Question about Hamat 3-3141PC Country Classic Bar Faucet with Lever Handle Polished Chrome...
How does one eliminate an annoying, loud noise that comes from the faucet shown below. We replaced the cylinder to no avail.
    New Friend:
A disturbed water flow causes such sounds. Since the sound propagates through the entire plumbing? The problem may be hard to pinpoint but is generally located at a valve or an endpoint.
Check that all valves are opened completely
Try removing one of the faucets and letting the water flow freely
If you can not repair - descaling or replacement.
Posted on Nov 21, 2014
    New Friend:
The culprit is probably air suction between cold and hot conduits inside the tap mechanism due to faulty seals or chipped seal bays. You could install no return valves on incoming cold and hot water supply pipes or change the mechanism. I had a Hamat technician recently changing a mechanism in a leaking Everest tap only to start noise problem. On a second visit they replaced again the mechanism to an older and better version which has two separate seals. The new mechanism has a single seal that covers both conduits and apparently doesn't seal well and cause noises both in tap and pipes when in half open position.
Posted on Jan 29, 2015
  • 3 Answers
If the noise is coming from the pipes, try closing the valves just a little, one at a time, while the faucet is on.
Posted on Jan 28, 2015
Chirping noise coming from a newly installed Single handle glacier Bay kitchen faucet. What is causing this annoying noise?
If it's constant, I don't know. Sorry. If it's intermittent, then it may be air in the line(s). If the latter is the case, turn on all your faucets for a while, flush all toilets and see what happens. . .
Aug 08, 2017 | Plumbing
When Faucet is turned on I get a loud noise. If I use the Sprayer the noise goes away.
Sounds like water hammer. Air in the pipes. Lower volume of water out of the sprayer isn't enough to initiate the hammer. Try shutting the water off to the house and draining the pipes.
Open the offending faucet and turn the water back on this should eliminate the air in the pipes.
Dec 08, 2014 | Plumbing
Why is there a loud noise when turning on my newly installed kohler bathroom faucets
It could be that your angle stops under the sink are not all the way open or need to be replaced
Sep 05, 2014 | Plumbing
Loud pressure noises coming from my geyser when i turn my hot tap on
That's a restriction of pressure someplace. It's not a geyser either, that's known as a faucet. Check to see the shut off valves below the faucet are fully opened
Nov 18, 2013 | Plumbing
A screaming noise seems to be coming from the metal cylinder (capacitor ?)above the pump on the right side of the dishwasher. Makes noise only when the pump is on.
Welcome to FixYa
Based on your description, "A screaming noise seems to be coming from the metal cylinder (capacitor ?)above the pump on the right side of the dishwasher. Makes noise only when the pump is on" It is likely the carbon impeller seal inside the pump assembly you`re hearing.
It looks like this...
It is located in that area, but inside the pump housing. It is a well known issue with the B/S/H/ dishwashers ( Bosch, Thermador, Gaggenau, Siemens ) and a service bulletin was issued to authorized techs. some years back.
It can be remedied in one of two methods, complete pump/motor assembly shown below, or just the impeller kit shown above.
The part number to replace it for the complete assy is # 442548 or the kit # 167085.
Both are available at several on-line depots such as "searspartsdirect.com" "repairclinic.com" to name a couple.
If you`d like to email me at my live account macmarkus@live.ca I can send you a complete service file on how to repair it with part numbers, procedure etc.
Thank you for choosing FixYa. Please keep me posted on your progress or if you need further assistance.
Good luck.
Regards,
Macmarkus :)
Sep 29, 2010 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Hotpoint refrigerator model # CTF16GKC.. a loud annoying buzzing noise recently started coming from below the fridge. What is this and what can be done to ELIMINATE it?
You could have a piece of paper hitting the condensor motor fan blade. Pull the machine out from the wall, unplug it and remove the fiber or metal panel at the back, bottom of the fridge. The fan will be on the right side. Check if for any debris that might be hitting the fan blades.
Mar 03, 2010 | Refrigerators
The kitchen sink makes a loud popping noise
Try removing the aerator on the faucet. If that resolves the popping sound, try replacing it with one that allows for a higher flow of water. (Also the existing aerator may be clogged).
Jan 05, 2010 | Moen 87555C Trianna Single Handle Pulldown...
SHARP,PIERCING, ALARM LIKE NOISE COMING FROM TV
unhhok all the sources from the tv as to eliminate where it might be coming from, hook up one source at a time you might find the problem that way
Oct 20, 2006 | Olevia LT32HVM 32 in. LCD Television
Hamat 3-3141PC Country Classic Bar Faucet with Lever Handle Polished Chrome... Logo
98 people viewed this question
Top Hamat Plumbing Experts
Colin Stickland
Colin Stickland
ray gallant
Daryl Gleaton
Are you a Hamat Plumbing Expert? Answer questions, earn points and help others
