Question about Sharp Televison & Video
I HAVE SHARP COMPANY 21 INCHES CRT MY FRIEND TV SET PROBLEM IS SET DEAD IN POWER SUPPLAY TRANSISTER 1886 REPLACED AFTER POWER SUPPLAY IS OK FBT ARCKING THEN IMMEDIATLY SET SWITCH OFF SET IN CIRCUIT R6
IN POWER SUPPLAY TEA2261IC TRAD1886 ,IF VCD IC NOM52340SP,FBT NO F147
  • Sharp Master
  • 1,249 Answers
Bad flyback transformer, freewheel diode, snubber capacitor, horizontal output transistor. If you replace one, replace them all. Also could be problems in the secondary power supply, these units use the flyback transformer to feed the audio and vertical sections.
Posted on Nov 26, 2014
    Top Expert:
  • Sharp Master
  • 74,383 Answers
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Posted on Nov 22, 2014
  • 556 Answers
SOURCE: tv dead
please check flyback transformer for short
good luck
Posted on Nov 02, 2007
SOURCE: LG vertical failiure vertical line at the bottom of the crt
replace the vertical driver ic and the proccesor ic
Posted on Nov 25, 2008
  • 56 Answers
SOURCE: chopper transister blown fuse blown
100k ground from ic pin replece 3 electrolytic cap . Adjust preset for 95v if it isphilips tv
Posted on Aug 19, 2009
gopakumarg43
  • 74383 Answers
SOURCE: I haveSansui 1403ctv the tv set is dead.no output from smps.When I switch on the tv immediatly switching transister(c1802) will be short.
Check the freewheeling capacitor connected to the collector of this switching output transistor for open. Check the serial resistor too.
Posted on Dec 05, 2012
gopakumarg43
  • 74383 Answers
SOURCE: no power Samsung flatscreen CRT 21 inch TV
Check its fuse. Check the rectifier diodes. If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Posted on Jan 18, 2014
What to do no power on 21" sony Trinitron 1997 ?
first check main card and then check fuse .if fuse is blown put new one amp fuse.af set is ok leave it .if not work then chcck seitching transister and S.T.R 6007and oo120volt zenner diode.
Sep 19, 2014 | Sony FD Trinitron WEGA KV-21CL10 21" TV
14V- WISON crt sharp tv no display how fix it
If there has sound but no pic...Check those bad resistors around the Flyback transformer, or its causing that the Flyback transformer is poor.. rejuvenate FBT.
May 19, 2014 | Sharp 21B-S10 21" TV
Sharp tv power supplay ok no EHT what is the probleb?
Possible a Dry joint- have you tried hitting the TV-
Does it come on intermitently?
If not it could be a problem with the FBT.
This will be an obsolete part if so.
Hope this helps
Welly 250
Jul 02, 2012 | Sharp Televison & Video
My trinitron color tv sony kv-21ct13, after 3 or 4 tic tic tic, the power led in the front of tv blink 10 times and after go to off. After of this tv is out of order. The fuse inside the tv for 230 vac is...
Ur high voltage is dead.FBT,the flyback tranformer the big black block of plastic with a red wire with a cap that hook to the CRT(tv tube).That it dead.The "H" transistor beside the FBT steel wall on the left outer wall might also be dead.U can tries unpluging,replung it an hour later might get some use of.To solved these problems must replaced the FBT,and "H" transistor.If u have this tv along time?Get rid of it,not worth repairing,parts are hard to find, and repair shop will charge alot for this prob.LCD tvs it cheap these day.
Mar 22, 2010 | Televison & Video
I have 37MF321 we replaced the capcitors and everything. However when we put the power into it. We have a Chirping Noise.
Ur high voltage it dead.The FBT is dead,it the Flyback Transformer.The big black block of plastic with a red wire with a cap plug to ur CRT(Tv tube).The "H" Transistor might be dead also.The "H" transistor is to left side steel side wall cage that surounded the FBT.
Mar 15, 2010 | Philips Magnavox 27MS343S 27" TV
Dead set sharp 21v-s300red light only green light bad
chek hout transister hstat voltage 8.2volt drivertfr
Jan 28, 2010 | Sharp 27N-S300 TV
My Sony Wega 55" LCD TV will not turn on, the standby light just flashes
if the light flashes 6 times over and over it is the power board. butcheck the lamp
Dec 08, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Tv dead
good luck
Nov 01, 2007 | Televison & Video
Tv not powering up
What voltage is present at the collector of the horizontal output transister? If the same 102 volts then you have no horizontal drive.
Mar 22, 2007 | Daewoo DTQ-20N2FC TV
Televison & Video Logo
100 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
