Question about HP Office Equipment & Supplies
I have an hp5530 envy e and it wont switch on
When i switch on at the mains the on switch flashes once .it wont come on when you press the on button
  • HP Master
  • 11,800 Answers
I presume you have tried other ink cartridges, that the print head moves freely on its rail, and that there is nothing that could have fall inside the machine and jam the rollers, and it behaves the same
One single flash signals a major failure - the system of the printer doesn't even go past the first power-on tests. If you can, open it up (6 screws on the european version and some tabs that must be gently pried open) and see for loose connectors or major electrical damage.
Sorry, it will be cheaper to just buy a new one than fixing this one.
Posted on Nov 24, 2014
I have zanussi ZWH 6140 P WATER WONT DRAIN ERROR CODE 5 FLASHING RED LED LIGHTS?
First, always check carbon brushes on main motor especially if the appliance is in use for several years.
Five times the red alarm means a problem with the engine washing.
So, could be:
E51 - Motor power triac short-circuited.
Current leakage from motor or from wiring; Main PCB faulty
E52 - No signal from motor tachometric generator.
Wiring faulty; Motor faulty; Main circuit board faulty.
E53 - Motor triac sensing circuit faulty (wrong input voltage to
microprocessor). Main circuit board faulty.
E54 - Motor relay contacts sticking (high voltage level when
the relay switches to OFF).
Current leakage from motor or from wiring; Main PCB faulty;
Rapid reading last alarms:
Press the START/PAUSE button and the nearest option button simultaneously (4 and 6) for at least 2 seconds: the LEDs initially switch off, and then display the flashing sequence indicating the last alarm.
zwh 6140 p-dd5v0vxzvbk4xzho0hm3qdol-4-0.jpgDado
Mar 01, 2017 | Zanussi Washing Machines
How do you change the ink cartridges in printer hp5530?
There you are Debbie, and with all the right information :>)
Scroll down this page for full instructions. With your model, you lift up the top.
HP ENVY DeskJet Printers Replacing the Ink Cartridges
Nov 11, 2015 | HP Office Equipment & Supplies
My technika lcd40-920 tv wont turn on standby flashing blue to red i held power in 30secs n stopped flashing but still wont turn on why some one said its trying to update but not sure can u help
How long have you had this TV? If it is under 12 months, get it fixed under the guarantee. If you have an extended warranty, use that to get it fixed.
I would suggest that you switch everything off, remove all the cable from your satellite box or games console and everything else, then switch off at the mains and unplug the set.
Now press and hold the power button on the TV for 30 seconds.
Now plug the TV into the mains again and use the TV button to switch on the set. If the lights continue to flash, then it's a repair job. If the lights are steady but there's no picture, then switch it off using the TV button and reconnect the aerial cable first and try it again.
Once you get a picture displayed, you can begin to reinstall all of the other cables until everything is working again.
Apr 13, 2015 | Televison & Video
Merlin Prolift 230T wont clear / delete remotes from memory
Press 'setup' key for 11s not 'learn' key.
Jun 26, 2012 | Cell Phones
Can you give me the step-by-step process to switch the time from standard to daylight savings?
From the main time display, hold down the adjust button until it beeps and your time zone is flashing on the bottom of the display. Then press the mode button once. [AUTO/ON/OFF] DST will be flashing on the bottom. Use the Time Memo and/or Receive buttons to cycle the mode. When it's what you want, press adjust twice.
Mar 13, 2011 | Casio G-Shock GW500A-1V Wrist Watch
I have an identical prestige remote which is not programed for my car iwould like to program it exatly like the one i now use so i can have a spare.
The programming procedure for Prestige/Pursuit remote is as follows:
First, locate the programming/valet switch. For newer model units the programming switch is located in the antenna, previous models have a push button LED (PBLED). Older models have a plain black push button, usually located near the driver's side kick panel (where your left foot would rest when driving).
