Hi do you know how to hard reset PM-0510-BV - Office Equipment & Supplies
    Sergeant:
  • 320 Answers
From the home screen, press Menu - Backup and reset - Factory data reset - Reset phone. It may ask for a password. Then select Erase everything
if you can not access this area you can proceed with the following.
This will remove all data from your device and set it back to factory defaults.
While the phone is turned off, press and hold the Volume Up and Volume Down buttons together. Then, while holding these, press and release the Power button (keep holding the volume buttons). The phone should turn on and a menu will appear. Press the Volume down button to navigate to the Recovery option. Press the Volume Up to select (if that doesn't work, use the Power button to select). A yellow triangle and an Android logo will appear. Press the Volume Down and Volume Up button together and a recovery menu should appear. Use the Volume buttons to move to the Wipe data/Factory reset option and then press Power to select. Again, use the Volume Down key to choose Yes and press the Power button again to select
Your phone will restart and may take several minutes to come back up.
Posted on Nov 21, 2014
Samsung gt s5222 dead what i have to do plz tel me
http://www.google.co.uk/url?sa=t&rct=j&q=&esrc=s&source=web&cd=13&cad=rja&uact=8&ved=0CF8QFjAM&url=http%3A%2F%2Fwww.hard-reset.com%2Fsamsung-s5222-star-3-hard-reset.html&ei=wOuKVO-iIdD7apKYgqAD&usg=AFQjCNH_PTbz4PDWLqNGrdjeE5ic9e0lzA&bvm=bv.81828268,d.d2s
Dec 12, 2014 | Samsung Cell Phones
What does error code C-0510 mean?
C0510 Upper fusing roller abnormally low temp
replace the thermistor in the fuser
Sep 08, 2014 | Konica Minolta Bizhub 8031 Copier
Unlock pettarn
Please read all of the following before doing anything!!!
Switch on the phone from standby, so that you get the phone unlock screen up. Select 'emergency call' to get the number/keypad open.
type *#*#7378423#*#* ...your phone will go into service mode.
Select 'customization settings' and then reset.
Your unlock pattern will be reset, **note** all custom settings will also be lost! So only use as a last resort.
Mar 19, 2014 | Sony Ericsson XPERIA X10 Cell Phone
The machine has the error code c0500. I need to know how to reset the error
Code C-0510 means a low fuser temperature. Most probable cause for that - the fuser lamp is probably defective. Try first to clear the error code (if the lamp is close to its life's end the code may pop up after a long print) so do this: power machine off; turn on the machine with the stop key held down; turn off, then on again. If this doesn't fix it then you need a new fuser
Thank you for contacting FixYa
*Please rate this solution with Thumbs Up
Nov 30, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
Pm reset
F7-03, have a service technician clear/reset the PM count. NO reset button
Sep 03, 2009 | Panasonic Workio DP-2000P Copier
Advanced hybrid system panasonic kx-t7730
how do i change my voice message on my answering machine??
Oct 29, 2007 | Panasonic KX-T7730 Corded Phone
224 people viewed this question
jasbo
jasbo
