FixYa.com
Tags:
Motherboards
Generic problem for all Motherboards
Computer cut -off went running
posted by pcgrace on Nov 11, 2007
I start the computer, hear one beep (which is good), then runs for about 30 seconds and shut-down. Retarted the computer around 10 times or more still does the same thing, over, and over, and over again....
I check the nvidia video card on another computer (ok), hard drive (ok), sound card(ok).
Could it be the power supply, or the CPU, or the motherboard?
Could anyone help me, going on 3 days, and I can't figure out!!!!
Thanks
Comment by pcgrace, posted on Nov 11, 2007
Yes. By the way the motherboard is a MS-7058 using Pentium 4 800MHz processor, WD 250 GB, 1GB DDR1.
Comment by pcgrace, posted on Nov 12, 2007
will try the power supply tomorrow, have to do homework, now thanks for all your help.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
Thanks for Trying (70)
mellomania
Rank:Wiz Wiz
Rating: 82%, 127 votes
there is a jumper near the board cmos battery try to clear cmos by changing the jumper to the other position for some seconds (while power is off) so smos is clear. start the pc hit delete to enter setup then load system defaults , exit saving changes.
Rating Locked! (?) pcgrace has rated this solution as Thanks for Trying
Solution #2
Pookeybrain
Rank:Wiz Wiz
Rating: 82%, 71 votes
Does it do this when just the hard drive is disconnected?
Comment by Pookeybrain, posted on Nov 11, 2007
Based on what you've said, it sounds like a power supply problem. You can buy a power supply tester for $10 - $15 U.S. if you don't know someone who has one.
Solution #3
posted on Sep 02, 2008
Not Rated (0)
babu603
Rank:Apprentice Apprentice
Rating: 100%, 3 votes
I find a very good site for Intel Motherboard Solution.Try the site clickhere.
Please Rate me if this information helpful for u.
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To: Acer AOpen AX4BS-V (91.89J11.001) Motherboard AOpen AX4SG-UN Motherboard Apple (661-2795) for iMac Motherboard ASUS P4BP-MX P4 Prescott/845GV/FSB 533/V/A/LAN (MOTAS26) Motherboard ASUS K8S-MX Motherboard ASUS P5B Deluxe/WiFi-AP LGA775 Core 2 Duo/ P965/ A (MB-P5BDLX) Motherboard ASUS A8V-VM Motherboard
Can you Help with these Motherboards problems?
Toshiba (K000002020) Motherboard
Toshiba problems
My toshiba satellite A75-S211 ... Answer This...
EliteGroup GeForce 6100SM-M Motherboard
nvidia nforcennetwork bus...
I am reformatting my PC. During... Answer This...
EliteGroup K7SEM Motherboard
Sound
I formatted my computer but i... Answer This...
Motherboards
system failure
I was recently watching... Answer This...
EliteGroup ECS A780GM-A Motherboard - AMD...
setting multi processors AMD...
setting multi processors AMD... Answer This...
Repair Service
Find Motherboard Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
