Question about Saeco Talea Touch Plus Automatic Espresso Machine - With Touch Screen
Why do my coffee machine displays restart to solve the problem
Cleaned brew group and restart the machine
SOURCE: Water leakage- V'spresso machine
I had the same problem. The water was coming from the front door switch inside top right. I followed the water and turns out the part that needed to be replaced was the steam valve body. #48. http://www.shop.partsguru.com/images/1208344975339-771025787.jpeg and link http://www.shop.partsguru.com/images/1208344975339-771025787.jpeg after I changed it the pool of water under the machine stopped. I hope this helps.
Posted on Mar 10, 2009
  • 1089 Answers
SOURCE: need to take out brew group jammed
Hi
Look on the left side where the box should be. In the left side towards the botton there is a long opening. Take plastic knife and slide it in while the machine is on and blinking and see if the brew unit will cycle. The drip tray has to be in for this to work. There is a metal bar that has to be pushed toward the rear of the machine to cycle the brew unit.
Posted on May 22, 2009
EsWorld
  • 1618 Answers
SOURCE: Saeco talea touch - grinds & brews coffee into grounds drawer??
Try this, adjust the grind to a coarser setting atleast 2 numbers, then remove brew unit and look behind at white plastic valve, there is a small chamber under valve make sure chamber is clean and that the small discharge from chamber to drain tray is also clear. Then remove shower screen from brew unit and clean if necessary, also check the tube from the shower. Reinsert and test.
Posted on Jul 02, 2009
  • 55 Answers
SOURCE: Lights for descale and grounds drawer flashing red
Have you ventilated the machine . turn to hot water and see if can get water out .
Posted on Dec 18, 2009
  • 81 Answers
SOURCE: The alarm light to empty the coffe grounds drawer
Hi, the problem with your machine is with the grinder motor (not working).As soon as you press the coffee the CPU senses the motor is out of circuit and the lights start flashing alternately.
You can test it by doing this. Press and hold the steam button and switch on the machine, you will see the lights going around in anticlockwise direction. Release the button then turn the dial to left (Min) and press the steam button the grinder should work. The dial on the right (Max) the brew group will come up..and half way it will come back to normal position. Press the coffee button in that position will work the pump. Servicecenter can fix this if the machine is less than 2 year old FOC.
Posted on Oct 11, 2010
What do I need to do when error 8 is displayed on turning on machine?
Jura does not allow access to internal parts for cleaning. Brew group is the dirtiest part as it deals with complicated movements to make coffee.
Error 8 means the brew group is not returning to start position after it completes entire cycle to make coffee.
Jura recommends to remove drip tray. Using a thin cloth, insert the hand all the way under the machine. You will feel access to the bottom of the brew group. Wipe clean the bottom of brew group as best as you can. There will be lot of coffee powder (wet & dry) that is partially responsible to prevent brew group return to start position.
A better method is to open the machine using special key. Clean & lubricate the brew group. every two months. This will prevent Fungus and Bacteria growth. .
Instruction videos are posted on You tube channel "Parts Guru USA"
Use the link below to order the special key. Services Unlimited Inc Parts Guru Since 1988 Services Unlimited Inc Parts Guru Since 1988
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edward_bbd2c7ff4ee1828a
Mar 20, 2016 | Jura Capresso Impressa S9 Coffee...
I have a jura capresso impressa f7 machine and when I cleaned it (using cleaning tablet) it made some strange sounds and the screen reads "Fault 8" - I removed the tray and cannot re-insert it as the...
Check to see if there is a lever that may need pushed in as you put the tray bad in...not sure as many of the machines are different...but it's worth a try! :)
Jul 30, 2014 | Jura Capresso Impressa F7 Espresso Machine
Not all coffee dispenses from BrewGroup: Last week almost nothing was being dispensed and coffee was detouring to grounds box. I cleaned the brew group-- removed and cleaned the spigot (including the...
I believe based on symptoms you described, that it is most likely just a good descaling cleaning it needs, try using CLR, OR some vinegar and water, run this through machine a few times, you can even use denture cleaner. I don't think it is your pump based on your symptoms.
Jun 13, 2011 | Saeco Vienna De Luxe Espresso Machine
The brew group is stuck and will not come out
I hope one of this two solutions solve your problem.
1- The brew group is out of place. Turn the machine on. Close the service door.
The brew group is automatically placed in the correct position.
2-Coffee grounds drawer is inserted. Remove the dregdrawer first, then the brew
group.
Jan 15, 2011 | Saeco Odea Giro Plus Coffee Maker
Is my "brew group" broken.
Remove the brew unit, under the white plastic valve you will notice a small chamber that might be filled with coffee grounds and water. Clean chamber.
Dec 01, 2009 | Saeco Vienna De Luxe Espresso Machine
Jul 02, 2009 | Saeco Talea Touch 14-Cup Coffee Maker
Not making espreso all the time
Being that you just started using it I would not be concerned. You did the correct thing by cleaning the brew group. Check on your screen under total coffees. We usually recommend you change the brew group every 10,000 cups.
Make sure you descale the machine and you can try using the cafiza tablets to clean your brew groups internal passages.
Brew Group: http://cerinicoffee.com/Saeco_brew_group_Magic_royal_916006715.asp
Cleaning instructions: http://cerinicoffee.com/clean_descale_coffee_equipment_instructions.asp
Nov 19, 2007 | Saeco Royal Exclusive 30153 Espresso...
Saeco Talea Touch Plus Automatic Espresso Machine - With Touch Screen Logo
49 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
