How do i get an onn electronics android plug to
How do i get an onn electronics android plug to hdmi adapter to work? It came with no instructions and i have tried multiple phones and hdmi cables. Plz help....
  • 88 Answers
Connect one end of the HDMI Lead to the adapter. Connect other end to the HDMI on the TV. Connect the adapter to the charger with the usb socket on adapter and connect the adapter to your mobile . Make sure you plug it in to an electric soocket or it wont work . I have one myself for the Samsung Galaxy S3 and mine works just fine . But you have to get the right adapter for your phone
Posted on Nov 21, 2014
5 Suggested Answers
SOURCE: Sony Bravia television hdmi stopped working
Installing a new software update will this issue. All you need is a compatible USB flash drive. Go to support on Sony.com. Look up your tv model and if there is an update, just follow the instructions to install it yourself. I have a KDL-46S5100 and this worked great. The download and instructions page I used was : http://esupport.sony.com/US/perl/swu-download.pl?upd_id=4769#install
Posted on Oct 10, 2009
SOURCE: My Philips 42PFL3603D/27 that does not connect to hdmi device.
At the rear or side of the PC there should be either or both of a 15 Pin DIN Plug, HDMI socket. or a Yellow RCA or 4 -7 pin DIN. Now IF these are present then YES you can connect to a TV. Now some TV's have a connector a DB15 MALE, so that the cable from the PC to the TV, is DB15. this plugs in directly, with appropriate DB15 cable. This, however, will ONLY take the VIDEO to the TV, Audio is delivered via the "Audio Out" Jack on PC, and Plugged into the AV Sockets on the TV, with a dual cored coaxial cable, they are Red & White. Some PC's also have a Yellow RCA Connector, OR a 4 -7 Pin DIN Socket, that requires a Special Adapter Cable (That generally came with the unit, and are colored and marked as to output) to use, for Video/Audio Out to TV. This signal is Composite or SVHS Video & Stereo Out. This connects up TO the TV's Composite/SVHS input Jacks and the Red & White Audio IN, RCA Jacks, &/or DIN SVHS socket.
First you need to know if your PC can output to a TV. Then you need to get the adapter & cables that connect the PC to the TV. Then you need the correct TV drivers installed for your video card. When they are all installed, you need to "Enable" that Monitors, the TV's, Desktop. You need to set either a "Cloned" display or "Spanned, Extended Desktop". Go to "Display Settings" Now ensure the TV/Monitor connected has the correct input/output display settings. Adjust the screens resolution via the resoloution "Slider", it is best to start with, 800x600 32 bit color. or even lower. and once working OK, THEN increase to max resolution, your TV can handle, find out from manual. Once it is all connected up. It should all just work great. Now, from then on, &, to get it to work every-time, the process is. Turn everything OFF. Connect the leads between PC & TV, Turn the TV, ON. Then, startup the PC up. It should "Detect" that it has TWO "Monitors" ie: One Monitor & One TV/Monitor, & you should see your desktop appear after a bit. Now you have screen 1 & screens 2. Now, if you are using "Cloned" mode, then whatever is displayed on the Master monitor, will be displayed on the TV. If you used Spanned, mode, in this mode, however, you will have to."Drag" the Video window, over to the TV, and it is though, you have one "Big Desktop". Now IF using Nvidia or ATI then BOTH of those have thier OWN, Control Panel, this, all then can make it all a lot easier to do it. So I would suggest that this method be used. But if you get stuck, or just want to do it by hand, then the the "By Hand" method is the only way.There is a great program called MultiMon, this allows great control over dual displays, and is well worth installing.
Posted on Mar 10, 2010
Testimonial: "While my problem did not get solved, he helped me as much as he could. Thanks!"
budmrtn
  • 11361 Answers
SOURCE: LD4088 LCD will not play sound via HDMI cables.
This is how AUDIO works in HDMI setup, you can select the source to send the digital audio along with the digital video through HDMI, the receiving end HDMI sound setup must be set to receive the digital audio through HDMI. Otherwise the audio may be sent and received through analog audio ports (Red (Right channel) and White (Left channel) RCA jacks) in stead. Most of the new TV and DVD player use auto detection.
So please check the HDMI audio setup to see how the audio signals are set to be processed.
Please leave rating if it helps.
