I recently purchased this old model and got the following error codes: DEV 086 ERR 22 FRU 0010 Didnt find the codes in the RepairManual. Is it the Systemboard which is to replace? Thank yo
I recently purchased this old model and got the following error codes: DEV 086 ERR 22 FRU 0010 Didnt find the codes in the RepairManual. Is it the Systemboard which is to replace? Thank you!
  • Jemen Oslon
    Jemen Oslon Nov 21, 2014
    Actual error codes are
  • Jemen Oslon
    00161, 08611, 00192, 00163
    Top Expert:
  • Computers & ... Master
  • 22,705 Answers
Device 086 is either hdd or hdd controller. Error 22 is no communication.
Could be a new hdd required, could be the motherboard.
Posted on Nov 21, 2014
3 Suggested Answers
  • 18 Answers
SOURCE: IBM ThinkPad 600 Hdd error
make sure the Hdd is well connected , and hope its not an HDD failure. Might also want to check see if you didn't disconnect any other wires by changing the battery.
Posted on Feb 28, 2009
  • 36 Answers
SOURCE: I am trying to restore my IBM 600E Thinkpad. I
Hi blue_sky_day,
While googling on the net, I found something related to your problem at this web site: http://www.howtomendit.com/answers.php?id=12813
There are explained many things about your IBM 600E Thinkpad, you will have to read it and see if you can solve your trouble.
Yours sincerely.
Posted on Feb 09, 2010
Wat do;s Err-80 meen
Looked up on Canon.es and this is what I found.
FAQ: What does the error code 'Exx'?
FAQ ID: 44574
Last Modified: 22-Jan-09
Cause
Answer:
When an error occurs the camera will display an error code like "Exx", where "x" represent numbers.
See the list items at the bottom of this page when it shows following error codes.
"E18" error of the target unit / lens barrel
"E30" and "E50" error of the CF or SD card
When an error code "Exx" different from those already mentioned, the camera off and then turn to try to capture or play back images.
If this error persists or an error code appears often, there was a malfunction of the camera.
Note the error code and contact the retailer where you purchased the camera or the nearest service center for Canon.
I hope this helps
Jan 24, 2012 | Canon EOS-D30 35mm SLR Camera
I am getting an Error 00301 on an IBM Thinkpad Type 2645, Model 41U, 600, and it boots to a blinking character (looks like a hypen turned sideways)
I ran the diagnostics and had errors on the SystemBoard,
DEV 001, ERR 91, FRU 3610. Upon reading on other sites, it said that the battery is dead and to remove it and run the diagnostics using just the power plug. That did correct the SystemBoard error. It is still running the diagnostics. Next I will see if I can boot the system using a boot disk if necessary.
Feb 08, 2010 | Computers & Internet
E000020-0010
you have a problem with your developer or toner add assemblys toneris not going into your dev unit
Aug 15, 2009 | Canon imageRUNNER 7200 Copier
Ir8500 error code e000020-0010?
you have to clear this error by doing the following press additional function(*) and 2,8 together) then press additional functions (*)again (you have to do this quickly to get into service mode then you press copier
then you press function
then you press clear
then you press ERR
then you press ok
then turn off the machine and then back on
this is a low toner level detection code
do you have a new toner in the machine?
Aug 05, 2009 | Canon imageRUNNER 105 Copier
What does E000020-0010 error code mean?
e0020 is to do with there not being enough toner in the developer unit.
Firstly it may be a good idea to check/change to toner cartridge.
Switch off and disconnect from mains for the next bit.....
If ok remove the developer roller, cover is above the manual tray on the right hand side then once inside dev unit has connectors at either side, check they are properly seated. If you need to remove the dev there are several black screws around a metal plate all need removing. The roller should be black with toner. May need replacing depending on age and usage of copier.
Mar 30, 2009 | Canon imageRUNNER 7200 Copier
Error E000001 -0010
The error code is for the fixing assy not getting to the correct temperature in a specified time. The 0010 part of the code is indicating the copier was turned off and back on without resetting the error. To reset the code, Press the additional function button, then the numbers 2 and 8 at the same time and then the additional function key again. The display will now be indicating the service options available. Touch COPIER, then FUNCTION at the top of the display, the CLEAR in the middle, then ERR, then OK. Power down copier at the right side rear, then turn back on. If the error comes back then you will have to check the fuser assy to see if the front drive gear has failed or one of the thermistors has gone bad. Good luck
Mar 06, 2009 | Canon imageRUNNER 5570 Copier
Feb 28, 2009 | IBM ThinkPad 600E 2645 Notebook
PROBLEM WITH ERRORS HARD DRIVE DEV-017 ERR 81- FRU 6010 APRECIATE
As you boot up the computer, keep on pressing the F8 key, you will be able to get into the Windows Startup Menu and be able to select Safe menu.
You most likely have a problem with a bad block in the page swap file area.
You may still not get Windows to open, and basically your need to format the hard disk and this will lock out the bad blocks and then you can install Windows again.
This also indicated your hard disk is wearing out and more than likely you will get more bad blocks and this will cause further problems such as computer locking up to data file corruption and or loss files etc.
You have an old laptop (it must have come out of the ark), it is not fixing, unless you can get another hard drive very cheaply, put your money towards a new one.
Jan 02, 2009 | IBM ThinkPad 600E 2645 Notebook
I got a think pad 600 when i turn it on it tells me i got a problem with the system boardafter testing it it says dev 001 err 91 fru...
Your best bet at this point is, unfortunately, to call the manufacturer and see what they say. If it's under warranty, you can send it in to them for a fix.
Dec 03, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
