Question about HiTi 720L Photo Printer P720L
On the display of the printer it only indicates intializing. The cable from pc to printer is good? And the door of the printer isn't opening. What can the problem be?
HP PhotoSmart computer indicates "open door"
Open "Devices and Printers" in start menu.
Right click printer with green arrow - click see whats printing.
Delete all documents.
Restart computer - then restart printer
See if that clears your error messages.
Mar 12, 2014 | HP PhotoSmart C4345 AllInOne InkJet...
No display when i turn printer on.
two things you need to check..1.printer intializing? 2. printer recognising?
Printer intializing & not recognising replace formatter, recognizing,intializing replace control panel,printer not intializing,not recognizing replace DC controller..
Sep 19, 2011 | HP LaserJet M1522n MultiFunction Printer
My printer says the door is open when it is closed!
the iR1600/2000 will show the message close printer door if the copier paper path door ( on left side of copier, beneath the bypass tray are paper path door in level with paper cass. ) isn't closed well. Open the door and close them with some "gentle" force. It is good idea first to push the paper path guide, before closing the door.
Hope that helps!
Apr 21, 2011 | Canon ImageRunner 1600 Copier
Showin cover open but doesnt indicate plus sc code 670
I looked up the error code in the manuals for the 450 and 450e,I tried sc 670, 607, 706 and 760 NONE or those codes exist in either one of my manuals! Sorry. Wish I could help
Apr 03, 2009 | Ricoh Aficio 450 Copier
''No Cartridge'' Error
check if the cartridge is a hp cartridge
if no use a hp cartridge
if issue stll occurs
open the cartridge door
remove the cartridge and the papers from the tray
close the cartridge door and turn off the printer
then turn on then printer
you will get a msg install black cartridge
open the cartridge door and put the cartridge inside and the papers in the tray and close the cartridge door
the printer will intiallize and you will get a ready msg on the display of the printer.
if you still get the msg have the printer serviced
Feb 03, 2009 | HP LaserJet 3055 All-In-One Printer
Missing Black Cartridge
hi..try these steps
1. clean the cartridge contacts in the printer..
2.unplug power adaptor(black box) from the bac of printer,,press and hold stop/clear button..plug the adaptor back in...display says clearing NVRAM,,,,after this printer would turn off and turn on automatically..reenter the intial set up details like language,country....
3.insert black cartridge...still same msg..printer is defective...call techsupport..your printer would be replaced if in warranty.
good luck
Jan 25, 2009 | Lexmark X4270 All-In-One InkJet Printer
Ink Waste Tank Almost Full on Canon i320 printer
Hi, This procedure should work.
Waste Ink Counter Reset.
Step 1 : Manual for service mode
1. Unplug power and USB.
2. Open door and hold power button.
3. Connect power.
4. Close door, then release power button.
or
1. Turn off the printer. And disconnect the printer cable.
2. Press and hold the POWER button, turn on the printer.
3. The indicator (L.E.D.) should be green.
4. Press and release the RESUME button , the indicator (L.E.D.) should be orange.
5. Press and release the RESUME button again, the indicator (L.E.D.) should be green.
6. Release both buttons.
step 2 : Software for Permanant
1. Reconnect the printer cable.
2.Open General Tools software and select (USB PORT)
3 .Choose (SET DESTINATION 1) And it should be reset.
Jul 25, 2008 | Office Equipment & Supplies
Ricoh Aficio340
Well, you sound like you figured out part of your problem. If the open door symbol is showing, then you need to find out which door the machine thinks its still open.
Check all the doors, front, both right and left doors, and if the machine has a bottom console, then check those doors also.
I would open every door and reclose them again and see if you can get the DOOR OPEN symbol to go away. Need to start with the basic first.
Once this is cleared then we can see if we can troubleshoot any other problems.
(Most doors have a little stub that sticks out that either goes in between a sensor, or pushes on a switch to tell the machine that the door is closed.
If after opening and closing each door, and the machine still says Door open, then Next step I would take is to see if there are any places on the door that looks like a small piece of plastic might have broken off.
Let me know what you find.
Good luck.
Mac
Mar 29, 2008 | Office Equipment & Supplies
HiTi 720L Photo Printer P720L Logo
Top HiTi Office Equipment & Supplies Experts
Emmanuel Sackitey
Cara Lee
Cara Lee
Level 1 Expert
Adegoke Mubarak...
Adegoke Mubarak...
Level 1 Expert
Are you a HiTi Office Equipment and Supply Expert? Answer questions, earn points and help others
