My nokia phone has a picture or headphones and when someone calls or i call some one they cant hear me. I have tried everything to fix this please help
I have Nokia 6101 phone also. Incoming callers cannot hear me. There is a picture of headset on the phone. I have tried for ages to get rid of this. Has anyone else had this problem?I have Nokia 6101 phone also. Incoming callers cannot hear me. There is a picture of headset on the phone. I have tried for ages to get rid of this. Has anyone else had this problem?
You can't post conmments that contain an email address.
The problem with your phone
is that the earpiece on your
phone is bad that is why you cannot hear the party calling you or hear
anything while you call.
All you need to do is to replace the
earpiece on your phone and you will see that you can hear whoever you
are talking to on your phone.
Change the earpiece on your phone
and you will see that the problem is solved. meanwhile, you can keep
using the headset pending the time you will replace the earpiece.
The problem could be due to some contact error in the headphone jack of ur phone. Please re insert the headphone and remove it. Now try making a call with the speaker volume put to maximum. Dont forget to rate the solution. Thank You..
Not certain... but you need to check menu - tools - settings - general - enhancement and make sure your default is set to "headset".
When you plug headphones only (not the headset/mic combo) into the 2.5mm jack, it will go into a headphone mode where you can hear through the headphones but you must speak through the phone microphone - it sounds like it is going into that mode on you. It can only be the setting above or possible a short in the jack (though that doesn't really explain why it is happening only when you receive a call).
If you have 2.5mm headsets (or can pick up a small 3.5 to 2.5 adapter), you can also try having them call you and see if you can hear through the headphones - that would prove it is going into headphone only mode.
This just happen to me 45 seconds ago what you do is put the phone on the charger and make a call to your self or voice mail and then you unplug the charger and hit your speaker or try and hit your speaker button while its on charger then unplug one or the other. this is what i did to fix this problem
may be u should try to showing to any nokia care...these r not adjustable prob's within us,may b the pcb inside has got an loose contact to it..don check urself..since these costly phones will have complex to complex issues..
if it helps den plz plz plz rate me.. ne othr probs am there for u alwyss.. cya..
hi.
reset your phone settings to default and adjust for headset connection
try to connect the headset to another phone and check if the mic is good
good luck
