Question about Tools & Hardware - Others
Bostitch model T26 - piston will not return to top of cylinder. Have replaced all O rings. Piston remains at bottom of cylinder with much air escaping at exhaust. Any solutiions?
New O rings. Lots of black junk outside of cylinder like maybe something come apart, don't know what.
  • 1388 Answers
SOURCE: DA250B air nailer leaks air, piston stays down
Your nailer has a collar /vinyl seal that should be installed on the head valve and seats against the cylinder. The seal should fit very snugly on the headvalve. The plastic cylinder must not have any nicks on the surface or be out of round. The head valve has an upper bumper that needs to be inspected for cracks. To test the orings in the head for leaks do the following. Push in the headvalve with your thumb till it hits bottom then cover the small hole at the mating surface of the head with finger then release headvalve. Suction should hold the headvalve in for a moment. If no suction, replace the orings. Parts and item list are at WWW.toolpartsdirect.com . Enjoy
Posted on Dec 11, 2008
mickey813
  • 472 Answers
SOURCE: Instructins needed on piston ring replacement on air compressor
GO TO SEARSPARTSDIRECT ENTER THE MODEL NUMBER AND IT WILL SHOW IT ALL TO YA LET ME KNOW IF THIS HELPS YOU
Posted on Nov 19, 2009
SOURCE: ring burns up low compression
sounds like you are running to lean,whenever you alter your exhaust system you must rejet your carb. when you have jetted correctly your spark plug colour should be chocolate brown. white or gray is to lean black is to rich.Change your jet to a larger size,install new spark and take it on a short ride at full throttle stop and check plug colour. repeat this till plug colour is correct. hop this helps james
Posted on Mar 16, 2010
dontbother10
  • 2220 Answers
SOURCE: how do i remove piston pin from 375 poulan pro
ArboristSite Chainsaw thread (free to join)
http://www.arboristsite.com/forumdisplay.php?f=9
I suggest you look around the above site. Someone here has been where you are. You can join for free and they are a very helpful group of folk.
Posted on Apr 21, 2010
  • 1015 Answers
SOURCE: 55 rancher-put new after market piston,ring and
I had a very similar problem with a stihl 029 farm boss.I did everything you did except I took it to a shop to do the piston and ring replacement. When I got it back the first time it would run for about two mins. then die.I fought it for a couple of weeks then took it back and expressed my displeasure. Then checked it all over and replaced piston and ring again and it runs great. They told me they could not get the right compression with the first one and thought the groove for the ring was cut to deep.I hope this is of some help to you. Thank you.
Posted on Mar 21, 2011
Bostitch N62FN air leaks out the cap and it wont pressure up or fire. Is the piston ring solid
Glad that you repaired your gun. The piston oring is the only oring in the gun that can have slit and still work fine. It works like a piston ring in a motor. Small ring gap is ok just as long as the piston does not drop down the cylinder under its own weight. The piston oring does not hold pressure, it only reacts to pressure when headvalve opens. When this series of gun leaks air, it is usually due to headvalve orings (lube with white grease), Cylinder seal loose or broken, or trigger valve oring splits (tva6 valve). Good luck
Mar 29, 2013 | Stanley Piston Driver Assy Bostitch N62fn...
I just put a repair kit in my sx150 stapler and it fires put will not recoil i think im missing a spring in the bottom of the piston cylinder?
The Bostitch SX150 pneumatic brad nailer/stapler uses air to both drive the brad or staple and to return the driver/piston assembly to the top of the gun for the next firing. There is no spring that goes into the sleeve or under the piston. If your driver is not returning to the top of the gun you may have put an o-ring or seal in the wrong place or left one out. The o-rings and check seal on the bottom half of the driver sleeve are what control the air that returns the piston to the top so check those first.
May 26, 2012 | Stanley Air Tools & Compressors
SB 1842bn
When a firing pin won't return it's usually caused by damaged o-rings inside the gun. The most likely culprits are the o-rings around the outside of the cylinder or the rings on the drive piston. Another cause could be a cracked cylinder or bent driver. Remove the cap on top of the gun and check the condition of the o-rings, cylinder and driver. You'll have to order any parts that need to be replaced as Bostitch doesn't make a rebuild kit for this gun. Don't forget to lightly oil the o-rings with pnumatic gun oil when reassembling the gun. Most pin and finish nailers say they are oil-less but they still need a drop once in a while to keep the o-rings from being damaged.
Feb 14, 2012 | Stanley Bostitch HP118K 23 Gauge Headless...
