Question about Olympus Cameras
I have just installed a new battery to my omlympusvr310 but now it wont turn on
Tried taking out the battery an reinstalling but still nothing
    Top Expert:
  • 2,044 Answers
I would confirm that you are installing the batteries correctly (Positive is the +, Negative -)... I would also confirm that your NEW BATTERY is also GOOD. On more than one occasion, I have purchased a NEW BATTERY just to discover it was defective.
Posted on Nov 21, 2014
Lens was stack and wont open
1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable. I really hope this will work for you, but unfortunantly often when the product is dropped a mechanical problem appears. And there is nothing more than to order an OoW repair for this fault and model is 48 pounds. In order to organise your repair or Trade up please Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Jan 07, 2010 | Kodak Easyshare 1725043 M893Is Digital...
The camera wont turn on
Here are the steps: 1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable.
Jan 05, 2010 | Kodak MX1063 Digital Camera
Wont turn on
1. Make sure you will install a new or fully charged battery/batteries into your camera. Please use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
3. Turn on your camera without the memory card.
Dec 31, 2009 | Kodak Easyshare C813 Digital Camera
Wont come on even when a new battery is installed.
Here are the steps: 1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable. In order to organise your repair or Trade up please Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Dec 21, 2009 | Kodak EASYSHARE M1063 Digital Camera
My N95 kept rebooting itself so i looked around on the net and found that i need to install new firmware. I downloaded nokia software updater and it starting downloading the upgrade. However about 14mins...
You should try to install NOKIA SOFTWARE UPDATE to ur phone to install the new firmware .It is just software problem not any big to worry.You can go to any nokia center to reinstall the firmware and got ur phone A1.
Dec 05, 2009 | Nokia N95 Cellular Phone
Camera lens does not retract
Here are the steps:
2.Remove the battery/batteries and the memory card from
your camera
3.Reinstall the battery/batteries into your camera
4. Without the memory card,turn on your camera.
If issue persists, call 1.800.235.6325 for repair.
Sep 21, 2009 | Kodak CX6330 Digital Camera
My camara wont turn on
Here are the steps:
3. Without the memory card,turn on your camera.
Thanks.
Neerak21
Aug 27, 2009 | Kodak EasyShare M863 Digital Camera
Phone wont turn on it just blinks red
just connect your handset using datacable to your pc or laptop and then install desktop maanager and take a backup of your handset and reinstall your operating system.
Aug 11, 2009 | RIM BlackBerry Pearl 8100
Wont reinstall OS (error message during installation)
I had a very similar problem when trying to install the new OS. The way I got it working was
1. make sure you have fresh batteries in.
2. Find a new computer which you have not used neither TI connect nor the calculator on.
3. Download the OS to this computer from Ti´s webpage
4. Install Ti connect and the calculator on this machine 100 % correct! (check other help files for this)
5. Go into Ti connect, and it should find the calculator now.
6. Use the "device explorer" and then the "OS downloader" directing the downloader to the path where you have already downloaded the OS to the computer.
I hope this helps you out...
Apr 10, 2008 | Texas Instruments TI-84 Plus Calculator
Cameras Logo
Top Olympus Cameras Experts
Willem.
Willem.
Are you an Olympus Camera Expert? Answer questions, earn points and help others
