Question about Euro-Pro Shark Sewing Machine
Where can i find a bobbin case for a shark euro pro model 71132L
    Problem Solver:
  • 16 Answers
Ellen did you try putting the name and model no in to a search? Also, try going on the Shark site and put in Euro Pro, etc. I have a EuroPro Crafter's Choice and sure enough I found what I was looking for. Try it. Hope that helps.
Posted on Nov 22, 2014
  • 106 Answers
SOURCE: Bobbin won't thread
Sounds like the bottom tension is to slack.
Look at the side of your bobbin case, when you thread the bobbin thread part of the route it runs is under a flat leaf spring. There is usually 2 very small scews on this leaf spring one screw holds the spring onto the casing and will be tight. The other is the tension adjuster screw, turn this screw clockwise half a turn at a time. After each half turn pull the bobbin thread until slight resistance is felt. Then try sewing if bunching/tangles still occur more tension is required, this is trial and error until the tension is corrert.
If you want a new manual try this website if your machine is not listed email them and they will try to help.
www.sewusa.com
Posted on Apr 03, 2008
geemarie
  • 876 Answers
SOURCE: I purchased a Euro-Pro Shark 998A but the B looks the same
Go to this address
http://www.euro-pro.com/europro/faqdetail.aspx?modelno=998B
It does not list a 9988A, but I would imagine there is not much difference in how the threading and bobbin is done. This is a page of instructions as well as a manual to download. The manual is in Pdf format, so if you don;t hae acrobat reader, you'll need to go to www.adobe.com/acrobat and download it for free so that you can read the pdf file.
Good luck to you and Thank you for using Fix Ya!
Posted on Aug 22, 2008
Michaelle
  • 65 Answers
SOURCE: looking for a owners manual for a shark euro pro
If you want it free, try here first. You'll need a specific # off the back of the machine, they tell you where to find it.
If they don't have it online, you'll have to pay for one.
http://www.euro-pro.com/europro/default.aspx
Posted on Mar 30, 2009
  • 3 Answers
SOURCE: help me find a manual for a euro pro 7133 sewing machine
I hope this helps. It took some searching but this is what i found. Good luck!
http://www.sharkclean.com/manual/7133_REV_1204_ENG-SP-FR.pdf
Posted on Jan 22, 2010
SOURCE: I have a Shark Intelli Sew 9110 Euro Pro. It was
There is no solution for that problem. My machine was doing the same thing, I returned it for "repair". Got it back 2 wks later and had the same problem. Just the other day, the machine did that, and then something "popped" and now the upper thread won't catch the bobbin thread. I called Customer Service and was told that if I want my machine repaired, I have to send them a check with the machine for $81! Your best bet...get rid of the Intelli-Sew and buy something that doesn't break every month or so!
Posted on Mar 19, 2010
I have a euro pro shark sewing machine. I just changed the thread for another project and cannot get the needle to pick up the bobbin thread. Any ideas?
Try installing a brand new needle. Bent/damaged needles will sometimes not pick up the bobbin thread.
Make sure the machine is threaded correctly. Check the bobbin--ie, it is turning the correct direction in the bobbin case and is threaded properly through the bobbin tension.
You might also try pulling the bobbin thread up to the top before beginning to stitch.
How and Why to Bring up the Bobbin Thread
Oct 02, 2016 | Euro-Pro Sewing Machines
My bobbin casing keeps jumping loose
it would be a good idea to have the sewing machine checked to see if there is something wrong with the hook and hook race that hold the bobbin casing.. you may need a new bobbin casing.
Aug 05, 2013 | Euro-Pro Shark 60 - 384
Shark model 361 when drawing up the bobbin thread it wont catch upper thread wandering what the bobbin looks like for this machine
try changing the needle
rethread the machine top & bobbin
check with sewingpartsonline.com-- to see if they show a picture of the bobbins for that machine
May 27, 2012 | Euro-Pro Sewing Machines
Euro pro 7133 shark is jammed can't turn the wheel, removed bobbin and lock housing but can't get the wheel to turn
If you have taken out the bobbin case and the raceway the machine should move, if it does not then you have a problem elsewhere and it means a process of elimination to find the problem
Aug 29, 2011 | Euro-Pro Shark 80 - 7133
Euro-Pro Shark Intelli-Sew 9110
you need a new bobbin case, only problem is finding the right one. I am currently wasting hours trying to find one for our 9110 intelli sew which has needle holes punched through it from where it jumps right out. I think lots of manufacturers know fine which parts fit the Euro-Pro but would like all of us to scrap them and go out and buy theirs!
Aug 28, 2008 | Sewing Machines
Won't catch bobbin thread
In order to see whether or not my euro-pro 9110 had a timing issue, the service rep had me change out the needle (making sure I was using anything but a Singer brand needle--they do not work in these machines). I re-threaded the needle, took out the bobbin casing and the plastic ring encasing the bobbin, then lowered the needle to see if the hook on the metal ring holding the bobbin actually catches the thread on its own. If it doesn't catch, it's a timing issue and needs repair. They can walk you through this process of troubleshooting and set up repair if need. Call Eruo-Pro's customer service center for sewing machine service and repair at 800-798-7395
Apr 17, 2008 | Euro-Pro 8260 Mechanical Sewing Machine
Sharlk sewing machine
the needle keeps breaking it is hitting the bobbin case .
Dec 31, 2007 | Euro-Pro Shark 60 - 384
Euro-Pro Shark Sewing Machine Logo
62 people viewed this question
Top Euro-Pro Sewing Machines Experts
Tally Girl
Tally Girl
Derek Massey
Irene Tulloch
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
