Question about Bosch Dryers
Reset the high limit thermostat on Bosch dryer and will run for a while and then trip again. Do I need to replace thermostat or look at some other possible problem?
  • 47 Answers
Could be a defective thermostat but not the most usual problem. The most common and 1st place to look would be to make sure that the exhaust hose vented to the outside of the house is clear of any obstructions such as lint. If this is extra long or has allot of bends in it the dryer can over heat and the thermostat is just doing its job. Whatever you do, do not bypass the thermostat as you could create a fire hazard.
Posted on Nov 25, 2014
  • 3 Answers
SOURCE: Dryer shuts off after a few minutes
THE KENMORE DRYER I HAVE... IF REN IN THE COTTON CYCLE IT WILL RUN FOR 50 MINUTES AND SHUT OFF. ITS BOLWING HOT AIR AND THE OTHER CYCLES SEEM TO WORK FINE WITH OUT SHUTING DOWN SO ID APPRECIATE A TIP ON WHAT THIS PROBLEM COULD BE
Posted on Nov 02, 2008
TheMobilian
  • 8220 Answers
SOURCE: Kenmore 84152 /94152
probably the heater
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jan 15, 2009
huuum
  • 750 Answers
SOURCE: Maytag Neptune dryer overheating
Hello
Welcome to Fixya
My name is Huum,
Yes, I agree it is the high limit thermostat, or the motor is bad!
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Posted on Feb 03, 2009
  • 686 Answers
SOURCE: Does the Bosch Tumble Dryer WTA3003GB/01 have a trip reset button
YOUR DRYER HAS A FUSE AND NEEDS TO BE CHECKED. SEE IF IT IS LOCATED SOMEWHERE WHERE THE POWER CORD COMES IN AT. IT SHOULD BE CLOSE TO THE MAIN POWER COMING IN OR MAYBE EVEN IN THE CONTROL PANEL AREA.
Posted on Apr 10, 2009
Greg20
  • 149 Answers
SOURCE: Maytag Gas Dryer - Flame trips high limit Tstat
firstly..is venting blocked? disconnect venting and try it. if problem persists then replace hi limit. assuming what you just told me was correct.
Posted on Jun 11, 2009
Problem with LER3624EQ1 Dryer. I have replaced the high limit switch twice and the thermostat. The dryer will run with hot air for a few minutes and then back to cold air with a new high limit switch. I...
The first thing you need is a multimeter, get one at Walmart you don't need a expensive one and the an be used for a lot of things around the house, pull wires off heater turn meter to ohms check between frame of dryer and each terminal it should show nothing if you are showing anything on the meter get a new heater
Aug 13, 2017 | Dryers
Bosch dryer wont heat up
This may help. Notice that the high limit thermostat has a red button.
Bosch Dryer Doesn Heat
Aug 12, 2014 | Dryers
I have a dlg5932w dryer that will not heat. From reading posts, it sounds like I need to reset a safety thermostat switch. How do I find it so I can reset it.
Unplug the unit. Remove the top cover by unscrewing the 3 screws in the back and sliding the cover back and up. At the control board, disconnect all the wires from the board, remove the screws holding the panel and pop the panel off. Remove the front panel of the dryer. Down on the right bottom corner inside the dryer, look for the large round tube where there are 2 sets of wires connected around it. There are 2 high limit switches, one on top right and one on the bottom left. The high limit switch on the bottom left has the reset button in between the wires. Push it and you should hear a click. That will reset the switch. NOTE: this is only a temporary fix. The manufactures recommends replacing that switch if it should trip because it will trip again. Good luck
Jun 20, 2011 | LG DLG5932W Gas Dryer
BOSCH DRYER #WTL5400UC Thanks Gentlemen, All power is there, all lights are on, but..........hit the start button and nothing happens. Please Help
Welcome to FixYa.
Based on what I've read of your post...I'd suspect the hi-limit thermostat is tripped if it is indeed a WTL series Bosch.
I'm not clear as to whether or not you located the hi-limit safety, reset it, or ruled it out so I'm going to explain what to look for and what to do when you get there.
**Unplug the unit from the wall or switch off the breaker...safety first**
Once the dryer has been disconnected from any power, remove the rear panel...
i.e.
Once the panel has successfully been removed, you'll see the heater with the Hi-Limit and NTC attached. The Hi-limit is the thermostat with the red button in the center...
i.e.
push it in to reset it. As you can see by the images I've provided, if you have a multi-meter or ohm meter you can verify the proper values of the listed components.
If the hi-limit is tripped, obviously something triggered it, you can check the possible culprits such as the NTC's or heater with the info I provided above as I alluded to.
( Even so, I'd suggest running it through a cycle or two and monitor it's performance, it may have tripped simply due to poor air flow from a large load etc. and therefore nothing is actually wrong...human error )
You may run the dryer momentarily without the rear panel in place provided nothing electrical has been disconnected, don't attempt an entire cycle, just witness the heater functioning, but it isn't recommended for much longer than a minute or two.
Thank you for choosing FixYa and please let me know what you find out or if you indeed require further assistance. Good luck.
Regards,
Macmarkus :)
Mar 30, 2011 | Bosch Axxis WTL 5410 Electric Dryer
I have a thin twin stacking whirlpool washer/dryer. The high limit switch is kicking off the element within 2 mins of running. So heating element heats up red hot, then clicks off after 2 mins. I have...
I think you are on the right track with a faulty high limit switch. When i serviced these units we always replaced the operating thermostat and the high limit switch together they came in a kit. The operating thermostat in theory should never let it get hot enough to trip the high limit switch, which is really just a safety backup for the operating thermostat. Get the kit and replace both, and also make sure your exhaust vent going outside has good flow at the outside vent,a restricted vent system will cause similar issues.. Good Luck
Oct 07, 2010 | Whirlpool LTE6234D Top Load Stacked...
I have a Bosch Axxis WTA 3510 dryer. The dryers heating coil stopped working. While looking on line I was able to fix the problem by using the reset button at the top of the heating coil housing. The...
Hello- The first thing to check, if you haven't already, is how well the dryer is venting. Make sure there are the flexible duct from the dryer to the wall is not crushed or crimped in any way. As well, with the dryer running, go outside and locate where the dryer exits the wall and feel how much air is coming out. Is should be blowing strong out of the vent. If not, and if the ducting travels a long distance through the walls you may want to have a duct cleaning service out. If there is a lot of lint build-up in the vent then the dryer will have trouble evacuating the hot air and the unit can overheat causing the thermostat to trip. If all your venting is ok but the thermostat is still tripping then replace the thermostat. Hope this helps, best regards.
Sep 27, 2010 | Bosch Axxis WTA 3510 Electric Dryer
Dryer went off for overheating won't start again . Reset is ok next to the burner.no point to point diagram , sequence of operations , or component i.d. beautiful machine.........
HI, if this has occurred, the issue may be a faulty high limit thermostat or, the thermal fuse has been tripped, due to an obstructed ventilation system(exhaust assembly).
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
NOTE***
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
Jul 09, 2009 | Bosch Dryers
Dryer will run for says then trip off, not the
If it is in timed dry mode, the problem is in the timer, if it is on sensor dry then you may have a clogged line. Easy to check, disconnect vent from back of machine and run it, if it dries without a problem then you need to replace or thoroughly clean venting. If it still does the same thing, check your thermostats, like the cycling thermostat, that is what advances the timer in sensor dry mode. What do you mean by tripping off? Do you replace the high limit fuse to get it to work again or does it just shut down?
Jun 15, 2009 | Dryers
Dryers Logo
152 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
