Question about HP Office Equipment & Supplies
Bad colors om hp 1415fn
After 2 yers and 1 month, the prints of fotos look like s.... Toner changed - no effect. What is wrong?
  • HP Master
  • 1,915 Answers
Can you clarify "looks like @#$" means. Is the color washed out, are there streaks, toner missing? Any chance you can scan one of your bad prints and post so I can see?
Posted on Nov 21, 2014
ctf1800
  • 4402 Answers
SOURCE: HP LaserJet 2430n occasionally prints goblety-gook
ISSUE: When printing from the computer, you receive a line of garbage or all of the printed output comes out on one line. SOLUTION: See the following:
  1. Perform a self-test to be sure that the HP LaserJet printer is functioning properly. If the self-test is not correct, remove all cables and accessories (if any) and print a self-test again. If the self-test is still not correct, service the printer. If the self-test is correct, go to the next step.
  2. Reseat or replace the cable. Check the cable for bends or pressure applied by objects resting on the cable. A faulty cable or cables that do not meet the IEEE-1284 Standard can cause print defects by distorting signals.
Posted on Jan 09, 2008
geekofcomp
  • 47 Answers
SOURCE: my hp deskjet 3520 printer
  1. check the ink cartridges
  2. make sure the color settings are right in the printer properties panel...it should havea way
  3. try, try again
hope this helps
Posted on Apr 10, 2008
  • 49 Answers
SOURCE: Just changed the black toner and now it won't print black.
Sometimes it may not be the toner that is the issue in this case the problem is with the black imaging unit, remove it and check for any damage and check the how life is left on it, if you have a spare then replace it!
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=49,E=0000000001347412543,K=9952,Sxi=0,Case=obj(4002)
copy and paste this directly into your address field!
Posted on Mar 31, 2009
  • 30 Answers
SOURCE: why my Fuji Xerox C525A color lazer printer print out not clear?
hi,clean corotron wires,drum unit & mirrors.send me result.
thank you.
Posted on Jun 08, 2009
Adi_Taticu
  • 71 Answers
SOURCE: hp 2605dn Black cartridge is printing 1/8" LEFT of other colors.
That problem is frequently on HP 2600 series.
You must try to change all remanufactured toner cartridges with HP OEM with no exception, the best alignment it is when you change the black cartridge and the printer make a cleaning page process. Cartridge HP OEM should be almoust empty. It Is not necesarry to be a new one. After the alignment process, you can put the remanufacturated cartridges back on.
This was work for me. 100%
Posted on Oct 06, 2009
My HP 5200 printer prints very light as if its cartridge is low while its toner is full, this problem was present from the very first day i purchased it, changed toner cartridge but no effect, (meaning no...
Try changing you Print Quality Settings.
1. Go to your Printers and Faxes(XP), Printers(Vista), Devices and Printers(Win7) 2. Right Click on Your Printer Icon 3. Click on Printing Preferences 4. On Print Quality, Choose Best. 5. Under Features -- Check the box for Print in Maximum DPI.
I hope this helped a little :)
Feb 04, 2011 | HP LaserJet 5200 Printer
Mottled effect on one face during duplex printing
that would b the fuser if it has build up on the rollers.. definitely change out the magenta toner and verify that the paper stock is within specs!
I’m happy to help further over the phone at https://www.6ya.com/expert/ron_9356d26241d4cbf7
Mar 31, 2010 | Canon LASER SHOT LBP-5100 Printer
Ghostly effect
If drum is a genuine Brother, then open the rear door and look at the fuser rollers, if you see toner or partial images on the rollers you need a new fuser, if the fuser is clean, look at the drum surface and if you see parts of last print then the drum is bad. In reports, print the user options list it will give the total print count. The fuser is worn out around 80 to 100,000 prints.
Jan 11, 2010 | Brother MFC-8460N All-In-One Printer
Sharp AR-C240P Printer Prints Everything with red cast
iF YOU HAVE NOT CHANGE THE DRUM TRY IT. FOR ANY COLOR THAT IS RUNNING OVER POWERING.
Jun 23, 2009 | Sharp AR-C240P Printer
Ghosting on prints
Wrong paper type can cause this, also if it is damp or too thick. Also check that you have the correct type of paper (thickness) selected in the driver. Ghosting can also be caused by a faulty drum unit, since you just replaced it maybe there is warranty left on it?.
May 24, 2009 | Brother HL 5140 Laser Printer
Printed pages look terrible...
I'm more familiar with HP printers, but it sounds like a fuser is bad. The fuser effects print quality as well. If you've replaced the toner, as you have.
Apr 24, 2009 | Sharp FO 5550 Plain Paper Laser Fax
Lexmark e250dn printer, toner light is flashing, new cartridge
Could be photoconductor at end of life.
You shoul still be able to do a printer test print (press the arrow button).
Look on the printed pagesfor Toner AND Photoconductor.
These show as OK when new or very low count, and 100% when fully used.
If the toner is showing as 100% when you've just replaced it, either the chip is faulty, the wrong one, or if the cartridge is a remanufactured one possibly nor been replaced.
Jan 19, 2009 | Lexmark E250dn Laser Printer
"DRUM LIFE OVER" KX-FL511
just change with new drum and toner.after replacing when msg gone just press start.u will receive ur faxes in memory.MIAN AKHLAQ
Dec 31, 2008 | Panasonic KX-FL511 Plain Paper Laser Fax
Does not print
the same, after 1 month no used. Total printed circa 100 prints.
Jan 26, 2008 | Samsung ML 2010 Laser Printer
mukhtar21 shaikh
mukhtar21 shaikh
