Question about Whirlpool Refrigerators
How do i fix the problem
How do i replace defrost sensor in whirlpool refrgeataor?
    New Friend:
    Problem Solver:
  • 6 Answers
Go to YouTube and punch in the refrigerator and specifically that defrost sensor I believe there are some videos that will help you.
Posted on Nov 21, 2014
My freezer fan is making a lot of noise and seems to be due to ice build up in the fan casing and the blades and rubbing against the built-up ice, how can I fix that?
This is a problem with the defrost system get it sorted or you have a serious problem, first check the defrost sensor and then the defrost heater
May 20, 2017 | Whirlpool Refrigerators
My Whrilpool 3 Door Protton refrigerator was found cooling only freezer compartment, not refrigerated compartment. Local mechanic told that it is a defrost problem and replaced two bi-metal thermostat
this seems to be a major issue with whirlpool and kitchenaid multiple door refrigerators. The defrost timer device on the compressor does not function properly or fails and the cooling coils freeze up. Check the little fan that pulls air through the freezer coils to make sure it is running (that cools the refridg) if not running then it is bad and causing problem. Otherwise you have another bad defrost relay on the compressor. It's easy to change and cost about $25 at the parts store. I just defrost mine every six months or so since none of the ones I tried work very well. Its just a bad design that is still propagating in whirlpool devices.
Jan 06, 2015 | Refrigerators
How do i force defrost on this fredge
To check defrost you first need to have an evap coil temp below 32, the thing you replaced was prob the temp sensor for the defrost.
Find the def timer and turn it till it goes into def.
May 15, 2014 | Whirlpool GX5FHDXTS Stainless Steel
The automatic defrost cycle is running longer the normal. causing items to defrost in freezer. We have replace the sensor and timer
THE CONTACTOR STAY OPEN. THE DEFROST TIMER DEFECTED OR DO NOT ENGAGE. IF YOU HAVE POWER WHEN THE CONTAC CLOSE CROSS THE DEFROST TIMER . THE DEFROST TIMER NEED TO B REPLACE
Oct 24, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
My freezer is frosting up on the back wall and sometimes makes a clicking noise. It also takes about 4 hours to freeze the water in my ice cube trays. What is the problem and any suggestions how to fix it?
You could very well have a defrost issue at the evaporator coil. Every evap coil, which is located in freezer section, will eventually accumalate ice by virtue of moisture hitting a -5 degree coil. The point though is that 2 to 3 times a day the freezer should cycle into a 10 to 20 minute defrost. There are three components to the defrost cycle... the defrost control (which can either be a timer, or a circuit board), a defrost heater, and a defrost sensor. Some of the Whirlpools had defrost sensor problems that were built between 2000 and 2008.
In all honesty, unless you feel comfortable removing the back interior panel in the freezer, then I suggest calling a professional
Mar 03, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Icemaker not working
Try using an hairdryer or defrosting the unit completely , this often get rid of blockage caused by frozen lines fixing the problem.
The water lines can also be unblocked from dirt using a thin flexible shaft. This after defrosting.
If all that does not fix the problem, then you may need to replace the water valve, the icemaker solenoid, or the whole icemaker assembly.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Mar 21, 2009 | Whirlpool GD5SHAX Side by Side...
Whirlpool icemaker
Jan 23, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
WHIRLPOOL GD25DIXHWOO NOT COOLING
the defrost system may be hung up in defrost try locating and replacing the timer
http://www.whirlpool.com/custserv/index.jsp
Aug 01, 2008 | Whirlpool GS6NBEXR Side by Side...
Whirlpool ED25PWXAW01 Refrigerator warm/Freezer side freezing up
Are you able to find the defrost timer? If so manually advance it with a screwdriver or something similar, and see what happens. Let me know.
Dec 02, 2007 | Whirlpool ED0GTQXMQ Side by Side...
Refrigerators Logo
49 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
