Question about Hotpoint Dishwashers
Hi I have bought a hotpoint aquarius 11010 dishwasher and have removed all the packaging but a bit unsure if i have to remove the polystyrene from the back, it is inside the frame
    Sergeant:
  • 244 Answers
It might be sound insulation and it will be obviously glued to the unit and difficult to remove if that is the case.
Posted on Nov 21, 2014
SOURCE: Hotpoint Aquarius DWF50 Dishwasher, cycle
hotpoint dwf50 will not start, the fast wash and prewash buttons are flashing together.
Posted on Sep 25, 2008
grandadfixer
  • 99 Answers
SOURCE: Salt tray full of water
Just pour a bag of dishwasher salt in water will come out.Then light goes out.
Posted on Oct 12, 2008
SOURCE: dwf50 hotpoint aquarius dishwasher
hi, just found this forum after searching the web 4 a solution to my hotpoint DWF50 problem.
I came down this morning to a machine which base tray was full of water and lights 3 ECO & 4 Fast flashing.
Anyway my solution was as i had seen a hotpoint engineer do once before was to press the start/reset button trip the catch, to fool the machine into thinking the door is closed then put in a program, press start, the machine hums slightly but doesnt do anything then after removing the large filter from the tray at the bottom underneath the lower basket insert a length of wire, with a loop on the end (Tip i used a wire coat hanger from the dry cleaners) poke in ythe hole that the dirty water drains from, after a bit of poking about the pump started working and the water drained away. Tip place a hook at the other end of your wire impliment to put your finger in to stop the wire getting caught in the pump mechanisim. After wards u have to hook back the door catch to the normal position, Tip another piece of the coat hanger with a right angled piece at the end will do this. This worked for me, saved me some money esp as D & G insurance ran out 2 weeks ago.....stu
Posted on Jun 22, 2009
SOURCE: Hotpoint Aquarius Dishwasher DWF31
MY DISHWASHER TASTES OF SALT AFTER EVERY WASH .I HAVE RINSED IT THREW AND IT STILL THE SAME
Posted on Jan 12, 2010
SOURCE: Hotpoint Aquarius SDW60 Dishwasher
i have had this dishwasher sdw60 for 18 months and it just keeps beeping, i have cleaned it ,turned it off at the mains it just dont wont to work. please help.
Posted on Feb 08, 2010
Do I remove the polystyrene from the back of the dishwasher?
After the Polish workmen half installed my dishwasher, I noticed that the sides flapped about.
My partner has her own Ariston dishwasher. It had to be taken out to redo the work of the Polish Heating Engineer.
I noticed that it had a polystyrene piece running across the back of the machine. There was a sign on it saying - "Do not remove". The Polish workmen who had installed my machine had removed it.
Apr 14, 2014 | Hotpoint-Ariston SDL510P Dishwasher
Aquarius DWF32 and dealing with water softner
Good idea to check levels yourself, but wear rubber gloves as dishwasher salt will leave your hands very sore, simply remove cover from salt tank, using a wooden spoon handle or similar check salt level and refill if required, replace tank lid, never wait for warning lights, they may never come on, good luck.
Feb 18, 2013 | Hotpoint Aquarius Washing Machine Front...
Polystyrene door
Go to www.manualowl.com for free PDF and see if you can locate your owner's manual there. Then look up the Index in the PDF for Troubleshooting your issue. Hope this helps to end your very frustrating problem with your dishwaher. Best to you. Jimmy
Apr 11, 2012 | Hotpoint-Ariston FDF784K Dishwasher
Can't remove polysterene hotpoint diswasher
Go to www.manualowl.com for the free PDF of your owner's manual and then go to the Index of PDF for the troubleshooting section. Perhaps you can put an end to your vexxing problem with your dishwasher. Best of luck to you, Evelyne. Jimmy
Apr 11, 2012 | Hotpoint-Ariston FDF748P Dishwasher
Where is the element on a Hotpoint Aquarius dwf30 dishwasher?
It sits in the base of the machine and you would need to remove the complete top section of the dishwasher to gain access to it, which involves removing the door first, then the balance weight and finaly the stainless steel top section
Mar 17, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint Aquarius WF740 My washing is coming out with dirty marks and bits of slimy dirt. I wonder if it is from the door seal as this is dirty or could it be something else? I used the persil gel filled...
Your pipe to the water pump exit is probably blocked with bits of old fluff or missing sock, i found that the clothes had slimy bits on mine, i tilted it up and removed the rubber water exit pipe from under neath, cleaned out all the rubbish and works a treat now.
Oct 19, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Manual for Hotpoint Aquarius dishwasher - DWF 34
hi
you want
Hotpoint Aquarius dishwasher - DWF 34 manual no.dont wory go to how stuffworks.comyou can get all info you want.please rate it
Nov 21, 2008 | Hotpoint 24 in. HDA2000Z Built-in...
Hotpoint aquarius dwf30 dishwasher
you can plumb into hot but there are some snags
first hot water pressure is often a lot lower than cold so the machine may take a long time to fill
second if the water is too hot it will destroy the resin of the water softener and you will see brown marks on the crockery.
third it a bit uneconomical as you will use a lot of hot water
May 18, 2008 | Hotpoint 24 in. DWF32P Free-standing...
Hotpoint Aquarius DWF31
to isolate fault,remove bottom front panel,turn off main water,put a tray under machine, remove inlet pipe frompump at front of machine. for a second to see if you have flow that far. If so trouble is in machine. Dig the filter out of th pump entry .It could be blocked
Nov 04, 2007 | Hotpoint 24 in. DWF32P Free-standing...
Dishwashers Logo
418 people viewed this question
Top Hotpoint Dishwashers Experts
AcmeUK
Level 1 Expert
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