After locating the programming switch; turn ignition on, press and release switch three (3) times,parking lights will flash once. This is channel 1 (lock button). Press lock button on remote. Parking lights flash once. Press and release switch one (1) time. Two flashes (channel 2). Press unlock button on remote. Press and release switch one (1) time. This is Channel 3 (trunk/remote starter), press the channel three button on remote. Repeat process for additional channels. Once you have programmed all available channels, turn ignition off to exit programming.
Jan 20, 2011 | Gmc Dodge Ford Reverse Back-up Sensor...
I bought a new key fob for my audiovox aps 686 and have no clue how to program it. I looked at unit under the dash have found no buttons to reprogram it. Anybody know?
Did the unit have anything plugged into the blue two pin port? If so, trace that wire (black & gray) to the programming switch. Once you have located the switch, turn key on, press and release the button three times. The parking lights will flash once. Press the lock button on the new remote. Press and release the programming button once (two flashes), press unlock button. Press and release probramming button once( three flashes), press remote start button. Press and release programming button once (four flashes), press option button. Turn key off. test system.
Nov 30, 2010 | Prestige Remote Start
Car wont start after getting a new key and replacing batteries -
hi well this is a bit long so if you can bare with me i will try explain how to , clear system to decode, and recode as this is what it sounds like that the coding has gone from the ignition key....ok here goe's
to sync key with car depress lock or unlock button manually lock the drivers door within 30 seconds of the above system should now work....if not do next bit
switch ignition on ( using non chip key ) manually lock drivers door using key ( another one, hopefully you will have more than one) press unlock button 5 times, in one second intervals indicators flash 5x for every time signal is received switch ignition off and remove key
that's the de-programming done...
to de-program the system if above fails..........
switch ignition on ( use key without remote ) manually lock drivers door using key to be synced with car complete the following within 30 seconds of doing above within 5 seconds press the unlock button on key indicators should flash once wait 5 seconds press unlock button once to confirm programming vehicle should unlock this also will confirm deactivation of programming mode switch ignition off remove key..that should be it, then try new programed key in ignition.
to re-program system and sync with key switch ignition on manually lock drivers door using key ( another one, hopefully you will have more than one) press unlock button 5 times, in one second intervals indicators flash 5x for every time signal is received switch ignition off and remove key
that should be it, if no joy then will have to main dealer i am afraid...hope this helps
Jun 07, 2010 | 2001 Audi TT
How can you remove a 5100 error with a canon mp210?
1. Switch off the printer (the button, rather then from wall-plug
2. Press and hold Resume
3. Press Power
4. Holding Power , release and once again two times press Resume , then release simultaneously all button.
5. After indicator is flashing, fall into service rezume.
6. Four times press the button Resume , under each striking Resume indicators are switched: green-orange. Once press the button Power for acknowledgement of the selected action (the unset of the counter pampers). The Button Resume enter prefunction:
- 0 strikings unset main counter in 0%, or
- 1 striking unset additional (platen) of the counter in 0%, or
- 2 strikings installation both counter on 0% .
7. Press Power (is executed service-function, chosen striking Resume )
8. Once again Power - swich off.
Sep 22, 2009 | Office Equipment & Supplies
Do not know how to program fresh start oasis full button over fil
Remove the brew basket and water defuser (sprinkler head) it should come off with a 1\2 turn.
Place your measuring pitcher or empty pot in place.
Turn the main power switch off in back of unit.
Press and hold the Brew(full pot) button.
While holding the Brew(full pot) button turn the main power button in back to on.
Once the red light flashes over the Brew(full pot) button release it, then press it once to start the brew cycle.
Let it flow until desired level in pot or measuring pitcher.
Press the Brew(full pot) button once to Stop.
Press the Brew(full pot) button once again to lock the settings into memory. Memory will store the settings even if machine is unplugged.
Half pot button is automatically set.
Apr 09, 2009 | Oasis FreshStart 80 oz 10-Cup Coffee Maker
Seeker5211
Seeker5211
