found a used footswitch, now the thing works as it should... and iv'e heard the same from others that own crate's. gremlin in the circuitry for sure. a guy could get rich figuiring this one out.....seems many amps are getting tossed to the wayside from this cancer....
Need the cables for crate flex ave footswitch
The easiest way would be to contact Crate customer service, or Guitar Center, or Musician's Friend, or Ebay.Here are the links-
http://www.crateamps.com/support/index.php
Guitar Center Music Instruments Accessories and Equipment
Musician Friend Musical Instruments Store
eBayeBay
Jul 02, 2016 | Crate Music
Crate three button foot swich how do you connect it to the amp
The Fender Hot Rod Deluxe shows a 2-button footswitch as standard but I'm confused. This link shows it as connected to the amp via a mono cable ... FENDER Hot Rod Deluxe DeVille Footswitch which is impossible using two switches. Normally it's a stereo (tip, ring, sleeve) with tip to sleeve being one connection, and ring to sleeve the other. Good luck with this one.
Apr 22, 2014 | Fender Hot Rod Deluxe Guitar Combo...
Effects don't work
On some amps there needs to be a footswitch inserted in the control jack to activate the effects circuit. Contact Crate to see if that's the case with your amp.
Jan 28, 2014 | Crate CA30DG Taos Acoustic Guitar Amp, 30...
Got a Crate VTX 15 guitar amp, and wondering if I can use a footswitch with it?
sure, why not, the footswitch connects between the guitar and the amp, with your guitar into the footswitch, go rock that thing!
Mar 10, 2013 | Music
Crate flexwave 120 head effects malfunctioning
That is probably a momentary switch that is dirty and sticking. These onboard effects on guitar amps are usually nothing more than a computer sound card and I've found bad connections going to and from them as well. I do think that switch is dirty and sticking, though.
Feb 19, 2013 | Crate FlexWave FW120H Guitar Amp Head with...
Changing channels by it self
Is this happening only with the foot switch plugged in? A bad cable on the footswitch is the most likely cause but there could also be a problem within the footswitch jack on the amp.
Aug 16, 2012 | Behringer Bugera 333212 120W 3 Channel...
My 100hdfx has a problem switching channels. Both overdrive channels work fine but the clean channel is none existant. If you switch it to the clean channel and turn it up all the way you can faintly here...
have you tried the footswitch to change channels. also. my amp has to be in channel 2 position (with the button on the head) before i can use the footswitch. sometimes the input/footswitch jack wears out and you need to bend the internal tip/ring tabs of the jack to make better contact. also like on my fender amp, i had just a standard mono instrument cable going to my footswitch and it was acting wierd cause it needed a stereo instrument cable. one last thing on the grounding resistors on the pcb, they get hot and break the solder welds which messes with all sorts of stuff in amps. usually look like sugar cubes , cement resistor. 5watt usually under 1k ohm. check for bad solder welds on the pcb where the big resistors are and the switches/buttons and at the footswitch. there may be a bad ic or transistor for the channel swithing
Dec 30, 2009 | Marshall MG100HDFX 100-Watt Amplifier Head
Fender Hor Rod deville footswitch
If the footswitch is not switching correctly, open it up and check for any shorts or a defective switch. Sounds like it's a problem with the switch.
Aug 14, 2009 | Fender Hot Rod Deluxe Guitar Combo...
Music Logo
Top Crate Music Experts
Michial Gueffroy
Ben Armstrong
richie46
Are you a Crate Music Expert? Answer questions, earn points and help others