I have a 2007 Bostitch sir compressor that will not buid pressure. I am able to repair my self, I just don't know what to replace or adjust. Any info will help. Its a model CAP6OP-OF. Thanks
Your compressor could have worn cylinder /ring, worn/ leaking/ or broken reed valves or just leaking at a joint (check for leaks first using soapy water). Oil-less compressors have a silicone /vinyl compression ring that wears out quite easily depending on conditions at the job site (dusty/ gritty etc). Remove cover and turn motor till the piston is at top of stroke. Look for scratches close to top of cylinder, if present, replace cylinder and compresson ring to restore full power. If cylinder is smooth, and ring looks ok from the bottom than loss of power could be reed valves. Remove head and examine reeds replacing as needed. Good luck
Dec 16, 2011 | Stanley NEW Bostitch 2 HP 6 Gallon...
I have a Stanley Bostitch Oil Free Air Compressor 6.0 Gal 2.0 Hp Peak, 1.5 Hp Running 135 Psi The problem is it won't blow out air or hold the air.. How can I fix this?
Some Bostitch compessors are very unique in that they intake air from below the piston. If you cannot find an air filter, then your compessor has reed valve built into the piston that may cause problems. If you have an air filter on the head of the pump, then you have reed valves in the head. When the reed valves fail, there will be very little or no air pressure. Second problem with all compressors is the in-tank check valve. This valve allows air to enter the tank and not back-out into the compressor. Easy to check. Add air into tank with another compressor thru the quick connect and listen for air leaking around the head or pressure switch. If no leaks and pressure holds in the tank then valve ok. Examine the condition of the cylinder and piston ring by rotating the crank by hand so that the piston is at top of cylinder. Look for scratches around upper part of cylinder wall. If scratches, then replace cylinder and piston ring. If top of cylinder looks good, then suspect reed valves. Good luck
Sep 12, 2011 | Stanley Bostitch 2hp 6gal Air Compressor...
My bostich1664FN was working fine,then it stopped shooting nails.How can I troubleshoot this problem. Thanks John
Here are some easy tests.
Assuming that the gun is firing normally however no nails are ejected. Remove the head of the gun and check if the piston is not returning to top of cylinder (piston needs to return to top for nail to enter into positon under the driver). Piston not returning to top indicates, bent driver or worn oring on piston. Repair /replace as needed. If driver/oring looks good, pull out the cylinder and look for check band in place around series of holes on lower part of cylinder and bumper should not be cracked. Lube all orings with silicone paste lube. Good luck
Sep 06, 2011 | Stanley Bostitch SB1664FN 16 Gauge...
N-80 vintage 1986 the striker does not return far enough to engage the next nail. If I turn the gun upside down and tap lightly on the head it will usually allow the striker to retract.There are no air...
you have lost compression on your piston o ring, instead of air pushing the piston back for the next nail its going around the piston , and the proof is that your piston will move with a simple tap. please replace all orings, because if one is worn the others arent far behind, if you dont replace all , at least replace the piston one and all the cylinder ones,,o rings kit are available at your nearest nail store or try toolpartsdirect.com plz rate this answer,,tks
Dec 11, 2009 | Stanley Bostitch N80s Nailer -rebuild...
Firing Pin doesn't return
The piston is returned to its firing position by air from the trigger valve after the piston has fired. It relys on the piston sealing against the bumper at the bottom of its stroke, if the bumper was damaged when the driver shattered or it was put in upside down the piston will not return. Also the piston uses air fed into the return chamber from the little holes in the cylinder, if the seal over these holes is damaged the piston may not return. Basically change the bumper and the check seal on the cylinder.
Jul 28, 2009 | Stanley Bostitch Coil Framing Nailer
BostitchCAP60-OF won't pressure up past 95lb and keeps running
This comperssor is oiless thus has a vinyl piston ring that wears quite fast depending on use and conditions at the work site. Slow pressure build or cycle never completes indicates a worn cylinder and piston ring. I would replace the cylinder, piston ring, valve plate, and intake valve. These parts are not expensive and available at www.bostitch.com. enjoy
Dec 01, 2008 | Stanley Factory Reconditioned Bostitch...
Air allways and continually leaks forcably from the top. Bostitch
This nailgun has several parts to the headvalve that must fit together properly to seal. Go to WWW.toolpartsdirect.com for a diagram of this tool. The part called the diaphragm is source of problem. It has thin vinyl walls that will fold over when you assemble. The piston will not cause the gun to leak, just make sure that piston fits snug into the cylinder. Loose oring on piston will only cause low power or the poston may not retract all the way back up. Some piston/drivers had a plastic ring instead of an oring. The plastic ring had a secondary oring under, however not necessary. You can use rubber or plastic, just make sure that the piston is not too tight or too loose. The piston oring is the only oring in the gun that can be cut to fit. It is like a piston in a car engine. The piston rings have a gap.
Nov 23, 2008 | Stanley Bostitch 18 Gauge Brad Nailer 1 -...
Tools & Hardware - Others Logo
231 people viewed this question
Top Tools & Hardware - Others Experts
john h
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
