Question about Garden
<!-- from fixya rte -->How much oil do I put transmission? - Garden
  • Eugene Rounds Nov 21, 2014
    Hi Steve Nedrow, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    What transmission? No equipment numbers at all makes impossible to answer.
    New Friend:
  • 26 Answers
Do you have a hydrostatic tranny, if so it is a sealed unit,
your manual will show you if it is a older unit and it is up to the fill hole on the side of tranny,
Posted on Nov 21, 2014
What do you do if the transmission locks up after use of Lucas engine oil leak?
Did you put ENGINE oil leak in the transmission? That's probably why the transmission locked up. If you put it in the engine, it had nothing to do with your transmission locking up. In either case, your vehicle needs to be diagnosed by a reputable, qualified transmission shop.
Apr 25, 2017 | Cars & Trucks
I have a 2005 Hyundai Santa Fe and I accidently put motor oil in the A/T oil spot. What should I do?
Don't run the engine at all. If it was started, the transmission pump will have pumped the motor oil all through the transmission-go have it professionally flushed. If the engine was not started, drop the transmission pan to drain the fluid, and get a new transmission filter. Put it back together and run the engine until the transmission fluid gets hot. Then change the fluid and filter again. After this, monitor the transmission fluid dipstick. If any traces of more motor oil in the pink fluid, do the drain and change filter a third time. (buy a case of transmission fluid-each drain and change will take about 6 quarts.)
Aug 18, 2013 | Cars & Trucks
How do I top-up the transmition oil in my 1988 Mitsubishi Lancer. I can locate the dip-stick, but not the location for topping up the oil. Regards Ian
Use a funnel and put in the transmission oil through the transmission dipstick tube. Don't put too much. Insert transmission oil in increments just to be sure.
Jan 12, 2011 | 1988 Mitsubishi Mirage
I need a step by step (for dummies) procedure to change the manual transmission fluid in my 96 Tacoma 4cyl?
First Look under transmission for a drain plug like a Bolt size Then Open your Hood Check On the side for Oil gauge... From that Oil Gauge after draining your old Oil ...Put Back Your Bolt ..Then Find a little Funnel to put our new Oil throw that Oil Gauge.. Transmission Oil For Manual Transmission Only From Canadian Tire ...Good Luck
Oct 09, 2010 | 1997 Toyota Tacoma
What weight oil goes in transmission on a 1999 harley davidson road king with 88 cubic inch motor
Mostly all motorcycles use the same oil in their Engins and transmission, you do not needs to put a seperate oil into the transmission, as the engin and transmission uses the same oil, you will also see that there is nowhere that you can top up the transmission oil, most motorcycles use 20W50 oils, but it can also depend on what country you are from
Aug 29, 2010 | 2000 Harley Davidson FLHRCI Road King...
Were do i put transmission fluid in the tranny 1997 cadi catera
Your Catera has a sealed for life transmission so therefore on one of these models there is no dipstick and you cannot check the fluid level yourself. The dealer can check the level but that is only necessary if you have a leak. Use a premium grade oil and a quality filter such as AC/Delco, Wix, Purolator, or Bosch. The correct weight oil is listed in your owner's manual and possibly on the oil fill cap or dipstick.
May 29, 2010 | 1997 Cadillac Catera
How do you know if you haven't got enough transmission oil in the motor?
dont put transmission oil in the motor! transmission oil goes in the transmission.. isnt there a dipstick?
Dec 12, 2009 | 2001 KTM SX 125
I did a transmission oil change, how do i put oil back inside the transmission
I haven't changed the fluid in a Catera, but all the auto trans cars I have, it's added through the dip stick tube.
Apr 29, 2009 | 2000 Cadillac Catera
PUT ABOUT HALF OLD OIL I HAD STORED IN TRANNY CONTAINER IN TRANNY
Improper fluids in a automatic transmission can cause severe results.
Drain the transmission fluid and change the filter.
If the car was running at the time you put engine oil in the transmission, I would also flush or drain the torque converter.
Replace with the proper amount and type of fluid.
Apr 21, 2009 | 1993 Ford Crown Victoria
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
