I install ncx xtenda 2000 xp but shows message - internal error! What will be the proble?
  • 11,800 Answers
Internal error means that there are conflicting applets running in the program. These can be caused by corruption or bad settings.
Uninstall every guest OS and reset everything to default. If you have just installed it then you either chose a bad option during install or the installer is corrupted - redownload it.
Posted on Nov 24, 2014
Stations stopped it says internal error .NCX-2000-xp
1. display message as updating service
2. while updating service error display already registered yr serial number
Jul 14, 2011 | NComputing X300 3 User Expansion Kit...
Recently i have a problem with NCX 2000-xp consol i have 4 desktop one one system one the main pc is working but other three screen show internal error what can i do to solve this problem
Where is the 'internal error' showing up, in the NComputing console, or on the Station screens? My recommendation is to uninstall the vSpace software, reboot, run thier cleanup utility, and reinstall the latest version. Before reinstalling, make SURE that you have applied XP SP3 and ALL of the current MS updates. Additionally, browse Device Manager and make sure there are NO missing or conflicting drivers. Lastly, if Intel Active Management Technology is installed, disable it. This will be listed in the ports section of Device Manager as either IAMT or SOL/COM3. Do NOT, I repeat, do NOT install from the provided CD. As of this posting date, the cleanup utility is available here: nc-eng.com/tools/ncuninstall. The most up to date vSapce for X300 on XP is at: ncomputing.com/download/x300.zip. If you hit this post later and the supplied URLs are not valid call NComputing TS at 888-365-1210.
Jun 30, 2011 | NComputing X300 3 User Expansion Kit...
I installed succesfully but when i update xtenda that i shawn to error and xtenda is not completely updated and i shawn my xtenda actiovation license is expired . so that the main problem is guest pc...
My recommendation is to uninstall the vSpace software, reboot, run their cleanup utility, and reinstall the latest version. Before reinstalling, make SURE that you have applied XP SP3 and ALL of the current MS updates. Additionally, browse Device Manager and make sure there are NO missing or conflicting drivers. Lastly, if Intel Active Management Technology is installed, disable it. This will be listed in the ports section of Device Manager as either IAMT or SOL/COM3. Do NOT, I repeat, do NOT install from the provided CD. As of this posting date, the cleanup utility is available here: nc-eng.com/tools/ncuninstall. The most up to date vSapce for X300 on XP is at: ncomputing.com/download/x300.zip. If you hit this post later and the supplied URLs are not valid call NComputing TS at 888-365-1210. Lastly do NOT forget to register the vSpace software and related XD1 boxes. Pay CLOSE attention to my comments about the Intel Active Management Technology, I think that is your biggest suspect but I'd recommend you follow all the steps I listed.
Apr 26, 2011 | NComputing X300 3 User Expansion Kit...
NComputing vSpace not installed my pc Error
Options:
(A)
An authorization error usually occurs when more than one system in a LAN has the same software serial numbers assigned to the system. In this case, the first PC to be turned on does not suffer an authorization error, but any subsequent PC's which contain the same serial number will experience the issue.
To remove these duplicate serial numbers, first unregister them, then delete them from the host PC they are installed on:
  1. Access the NConsole application by either:
    • Click "Start" > "All Programs" > "NCX-2000-XP" > click on the entry labeled "NCX - 2000 - XP"
    • Double-click the NComputing console application icon in the system tray
  2. In the left-hand pane, navigate to "Local Settings" > "Information and Settings" > "Serial Numbers"
  3. To unregister a serial number, right-click on the number and select "Unregister now"
  4. To remove serials, right-click on the number and select "Delete"
Also, an update that does not install correctly may rarely cause corruption of the data file in which serial number information is contained, causing this error. If there are no other X-series hosts on the network with duplicate serials, then a complete uninstall and reinstall of the X-series software may fix this issue. When uninstalling, choose to unregister all serials and remove all serial registration data.
To download the latest version of our software, please search the knowledge base using "software download" as the search text, for links to the latest software.
(B)
When more than one X300 station is used under the same login (same Username on two or more stations), Active Desktop error messages may occur. Also stations would be sharing same user settings and other files, which could cause unpredictable errors.
Different stations should always be used with different usernames logged in. To add more User accounts (usernames), go to Windows Control Panel, select Users and then go to Create New User option.
Mar 10, 2011 | NComputing X300 3 User Expansion Kit...
