How much is the wire control cable price ? - Audio Players & Recorders
how much is the wire control cable price ?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 924 Answers
What do you mean by a "wire control cable"? That's nothing I've ever heard of. Will need the make a model as well.
Posted on Nov 23, 2014
I'm getting a no signal display on tv when I try to hook hdmi devices to lg42Lh30. It is not hdmi wire, and when I hook up cable wire to tv I get hd channels ..
Buy a decent HDMI cable, check the version of the cable not the cost, as higher priced leads simply offer less interference and a longer life.
Nov 23, 2012 | Televison & Video
Leaking valve cover gaskets - repair estimate $1000.00. Is it worth it?
no it is not worth that much, you can do it yourself for about 20-40 dollars (price of the gaskets)
follow these for better instructions go to www.autozone.com and register to become a member
this will give you access to their repair database there you can specify your car and get repair info.
Removal & Installation2.0L Spi Engine
  1. Loosen the clamp and disconnect the engine air cleaner to valve cover hose from the valve cover.
  2. Remove the two ignition wire separators from the valve cover. Position the spark plug wires aside.
  3. Remove the three valve cover bolts and remove the valve cover and gasket.
To install:
CAUTION Do not use abrasive grinding discs to remove gasket material; only use manual scrapers. Do not scratch or gouge aluminum sealing surfaces or oil leaks may occur.
NOTE Do not use any sealer with a silicone-type gasket.
  1. Install the three valve cover bolts and remove the valve cover and gasket.
  2. Install the two ignition wire separators from the valve cover.
  3. Tighten the clamp and disconnect the engine air cleaner to valve cover hose from the valve cover.
2.0L Zetec Engine
  1. Disconnect the crankcase ventilation hose from the fitting on the valve cover.
  2. Disconnect the wiring connector at the oil control solenoid.
  3. Disconnect the speed control (if equipped) and the accelerator control cable.
  4. Position aside the accelerator cable.
  5. If equipped, disconnect the speed control cable from the bracket and position aside.
  6. Remove the ignition wires from the spark plugs.
  7. Remove the bolts and position the upper timing belt cover away from the valve cover.
  8. Remove the valve cover.
  9. Fully loosen the ten bolts.
  10. Remove the valve cover and valve cover gasket.
  11. Inspect the valve cover for damage. Install new cover as required.
    CAUTION Do not scratch or gouge aluminum sealing surfaces or oil leaks may occur.
  12. Clean and inspect the sealing surfaces of the valve cover and the cylinder head. Both surfaces must be clean and flat.
To install:
  1. The valve cover gasket and the valve cover must be installed and the bolts tightened to specification within four minutes of sealant application.
  2. Apply a 0.1 inch (3mm) bead of silicone sealant in two places where the front camshaft bearing cap meets the cylinder head.
  3. Install the valve cover.
  4. Position the valve cover gasket.
  5. Position the valve cover.
  6. Tighten bolts in the sequence shown.
    Fig. The proper torque sequence for the 2.0L DOHC Zetec engine
  7. Install the upper timing belt cover bolts.
  8. Install the ignition wires.
  9. Connect the oil control solenoid connector.
  10. Connect the crankcase ventilation hose.
  11. Connect the speed control (if equipped) and the accelerator control cables.
  12. If equipped, connect the speed control cable to the bracket.
If you need further help, reach me via phone at https://www.6ya.com/expert/michael_17692f6169bfde50
May 13, 2011 | 2001 Ford Escort ZX2
I believe my power source is in the ceiling. I just want to wire a light but use a leviton switch and dimmer at the wall. Can't figure this one out. Can you help. There are two red wires, one black and...
Question needs more details. Let me answer as if you have one light and one switch, and one cable coming into switch box from ceiling.
Usually a switch-dimmer combo operates 2 different Loads (lights).
One light is controlled by switch, other by dimmer.
If power source is in ceiling, then one cable enters switch box.
Cable has black, white and ground wires
Old switch had 2 brass screws where black and white wires connect
Black wire brings Hot down from ceiling, and white wire connects back to Load (fan).
Neutral wires are in ceiling box, and not inside switch box, and are discussed.
With new dimmer: Black Hot wire from ceiling connects to dimmer black wire.
White Load wire connects to one of the red wires.
The other red wire goes to another Load, which is unknown at this point.
Add a comment for more free help. Say what cables and wires enter box, and what Loads you are controlling. Also add exact model number so expert can reference manual. Levition instruction sheets and manuals usually have toll free number.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via e-mail or phone while you work on circuit or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 22, 2011 | Leviton MFG L00-IPI06-1LM DIMMER SLIDE...
Ignition Control Module Price:$113.99 Duralast/Neutral Safety Switch Price:$39.99 /Relay - Anti-Theft Price:$19.99 Relay - Fuel Pump Price:$14.99 Relay - Power Door Lock Price:$10.99 Relay - Starter...
Replacing all this you surely set the alarm off. Turn the car on, don't start . let sit for ten minutes, turn off, don't remove the key. do this three times. after the third time you turn it off, if it was the security, then the car should start. Let me know And we can go fdrom there.
