Question about Bosch B26FT70SNS VitaFresh Refrigerator Display Model
How do you replace a water tank on a bosch refrigerator model B26FT70SNS
2 Suggested Answers
SOURCE: How can I replace the tube of the water dispenser of a Bosch refrigerator?
If you haven't yet removed the old one. Use a small piece of duct tape, by small I mean don't wrap it around the tubes too many times, if you do it will jam inside, one or 2 turns max). Place the end of the new tube close to the end of the old one, tape them together, overlapping at least 1 inch on either side. Then while slowly pulling out the old one guide and push in the new one at the same time, until the old one is replaced by the new, pull them both out then remove tape and reconnect to spout. Carefully consider the procedure so you know if it should be pulled out through the top or bottom of the door. You may also need to cut the spout part off the old one, if its non removal. You may also need to remove the lower hinge to make it easier to get in it.
Posted on Feb 08, 2015
Condensation on the fridge
The veggie draw should be able to control the moisture with the sliding lever on it.
Do you leave your food uncovered while it gets to room temperature? if not that may be your problem sealing it before it does.
Oct 26, 2015 | Bosch B26FT70SNS VitaFresh Refrigerator...
Why doesn't the water inlet valve shut off completely?
http://www.repairclinic.com/PartDetail/b129p3/Bosch-Freezer-Water-Inlet-Valve/00649626/2000566?modelNumber=B26FT70SNS%2f04&ss=a3b129d1144601&mr=1
Sep 15, 2015 | Bosch B26FT70SNS
How to reset a filter display on a bosch refrigerator
from our bosch manual: press and hold the light/filter button for 3 seconds. the water symbol is reset. the symbol stops flashing. the new filter cartridge is activated.
Apr 16, 2014 | Bosch B26FT70SNS
Water tank leaks
Turn the water off, find the leak and the model number of your refrigerator. Use the model number to search for a replacement water tank or water coil depending on what your model uses. If the water control valve does not leak you can turn the water back on until the water tank is replaced if the wires going to the water dispenser are disconnected. Just prepare for some water to spill once you begin removal of the water tank. This will allow ice to be made without causing water to pour out onto your floor while you wait for parts. It is really important to have the model number because without it the parts department will not be able to find one without it and internet parts view is not possible without the model number found around the fresh food section door frame. Have you located where the leak is? Is it something other that the water tank causing the leaking water?
There are many types of GE Monograms and different part numbers for different models. Can you post the model; number here on Fixya? Let me know if I can help you and I will be glad to give you the part number. Or click here and enter your model number=> Point and Click Appliance Repair I'm here if you need me, Thanks Sea Breeze
Sep 02, 2013 | GE Monogram Side by Side Refrigerator
Bosch tas 1000
What model and brand are you talking about?
What does the tank do?
Is this water heater?
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Gene
Jul 31, 2013 | Water Heaters
The thermal cutout pops on tank two after it shuts off. It boils then shuts off. It also turns off when taking a shower, producing cold water. I checked the ohm readings on the thermal cutout and the...
Question posted under Bosch tankless.
Question says 'tank'
Brand, model, and type heater unknown.
Elements mean electric.
'Thermal cutout pops when taking shower produces cold water' indicates tankless, since tank-type would maintain some hot water.
No error code might indicate tank-type.
Add a comment with type, brand and model number of heater for possible assistance.
Sep 24, 2012 | Bosch PowerStar AE125 AE125 Whole House...
My new Bosch B26FT70SNS fridege which i got delivery yesterday morning compressor motor won't turn off. Since yesterday afternoon around 5pm until now 11am. More than 18 hours continue running, the...
HI JAMES.ummmm new bosh...should work.if not and motor running cont.then it sound to me like is out of refrigerant or motor faulty.check condenser unit.should hot.if cold call under warranty or replacement i would say.good luck Ali
Jun 30, 2012 | Refrigerators
Ariston GL6+ Occasional rusty water. Can this be remedied? Thank you Ed
Ariston GL6 6-gallon electric water heater has anode rod to prevent steel tank from rusting.
Once anode rod depletes, the tank rusts.
All tank-type water heaters have replaceable anode rod that can stop rusting, but will not repair damaged tank.
Open following links for resources + manual with parts number and illustration on page 7 and 10. Part number is shown as 570241 anode rod.
http://waterheatertimer.org/pdf/Bosch-GL_English.pdf
http://waterheatertimer.org/Replace-anode-rod.html
Jul 12, 2011 | Bosch Ariston GL6-plus GL6+ Point-of-Use...
How to unlock the screen?
Hold down the freezer up button and fresh food button down
Mar 08, 2011 | Bosch B26FT70SNS
Formation of ice in freezer compartment
Here is a tip that will tell you where the water is coming from and how to fix it. The drain hole has froze shut and the water from the defrost will not drain out.
Water Running in Refrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Sep 05, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
Bosch B26FT70SNS VitaFresh Refrigerator Display Model Logo
97 people viewed this question
Top Bosch Refrigerators Experts
Charles T Nevin
Charles T Nevin
jasbo
jasbo
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
