Question about Kitchen Ranges
Can't find part I need to fix my oven?
Model no.#362.7351892 and serial no.# is: 2M205872P I've been told they hardly have it anymore and when I do find one it's $200 dollars or more and I can't do that......I will just get a different stove if it's that costly.
    Habit-Forming:
    New Friend:
  • 155 Answers
That's a SEARS Kenmore range, and yes, thermostats and some other parts can be costly. Check around the web using the part name or number maybe you can find cheaper.
Posted on Nov 25, 2014
ginko
  • 19396 Answers
SOURCE: The oven on my Whirlpool
You do not know if it is a lose connection, that is just an easy diagnosys from somebody that did not want to waste much time on the problem.
When Oven is not heating check:
Wirings and connections.
Heating element
Knob control.
You need to test parts and wiring with a multimeter.
Posted on Aug 31, 2008
  • 1214 Answers
SOURCE: Hello, Can't find model/serial number.
Serial number labels are usually located in any one of a number of places -
Under the cooktop in one of the corners
Inside the oven door frame (not on the door)
Behind the bottom drawer pullout on the oven, left hand side
Oven back.
If this unit is anything less than 20 years old, there will be a label somewhere.
Reply back you findings and I can give you more information as to how to repair, and we can identify part numbers. You might also try www.repairclinic.com and see if you can drill down through parts when only knowing the manufacturer.
Posted on Jan 30, 2009
  • 100 Answers
SOURCE: oven temp low. recalibrated up 35 degrees, 375
no you need to still recalibrate the unit if your using the baking style thermo they are famous for being off 75 degrees
Posted on Aug 09, 2009
  • 5128 Answers
SOURCE: Where is the serial number located on stove?
If it is labeled like the other VGIC stoves, the serial number is on the left hand side of the burner box (stovetop). Remove the left side surface burner grates, burner bowl and grate supports.
I hope this helps.
Posted on Jul 22, 2010
  • 555 Answers
SOURCE: My Frigidaire electric range (Ceramic cooktop)
According to your notes, I believe the Oven heating element is damaged and may need replacement.
After some years of use, the heating element may short circuit and/or break. If you have experience on electric repair, check the resistance of the heating element. If it is open, replacement is needed. If the heating element does have resistance (not zero) then possibly the relay or control board may be damaged. (I hope not, control board is quite expensive).
Good luck.
Posted on Dec 09, 2010
Oven wont turn on but top burners work
You will only need the make and model of the cooktop to order the ignitor. Open the bottom drawer below the oven to find the data plate with model & serial #'s on the front of the oven.
Apr 10, 2014 | Amana Cooktops
Bang oulfsen penter amp no power
you didn't leave much for details.. No Model number so I don't know if it's a car amp or a house amp... but I've found these very useful for solutions and support...
Service Manuals: http://beophile.com/?page_id=8253
Contact Company for support: http://beophile.com/?page_id=2202
Explain to them with full details and make / model & model number / serial number /
Only other idea is to probably buy a new one if these don't resolve your problem..
Mar 25, 2012 | Audio Players & Recorders
Please say someone has a solution for me, very worried i've most my life's collection of music and movies =[
Try the WD USB hard drive in another computer. If you can access your data on another computer then backup your data.
If the WD USB hard drive is faulty then -
It is not possible to recover data from faulty hard drivesby mortals such as you and I.
There are companies that can recover data from faulty and damaged hard drivesBUT they wll charge an arm and a leg for their services.
Feb 23, 2012 | Western Digital 1TB WD ELEMENTS USB...
I have a Whirlpool Electric Range GY399LXUS. The oven will not turn on. The top burners work, the only button that works on the keypad is the warm button.
I am an Appliance Technician...... and you need a new clock/ECM The part where the clock is & the oven controls... under there is a big circut board that is basicaly the motherboard for your oven. And I'm sorry to inform you that I just used your model number to look up the board and it is NO LONGER AVAILABLE.... that means they just don't make that part for your oven anymore. Whirlpool didn't use that design very long because they didn't sell well, they were expensive to produce, and they had a few too many problems out of em. So BAD NEWS is they don't make the part you need to fix your oven....GOOD NEWS is you get to go shopping for a Range!!! And BUY WHIRLPOOL!!!!!! DO NOT BUY LG,SAMSUNG, GE, FRIGIDAIRE, OR ELECTROLUX!!!!
Aug 05, 2011 | Ovens
On model mw8626w can i use it in my semi with a 1000 watt inverter?
Take a look at the oven's electric rating information. It should be on the label with the model and serial number, and it will tell you how many amps the oven needs. Power in watts is volts times amps, so a 1000-watt inverter is good for about 8 amps at 120 volts output. Some inverters also use a peak rating, meaning power than can be delivered for a short time. The continuous power may be less than that; you'll need to look at the inverter. As long as the power needed by the oven is within the inverter's ratings then you'll be able to use it. Otherwise you'll need to shop for one with more output power.
Jul 15, 2011 | Emerson MW8626W Microwave Oven
I have a gas magic chef wall oven that is a 1993 model. The knob that you turn to turn the oven on and set the temperature is getting very very hard to turn. I called one repairman and he said it is the...
Its quite an old appliance, try www.whitegoods.co.uk you will need the serial number and model number, to order the correct parts. Also ISOLATE THE APPLIANCE BEFORE DOING ANY WORK, lift up the knob for temp control some older models have a small screw under a plastic cap, others just pull off with careful leverage. Spray the rieostate with wd40, move back and forward several times when its wet, it should begin to ease, wait until the wd40 has evaporated, then try the switch. Thermostats come in various types for cookers depending on make and model, but it should be attainable.
Hope this helps you
John
May 31, 2011 | Ovens
Brought an Electrolux oven had it 2 yEARS AND NOW They say they don't make the part Oven just want bake repair man ordered part but they don't make part anymore
Hi, Welcome to FixYa. I have a hard time accepting that as well. Can you provide the model & serial number as well as disclosing the part in question ? I will then see what I can find through my resources. I'll reply asap once getting your info. Regards, Macmarkus :)
Sep 03, 2010 | Ovens
Error code E6 F2
We repair these control boards frequently. The E6 F2 error is very common for whirlpool ovens and almost always is caused by the control board. It can be repaired quickly and reliably. www.fixyourboard.com
Jul 07, 2009 | Ovens
Kitchen Ranges Logo
52 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
