Question about PIAA 2008 Chevy Uplander - All Uplander models - Xtreme White Bulbs
Why does my heat only work when I accelerate? When I slow down it cools,no heat blows.
    Sergeant:
  • 244 Answers
The coolant level might be low/
Posted on Nov 21, 2014
Driving a good distance car makes a whamming sound the more Itry to accelerate the speed decreases whinning louder only stops whinning when I pull over to let the car cool down
Have your wheel bearings checked, when a wheel bearing is going bad it hums louder as you accelerate, when you stop or slow down the sound stops. A bad bearing does that, it over heats due to it not having enough grease on the bearing and will hum as you drive and get louder as you accelerate.
Jun 07, 2015 | 2011 Dodge Caliber Mainstreet
Ac not cooling
its need to clean a/c components some other caused by a/c filter
Sep 06, 2013 | 2009 Toyota Corolla 1.8
2006 dodge grand caravan heater only blows warm air when i am accelerating
With the engine cold check the coolant level. Add as necessary. If the coolant gets low enough the first thing to stop working is the heat. Accelerating will push coolant into the void and provide heat until you slow down and then the coolant drains back into the motor.
If you have lost enough coolant to loose heat there is a leak. Some common areas are the rear heater lines under the passenger side of the van, the water pump, and the radiator.
Dec 14, 2010 | Dodge Grand Caravan Cars & Trucks
My a/c will cool while i am going down the road but when i stop or slow down it blows hot air....i am not sure if this has anything to do with that but during the winter my heater did the same thing it...
check out first the fan for your AC under the hood close to the radiator. There should be one for the radiator and another for the condenser of the AC. It could either, the fan is not blowing or it has become weak. Check out the wiring if it may have caused it to not work.
If all check out OK, have your AC system checked out if you need more freon or of there are leaks. HAve the condesner checked out as it may not be cooling effectively.
Jun 18, 2009 | 2001 Dodge Stratus
Problem with front air switching to heat when accelerating
Check for a vacuum leak. WHERE is the magic question.
Mar 26, 2009 | 1999 Lincoln Navigator
Heater only blows heat when accelerating
I think you might want to start with thermostat replacement and pressure flush the system and as other suggestion check levels when car is COLD!!!!!!
Dec 22, 2008 | 2002 Chrysler Sebring
Slow speed, fan coming on loudly in Dell D800
Yeah the slowdown is the laptop throttling back due to overheating.
When you do processor-intensive work like - streaming videos - the laptop overheats. The fans come on loudly.
When the computer heats up despite the fans, the processor throttles back to relieve the heat.
When you reboot your machine, it stops performing intensive work, giving it a chance to cool down. It's not restarting that fixed the problem it's the fact that the laptop cooled down.
So here's what you do. Get an air duster and blow all the dust and gunk out from your fans. They are most likely clogged with dust and that's what's causing your cooling problems. If there are large dustballs in there, use a tweezers and pull them out. Get as much out as possible.
Dec 06, 2008 | Dell Latitude D800 Notebook
PIAA 2008 Chevy Uplander - All Uplander models - Xtreme White Bulbs Logo
94 people viewed this question
Top PIAA Optics Experts
Lawrence Oravetz
Vernon Taylor
Are you a PIAA Optic Expert? Answer questions, earn points and help others
