What does system lockout mean 1 flash - Heating & Cooling
    Problem Solver:
  • 6 Answers
The unit is overheated and the safety high limit switch on the heat has shut the unit off. sometimes this means that they are need to be replaced , use an ohmmeter check out the resistance and see if it's still good.
Posted on Nov 21, 2014
What does 3 flashes of the red light mean on an amana model ptc153a35ac ?
Here are your Amana flash codes:
Steady On - Normal
Off Controller Failure
1 System Lockout
2 Pressure Sw stuck closed
3 Pressure SW Stuck Open
4 Open - High Limit
5 Flame sense without gas valve
6 Open rollout or open Fuse
7 low flame signal
8 Check igniter or improper ground
continuous flashing - reversed AC polarity
Sep 11, 2014 | Heating & Cooling
How do i reset the lockout
Push and hold the button for 60 seconds. It is in customer lockout because it was pressed more then 3 times.
Apr 25, 2014 | Honeywell R7184A1026 Electric Oil Primary...
Pr sw failed to close
Troubleshoot by type of gas control valve
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Repeated 3 flash on power vented honeywell gas control thermostat means system in lockout.
Repeated 3 flash on atmospheric-vent Honeywell gas control valve means temperature sensor failure.
Take apart gas control, and buy temperature sensor if sold separately at AO Smith dealer.
http://waterheatertimer.org/How-to-replace-Honeywell-gas-control-valve.html
Add a comment with more information
Mar 23, 2013 | Rheem 40 Gallon FVR NATGAS Low WATER...
Lg spilt system turns of after 5 mins green light flashes
You need to note the pattern of the flashes, short or long flashes etc.
there is a legend that explains all the possible codes.
Example: 3 long flashes 1 short flash, the legend will say something like hi pressure safety switch
or low pressure safety switch , this could mean dirty coils, inside and outdoors, or bad fan motors either location as well, the compressor may be over heating or overloading, or be gong bad. a capacitor may be the culprit, what you can do is see the fuses and airflows good and no coils blocked etc , notice if any motors stop causing the flasing lockout condition.
Dec 27, 2010 | LG LS-L1210CL Mini Split Air Conditioner
Hi, the lights on my circiut board are flashing the one on the left is on all the time and the one to the right of it flashes two times and then waits and then flashes two times again
Error Codes
A green LED indicates system faults
Steady On: System OK
Steady OFF: Board control fault or no power applied
1 Flash: Ignition failure (control in one-hour lockout)
2 Flashes: Pressure switch fault, fails open (switch is
stuck open)
3 Flashes: Limit switch open (main or auxiliary)
4 Flashes: Pressure switch fault, fails closed (switch is
stuck closed)
A yellow LED indicates flame status
Steady on: Normal flame is sensed
Flashes: As flame weakens, frequency of LED flashes
increases
hope this is helpful.
Dec 21, 2010 | Ruud Central System Air Conditioner
The power button and the screen flashes when i try to turn my nes on. Why, and how do i fix this?
Well there is a segment I see on youtube that has NES lockout chip removal
the red blinking light of death means the lockout chip is malfuncting and needs to be disabled.
Jun 12, 2010 | Nintendo NES Console
Armstrong upflow,unit works intermittent problem,call for heat nothing happens,error code of 5 blinks then 6 blinks. i have no manuel, and the panels dont have the codes on them. anyone have access to the...
Armstrong
FAILURE CODES
LED Status Fault Description
Off
No Power to the System Control
Steady Flash (11 or more flashes with no pause)
Normal Operation (Standby or call for heat)
2 Flashes
Pressure Switch Closed When It Should Be Open
3 Flashes
Pressure Switch Stuck Open 30 Seconds or Longer After Call for Heat (System in 5-minute delay mode before next call for heat). On/off switch in "off" position during a call for heat will generate this code.
4 Flashes
Open Limit Switch or Limit Switch Circuit
5 Flashes
Flame Sense Signal Sensed Out of Proper Sequence
6 Flashes - pause - 1 Flash (see Note 1)*
Soft Lockout Type 1 (Failure to light within 4 trials for ignition)
6 Flashes - pause - 2 Flashes (see Notes 1 & 2)*
Soft Lockout Type 2 (Flame sense lost during run)
6 Flashes - pause - 3 Flashes (see Notes 1 & 2)*
Soft Lockout Type 3 (Pressure switch opened during run)
6 Flashes - pause - 4 Flashes (see Notes 1 & 2)*
Soft Lockout Type 4 (Limit or limit circuit opened during run)
6 Flashes - pause - 5 Flashes (see Note 1)*
Soft Lockout Type 5 (Flame has gone away after Error Code 5)
6 Flashes - pause - 7 Flashes (see Note 1)*
Soft Lockout Type 7 (Self-check failure)
10 Flashes* - SV9520H8034 only
Line Input Voltage Polarity Reversed
Dec 12, 2009 | Coleman Heating & Cooling
Meaning of rudd furnace trouble codes
Error Codes
stuck open)
stuck closed)
increases
Dec 12, 2009 | Heating & Cooling
Heating & Cooling Logo
42 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
