Question about Radio Communications
Bluetooth E1282T pin code - Radio Communications
Usb dongle is not working
Step 1:
A Bluetooth dongle is an external Bluetooth device used to enable your PC's Bluetooth connection. Many Bluetooth dongles come without installation disks since the software is pre-programmed into the actual USB stick. These Bluetooth dongles are very useful on netbooks that don't have Bluetooth connection, since netbooks have no CD-Rom drives. Turn on your PC. Insert the USB Bluetooth dongle into the USB port on your desktop tower, or the USB ports located on the perimeter of your laptop. Wait for the program to auto run. Once you connect your dongle, the driver program should launch. Follow the onscreen prompts to install the dongle. A dialogue box should open that says "Installing Drivers" from the taskbar. Allow the driver to install completely before closing the box. Unplug the dongle and restart your PC. Once the PC has been switched on, insert the dongle. Double-click "My Bluetooth Places." This is the Bluetooth icon located in your taskbar, and it should launch the "Initial Bluetooth Configuration Wizard." Click "Next" on the first screen. Next, type in the name of your computer and select your computer type from the drop-down menu, then click "Next." Click "Skip" on the onscreen prompts, then finish. Pairing the Devices Turn on your external Bluetooth device. Double-click "My Bluetooth Places." Select "Find Bluetooth Devices." The name your Bluetooth device should display in the next window. Right click the icon for your Bluetooth device, and scroll down to "Pair Device." Enter the Bluetooth pin code for your external device in the "Bluetooth Pin Code Request" pop-up window. Then click "OK." The default pin code is normally "0000" or "12345." You can find your pin code in your user manual. If you are pairing a cell phone to your PC, you will have to enter the same pin code on your cell phone to establish the Bluetooth connection.
Apr 10, 2013 | Computers & Internet
Tip
PIN Codes for most Bluetooth Headsets
Most Bluetooth headsets have a factory set PIN (Pairing) code of 0000 (four zeros). Other pin codes to try are 1234, 1111, 9999.
This applies to most mono and stereo headsets and many other Bluetooth devices. Devices that have a changable pin code may differ.
If none of the code work for your device please see the user manual or contact the product manufacturer.
For a manual replacement, refer to:
http://www.fixya.com/support/r4964670-get_manual_most_any_electronic_device
on Jun 02, 2010 | Radio Communications
Need pin code for bluetooth headset nokia 2330c-2.
Regarding your pin code for bluetooth You can provide yourself. suppose if you provide 0(zero) than the other hand-set or phone that you want to send or receipt from other should be provided the same code that you provide 0 (zero) on the other hand-set or phone then it'll be helpful to you to send r receipt.
Thanks for using FixYa
Good Luck
Aug 29, 2011 | Nokia Cell Phones
I am trying to use my iphone 4's Internet Tethering capability to connect my desk top to the Internet through bluetooth. To accomplish this, I am using a USB, HAMA, Class 2 device. I go through the...
Ive got exactly the same problem with my IPhone 3GS and it's driving me crazzzzzzzyyyy....these developers should be shot. It doesn't need to be this hard. Just some common sense universal terminology would be great for start...
Oct 13, 2010 | Apple iPhone (16 GB) Smartphone
I have a nokia 3330 pay and go phone it won't allow me to turn on bluetooth what do i do?
Jul 07, 2010 | Nokia 3300
Pioneer Bluetooth
The Z2 default code is 1111
Oct 23, 2007 | Pioneer AVIC-Z2 Car DVD Player
Radio Communications Logo
48 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
