Question about Waring Blenders
I have a Waring blender R600 GBS, Model WS 104. The base has stopped working. The switch seems to have the normal tension. Have there been problems with this model just quitting after about 7 years
See above under question
ThaMp3Doctor
  • 8596 Answers
SOURCE: I have a Waring Pro Speciality Blender. After only
If you don't see a physical crack or stress line on the jar, the issue could be either the gasket or blade assembly - Waring doesn't list any parts for sale for this model, but you may be able to call them and get these parts. There are not very many reviews on this particular Waring, so I am working with very limited information (and this is just my opinion), but the few that I have seen suggest that this might be the worst blender Waring ever made (in general, though, their blenders are usually top-notch).
Consumer Guide generally rates it high, but issues this:
"Cons: Strong churning motion requires you to hold the lid in place to prevent leakage through the top and limits the ingredients capacity, especially for hot mixtures"
The sites that invite the most user input into the rating generally give it a 2-star rating.
Waring seems to have escaped somewhat from their usual blender shape - and I have even heard that the shaft is made out of rubber, which is frightening.
Posted on Apr 01, 2009
darjr
  • 378 Answers
SOURCE: burning smell when used
No need to oil it. The carbon brush maybe sparking already it is located inside the motor. It is due to damaged Armature or overloaded motor.
Posted on Jun 01, 2009
tbreeze47
  • 3083 Answers
SOURCE: Regarding the Viking Professional Blender
Here's some reviews on Amazon.com, and about halfway down the page there's a blog on stainless replacement blades. Alot of people had trouble with the plastic blades breaking, and it sounds like yours are jammed, or kind of cemented. Try soaking it in hot water (hold it upside down), to try and loosen the binding.
There's a lot of complaints about this item, and most wouldn't recommend it with the problems they've had.
Anyway, good luck, thanks for using FixYa, and hope this helps.
Posted on Sep 04, 2010
SOURCE: How do you get the blender coupling driver off the
how do you change the coupler on a waring extreme blender
Posted on Apr 08, 2011
SOURCE: Waring Pro Blender is leaking and blade assembly is loose
I know this is an old, old post, but I could not find a solution anywhere, so hopefully this will help someone. We have a model 51BL25, similar to scottman55's blender, and it had the same problem. There are two separate nuts in the blade assembly. One holds the blade on, and the other holds the seal tight. When the latter gets loose, the blender shakes and leaks.
To fix it, first you have to remove the top nut holding the blade on. I had to get in there with pliers, but a ratchet with an extension would be perfect. This nut is right-handed ("normal"). Once that nut is loose, you can remove the nut and the blade. You will also want to remove the washer immediately under the blade (take note of which side goes up).
Now, you can pull the whole axle out by the wheel on bottom of the blender. This exposes a really thin, flat nut. In my case, this nut had come completely off, so nothing was really holding the seal together at all. Again, make sure you remember which direction the nut goes -- it is not quite symmetrical. That nut is what comes loose when the blender starts leaking. By the way, it is a left-handed nut, so it screws on counter-clockwise ("backwards"). Screw it in tight, then put the rest of the blade assembly back together, and your done. If you have the right tools, it should take only maybe 5 minutes.
Depending on your problem/model, this may or may not solve your problem. Hope it helps!
Posted on Sep 09, 2011
Waring blender switch wiring
most blenders throttle the power by using different taps inside the motor winding themselfs ., the switch just selects what tap to use and applies power to that winding , just three windings can produce multi speeds if used in combinations sorry no easy fix for switchs other than to make sure theres no food down inside them , i use a good electrical contact spray (CRC) down in them to make sure
May 01, 2014 | Waring Blenders
Immersion blender won't start
I think you need a new one you burn up the motor.
Jan 07, 2013 | Waring Pro SB10 Professional Immersion...
Hi, i am a culinary arts teacher. we bought the waring BB160 and used it for the first time today to make milkshakes. the canaster does not fit snuggly on the base. it can be shifted to the left or to...
I am not sure what you mean by "can be shifted" but the model does not have a locking mechanism to the base so the jar assembly can be easily removed once the mixture is done. As long as one does not take the jar assembly off while the machine is running (which could ruin the coupling and blade) you should be ok.
Nov 02, 2010 | Waring BB150S Work Top Blender
The gear at the base of my waring bb 180s blender is stripped
You can try the sears online parts store for help they may be able to get the parts you need as they are pretty much the same. iF YOUdon't find it let me know and I will resurch it for you and find the part it is eather the druve nut has come loose or the teeth on the plastic shaft has worn off, it is possible to super glue it to hold if you cant find the part.
Nov 12, 2009 | Waring BB180 Work Top Blender
Waring P320CX blender parts required
Hi - there is a website called nisbets.co.uk that has all the spare parts for this Waring blender, plus a great diagram which is much better than anything in the blender instructions.
Jun 05, 2009 | Waring MX1000R Blender
I have a Waring Pro Speciality Blender. After only a few times in use, the jar began leaking and I noticed glass shards around the outer rim of the jar. The blades are fixed on this model. I wrote to the...
Mar 31, 2009 | Waring RB75 Specialty Blender Stainless...
Waring blender BB180
try to soak hot water around the base unplug firts and pour hot water slowly at the base
Dec 28, 2007 | Waring BB180 Work Top Blender
Stopped blending
Exact same problem.  Turned out the threaded shaft that holds the blades was broken so tightening the nut on the top doesn't really help.  Just ordered a new blade assembly from www.smallappliance.com.  Mine was the Waring 007314W Blender Cutting Assembly but there is also an older one for earlier models.  Don't know if it will work yet (assume it will), but cheaper than buying a new blender.
May 17, 2007 | Waring PBB 25 Professional Work Top...
Replace clutch assembly Waring BB150 Blender
Remove the little rubber feed on the bottom of the base (they might be glued a bit so be careful not to rip them). This will reveal 4 phillips head screws...remove them...this will open the base and reveal the back site of the rotor. In the middle you will see a turban blade like wheel with a large flat tip screw. Wedge a large screwdriver between the teeth of the old clutch so that when you turn the flat tip screw it will stop rotating the other end. Turn the screw with some force to the right to losen the clutch...then do the reverse to get the new one on tight...put everything back together and there you have it.
Keep in mind that this might void your warrenty if you still have some on it.
Apr 13, 2007 | Waring BB150 Work Top Blender
Blenders Logo
119 people viewed this question
Top Waring Blenders Experts
karen renee may
Level 1 Expert
eyecam
Are you a Waring Blender Expert? Answer questions, earn points and help others
