Question about Air Tools & Compressors
My DEWALT DC 618 angled finish nail gun won't fire When switch is moved from single fire to sequential fire the yellow light just stays lit Without trigger depressed
    Sergeant:
  • 206 Answers
Could be one of several things - first, check the contact element (part that touches the wood) make sure it is not bent & moves up and down with the linkage freely.
These are also very sensitive to volt/amps - if your battery is not up to par you can also have malfunctions like this.
Last, open the front metal cover (3 screws) and inspect to see if the return bands are in place and not broken. These are located at the top on either side of the driver blade. This is the most common repair on this tool.
Let me know if this helps.
Posted on Nov 25, 2014
  • 3 Answers
SOURCE: I purchased a new FN16250K-2 finish nailer today. I loaded it w/
get a senco
Posted on Mar 11, 2009
  • 25 Answers
SOURCE: nail gun double fires
There is one main part that can be the cause of the problem.
The trigger. Check to see if there is anything out of the ordinary with this. There should be some moving components attached to the trigger itself. Is any part of the trigger touching the button in the body of the gun when safety is not depressed. If the lever on the trigger is pushing on the button, even a little bit, It will allow the gun to fire again and again.
Posted on Apr 19, 2009
airnailer
  • 109 Answers
SOURCE: dewalt angled finish nailer, just got, when nose
if air is released when the trigger is pulled then stops when the trigger is released , then the trigger is doing its job. its probably a firing valve issue. four screws will take off the top cap of the gun the firing valve is inside of the cap . first check to see if the gun has enough oil( unless its an oil less gun) if its dry then grease or oil all of the orings, if this dose not work check to see if any of the orings or plastic parts need replacing. pls rate this answer...;tks
Posted on Feb 16, 2010
kirkx
  • 2019 Answers
SOURCE: Paslode finish nailer. Pull trigger
Try the other order, where you depress the gun first, and then pull the trigger.
Posted on Mar 12, 2011
  • 1388 Answers
SOURCE: Dewalt D51822 nail gun does not fire nail. When
There are 4 orings that cause this problem. Two are in the trigger valve installed on the firing pin. The firing pin can be seen just under the trigger, however if you replaced the valve, you could assume no problems with the trigger valve. I would take apart the old trigger valve and examine the orings on the pin. The pin should fit snugly in the trigger valve cap and also in the valve. If the orings look good and it does fit snugly, most likely valve is still good. The other two orings to suspect are installed on the cylinder inside the nailer and make contact with the bulkhead (white plastic piece that seals the cylinder note parts reference 55, 74, 11 on the parts list). For parts list and to order parts go to www.toolpartsdirect.com Good luck with your repair.
Posted on May 27, 2011
Dewalt d51276 fires multiple times with a single pull of the sequential trigger
Trigger valve most likely problem. You could also just replace the two orings on the trigger stem within the triger valve. They are very small (2mm). There are two or three other orings inside the gun that need to be replaced as well. The yellow vinyl orings used by dewalt do not last as long as the black rubber.
Oct 23, 2013 | Makita Brad Nailer Finish Nailer...
Dc618 brad gun wont fire on bump
The link below is where you can download the owners manual. The link is on that page near the top right hand side under the area marked downloads. Page 5 will show you were the switch is located that switches the tool from sequential fire to bump fire.
DeWalt DC618 parts and operations manuals
Jul 07, 2012 | Dewalt DC618KA Angled Nailer Kit
Looking for a dewalt1276 manual for a 34 degree 15ga nail gun
There are a couple of videos at youtube
Look for: dewalt d51276 nail gun instructions
Mar 19, 2012 | Dewalt 1 - 1/4 - 2 - 1/2" 15 - GAUGE 34...
The pin on my Dewalt dc616 cordless finish nail gun is ceasing up. How can i lubricate it? can i spray silicon into the nose of the gun?
Hello, W/D here.
The better way is to disconnect the air line from the gun, and place several drops of light oil in the gun while holding the trigger down. Oil daily. Then, re-connect the hose, and fire a few nails into scrap wood.
Another trick is to spray your nails with WD-40 before you load them into the gun.
Best regards, --W/D--
Feb 09, 2011 | Dewalt DC616 16g Cordless 18v Straight...
Need nails
Do a search on Google or Yahoo to find sellors and prices.
Mar 23, 2009 | Dewalt 1 - 1/4 - 2 - 1/2" 15 - GAUGE 34...
Dewalt dc618 nailer is not firing
I have both the DC616 and 618 and have used them sucessfully for about three years. Two main things go wrong. There is a drive belt that breaks (drives the spool that give the energy to drive in the nails), second are two small rubber bands on either side of the drive head that break. The bands can be accessed by taking off the front silver cover, the drive belt is access by spliting the case. Make sure you are using the correct nails or the drive pin may become bent and will jamb repeatedly. Hope that helps!
Nov 18, 2008 | Dewalt DC616kn 18 - volt 16 - gauge...
Dewalt nail gun
if ur nail gun is DC608 it on recall. if it other model it could be the return assy or the pc board.
Sep 10, 2008 | Dewalt DW715 Heavy Duty 12" Single -...
Air Tools & Compressors Logo
113 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