How to remote desktop xtenda ncx-2000-xp
A handy little app is Logmein, the free edition is available here
Nov 03, 2010 | NComputing X300 3 User Expansion Kit...
I wanna the cd of x300 Xtenda multibox because I need the driver and cd for the installation
I would recommend NOT using the CD. Uninstall any current version of vSpace. Reboot. Makesure you have no missing or conflicting device drivers inside of devicemanager. Then run the NComputing cleanup utility located here:www.nc-eng.com/tools/ncuninstall.exe. Download current version for XP(v4.03.104.1) from here: www.ncomputing.com/download/x300. Unpack the.ZIP file and install. Reboot and register.Do NOT, I repeat, do NOTinstall from the provided CD and upgrade. Simply install straightfrom the download file I provided in the link. Lastly make SURE you REGISTER the CARD and the XD1 boxes.
Sep 29, 2010 | NComputing X300 3 User Expansion Kit...
"Opps Error"
That's Problem known as internet virus.
u do one thing format ur computer.
And install one program that's software name is adware
after that u do not have a sing le proble related to server & ataachments .
Reagrads.
Pradeep
Feb 26, 2009 | Yahoo Mail
Philips SpeechMike Executive V3.2 wont run in Vista
I had trouble initially with the same error message as deedee 222 8 and cannot give exact instructions. Try intalling old version, uninstall and then install upgrade 390 from Philips web site. I had to restart 3 times to get rid of an error messge on boot up but then it worked!
Jun 01, 2008 | Computers & Internet
Open Questions:
We provide best team support to all Toshiba users active for 24*7 hrs. Call us +1888784-9316 With 24x7 major subsidiaries and affiliates worldwide, Toshiba Corporation is known as a world class innovator and global high technology product leader worldwide. Toshibha launched laptop computers from its kitty way back in 1985 and by Financial Year 2010 they have managed cumulative shipment of more than 100 million Laptops. Toshiba has been known to set benchmarks when it comes to quality and features that results in exceptionally high performance. In spite of the exceptional features you may experience issues related to data recovery, backup and security and may be deprived of any support by the Toshiba Support. In the event of an OS Crash there is always a chance that you may Toshiba Support your critical data. Virus attack or accidental data deletion are also some of the other reasons that could cause mess. An updated backup will warrant that you do not lose your critical data forever. DataAlign comes to you rescue in these situations. DataAlign offers comprehensive technical assistance for your computer's data backup, recovery and security. DataAlign lets you schedule backups to execute daily, weekly or monthly. Our award winning cloud backup Toshiba Customer Service lets you schedule your backups continuously throughout the day. Data Align gives you affordable services that saves you both time and money and that lets you take control of other important things in life like growing your business or spending time with near ones. TOSHIBA is known for its diversified product range and services worldwide. Still, there are several issues that a TOSHIBA user can face on the TOSHIBA computer. Problems faced by TOSHIBA customers BIOS update Toshiba Backup Slow Performance Windows 10 upgrade Data Backup and Transfer Office and outlook setup Wifi and Internet Issues Audio & Video Issues Startup and Boot problems Windows updates Computer Tune-up Issues Virus Removal Issues Our highly talented and expert IT Team can help you fix most of the issues that you face with Toshiba Virus . And the best thing is that we can help you get your data backed up on our secure cloud storage. Why Our Toshiba Help Desk Number Technical Support Team Are Best? With several years of experience in our kitty working with a wide variety of customer group, we have gained an edge when it comes to providing technical support for TOSHIBA Computers. To add to it, our expert technicians trained specifically on TOSHIBA computers are always ready to help you best possible solution for any issue that you may face with your TOSHIBA product. 24X7 availability and assistance for your TOSHIBA computer. We have a dedicated & experienced support team to handle issues for your TOSHIBA computer We ensure little to no downtime with maximum uptime and highest productivity for your TOSHIBA Computer. We ensure Data backup and retrieval assistance We ensure end to end ownership & solution for issues you face with your TOSHIBA computer. Quick and efficient support over the remote. You can sit back & relax while one of our techs fix the issue for you. All these issues and many more, concerning Toshiba users are directly and efficiently resolved by our technically knowledgeable team who can be Reached 24/7 on our Toshiba Contact +1 888 784-9316.
Apr 27, 2018 | Toshiba Computers & Internet
Computers & Internet Logo
228 people viewed this question
David Payne
David Payne