Posted on Jan 14, 2011
  • 8457 Answers
SOURCE: I have a sony blue
Tries tv unplug,replug it back like about an hour later.Than tries go into the tv menu do a resetting to factory setting in every settings on the tv.Than reconnect the Blu Ray player again should work.If not the tv and Blu Ray player softwares main firmware just not compatibles.The only solution is just don't used it on this tv,because if u tries to upgrade the tv firmware or the Blu Ray firmware and u get the wrong upgradable version in the tv or Blu Ray player.That it u in deep ****,than the tv or Blu Ray player well not functions at all or have multiple orperational problems during it playing times.
Posted on Jun 18, 2011
How to hook up android box to smart tv
You need to go to Radio Shack or Look up online; but buy a Auvio USB/HDMI PC to TV adapter and an HDMI cable at 6 to 12 feet long. Hook it up following the instructions in the kit or watch the video on youtube.com to hook it up. You can hook up your phone or computer using this adapter. Have fun watching your videos then.
May 24, 2017 | Televison & Video
Lg stylo will not work with slimport or mhl cable
LG G3 Help with the Best MHL Adapter... - Android Forums at ...
forums.androidcentral.com > LG Android Phones > LG G3
Sep 14, 2014 - 11 posts - ‎6 authors
I got this one Slimport™ to HDMI® Adapter - Black - Monoprice.com. ... Again, the LGG3 will not work with a MHL adapter, regardless of what ... Is there a way to get 'll g g stylo to Screen mirror or cast ...
Aug 17, 2015
HDMI to TV connection isue
May 15, 2014
Is A Special App. Or Setting Needed to use a Slimport ...
Oct 30, 2013
Anyone Using An MHL Cable With Ther Optimus g?
Nov 19, 2012
More results from forums.androidcentral.com
SlimPort to HDMI Video Adapter Review for LG G4 G3 G2 ...
? 1:27
https://www.youtube.com/watch?v=dy_ra3_A_JA
Sep 28, 2014 - Uploaded by EEEKit
Oct 30, 2015 | LG Televison & Video
How do I watch movies on my tv from my Android smart phone ?
theres a couple of ways to do this. you can get a cable from phone to TV ( check your make of phone for right cable ) or you can do it wirelessly via a hdmi adapter ....an example of the adapter is
http://www.worldtvpc.com/blog/how-to-wirelessly-stream-media-from-pc-phone-and-tablet-to-the-big-screen-tv/
May 06, 2015 | Android Cell Phones
What is the website address for ONN electronics?
onn electronics is a generic brand for walmart shops
I typed in onn electronics on the net and there are pages but the walmart has the agencies for the onn products
talk with the tech guys in walmart for the item you requie.
Apr 23, 2015 | Audio Players & Recorders
Will an onn bluetooth keyboard pair with i pad 2 air?
You shoud have bluetooth enables in setting. If it is enabled, it should pair.
iT SHOULD WORK. If you can't pair, presume bluetooth of your keyboard is defective.
Mar 22, 2015 | Onn Wireless black keyboard with slim line...
How do I hook up my phone to tv
What type of phone?
IPhone? To do that with an IPhone you will need airplay and apple TV.
second solution is to buy an HDMI cable adapter for IPhone APPLe component AV cable.
Samsung Android? To do that you will need an All Share Cast Wirelles Hub.
Second solution an MHL adapter cable.
Dec 05, 2014 | Televison & Video
Suddenly lost Laptop to Mitsubishi 60c9 connection using HDMI
never plug in hdmi when comp.is on you may burn your hdmi port
Aug 03, 2012 | Mitsubishi WD-60C9 60" DLP HDTV
I HAVE A ONN HDMI DVD PLAYER WITH DIVX. (SW2411A-DIVX.) I RUN IT ON A SCART LEAD AT THE MOMENT, BUT I HAVE TRIED TO USE IT THROUGH HDMI CONNECTOR. IT JUST GIVES ME 'NO SIGNAL' ALERT. IT IS A NEW CABLE....
I got the solution, you must plug your ONN DVD PLAYER With an S-Video Cable and then, press set-up key and configure the output as HD (High Definition of course) and ready to fly, unplug the svideo and enjoyit....
Mar 03, 2010 | 1996 Dodge Caravan
Televison & Video Logo
135 people viewed this question
Top Televison & Video Experts
Electro Med Services...