Randy
Dec 02, 2010 | 1998 Saturn SL
The airflow selector on my 2001 Toyota camry became difficult to turn, so unfortunately, I forced it and something snapped. I believe the arm that moves the paddle broke. How can the entire airflow...
Brother Mark, I know just what you mean. What happened is that the wire on the end of the cable has pulled out of the hole on the lever at the control because the cable has dried inside the housing and needs lubrication. Near impossible to do without taking it out, then mas as well replace the cable. Most likely the lever on the control valve that shuts the water line off at the firewall has stiffened up and caused you to force it and pulled the cable out at the valve in front of you on the firewall under hood. I don't know pricing on this stuff because I always do my own work. I build my vehicles, not buy them. Either way, it's the water control valve and cable that need attention. I just open the valve with pliers under the hood for winter if I don't feel like changing it right away. the other stuff on the control panel works fine.
Nov 12, 2017 | 2001 Toyota Echo
I have a Toshiba Satellite L505D-S5983 Laptop with Windows 7 and a Philips HDTV flat screen TV. I want to run a cable from the laptop to the TV so I can watch online shows on my TV screen. My TV has an...
The price difference in the cables are what type of metal wire that is in it. One might have copper or even gold plated and the lower price one might have some low end metal. I have not seen any difference. Yes, all you have to do is plug it in and Windows 7 will recognize your TV. You might want to go into the Control Panel and open Sounds and make sure you have the audio turned on for your HDMI connection. Your laptop screen and the TV will be displaying the same.
Sep 04, 2010 | Toshiba Satellite L505DS5983 Notebook
I don't have an extensive tool collection and even less experience with cars. But my mechanic wants $500 to replace my starter in my 2000 Toyota Sienna. 15 years ago I changed the starter in my little...
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
  2. Remove or disconnect the following:
    Battery Battery tray
  3. Remove or disconnect the cruise control actuator, if equipped, as follows:
    Actuator connector and clamp 3 bolts and the actuator with the bracket
  4. Remove or disconnect the following:
    Automatic transaxle shift control cable Engine wiring Starter electrical connectors Both bolts, shift control cable clamp and the starter
To install:
  1. Install or connect the following:
    Starter and the shift control cable clamp. Tighten the bolts to 27 ft. lbs. (37 Nm). Starter electrical connectors Engine wiring Automatic transaxle shift control cable
  2. Install or connect the following, if equipped with cruise control:
    3 bolts and the actuator with the bracket Actuator connector and clamp
  3. Install or connect the following:
    Battery tray Battery
3.0L Engine
  1. Before servicing the vehicle, refer to the Precautions section.
To install:
  1. Before servicing the vehicle, refer to the precautions section.
To install:
3.3L Engine
  2. Remove the air cleaner assembly and inlet tubes.
  3. Remove the air cleaner bracket.
  4. Remove the wiring from the starter.
  5. Remove the 2 bolts and lower the starter.
  6. Installation is the reverse of removal. Torque the starter bolts to 26 ft. lbs. (37 Nm).
  2. Remove the battery and tray.
  3. Remove the air cleaner assembly and inlet tubes.
  4. Remove the air cleaner bracket.
  5. Remove the wiring from the starter.
  6. Remove the 2 bolts and lower the starter.
  7. Installation is the reverse of removal. Torque the starter bolts to 26 ft. lbs. (37 Nm).
Thanks for using FixYa - please use the preceeding instructions to determine if it within your skillset (and tooling) to replace yourself. A FixYa rating is appreciated for answering your FREE question.
Jun 21, 2009 | 2000 Toyota Sienna
PS 3 conroller recharge cable
Courtesy of Calibex, here is a search I did to find a good price for the recharge cable:
http://www.calibex.com/ps3-controller-cable/zzcalibex2zB1z0--search-html
Gives you plenty of places to buy it from. Just find the place and price you like.
Feb 28, 2009 | Sony Playstation 3 (PS3) Console
Cruise control installation
Not really sure on parts pricing (probably very expensive) but very complicated and work intensive to install... Need to get the engine computer reprogrammed for cruise control, install all the wiring (to the brake light switch, the speed sensors, etc...) install the servo/vacuum motor and cables to the throttle assembly...
Aug 20, 2008 | 2006 Hyundai Tucson
Firewire cables
I highly recommend that you avoid the cheapest cables. Generally speaking, they tend to fail at a much higher rate than cables in the mid to high cost range. The molded plugs crack, the end connectors become intermittent, and the wires inside the cable tend to "open" (come apart) when flexed or stored coiled too tightly. (All cables are best stored straight or, if need be, in a large loop).
Also, cheaper cables quite often have less "conductivity" and may be prone to have less "noise" (interference) suppression.
I assume your use is moderate at most (5-10 hours a week or less) in which case I beleive a mid-price cable--$25 to $35-- will work fine for you. Monster Cable is readily available online and in stores. Other brands usually have a selection of grades for the same length that you may need.
Jan 09, 2008 | Sony Handycam DCR-HC21 Mini DV Digital...
37 people viewed this question
 Grubhead
Grubhead
