I am getting a F4 error code on my Amcoriare mini split. Is not blowing hot air.
The inside unit displays a F4 code. I have two inside units on this system. The other unit is working fine.
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 102 Answers
Gas valve inlet to that unit may be stuck or no volts
Posted on Nov 26, 2014
joshuaramsey
  • 6 Answers
SOURCE: uotside unit blowing cool air but hot on the inside
It sounds like you have a unit called a heat pump. When a heat pump unit is in cooling mode the outside unit blows hot air and the inside unit blows cold air. If the outside unit is blowing cold then the indoor unit is most likely blowing room temperature or warm air. It sounds like the thermostat could be controlling incorrectly or you could have a failed reversing valve which is the device that switches the unit from heating to cooling mode.
Posted on Jun 02, 2009
SOURCE: E4 error code on AUX mini-spit a/c unit
E9 Showing on my split unit a/c
Posted on Mar 19, 2010
SOURCE: LG Ductless Mini Split System LAN125hv: Heat pump doesn't run.
CA: Compressor Discharge Sensor Fault
Contact a qualified service technician and have them replace this sensor.
Posted on May 04, 2010
guru_fixya
  • 944 Answers
SOURCE: The Wall unit to my
hi,
If the unit displays Error E4
1)Check whether the winding resistance and
operation current of the compressor are normal.
2)Check whether the high and low pressure is normal
when the unit is running.
3)Check (whether the coil pipe sensor is normal)
whether the contact of the inserted on the circuit
board is well, the coil pipe temperature sensor is
fixed, the evaporation of the indoor unit is well,
the key is to check the evaporator temperature
detected by the coil pipe temperature sensor has
reached the cooling or heating temperature.
4)Check whether the surface of the condenser is too
dirty, it should be cleaned when it is too dirty.
5)Check whether the capacitance of the outdoor motor
and the fan is damaged, it should be replaced when
it is damaged.
6)If the above items are normal, the electric control
board should be replaced.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Jan 11, 2011
SOURCE: Air Conditioner Error code?
Error "FL" is coming It is not going by applying suggesstion in your booklet kindly enlighten
Posted on May 16, 2011
What does E2 code indicates on a Winchester brand ductless air conditioner?
Try turning the power off for 15 minutes.
Tech Tips: How to Resolve E1 and E2 Error Codes - YouTube
? 1:48
https://www.youtube.com/watch?v=COIxQBT-J2k
Oct 14, 2015 - Uploaded by MitsubishiHVAC
In this Tech Tips video, Jeff explains the E1 and E2 error codes, possible causes and some ways to resolve ...Missing: winchester ‎brand
Error Codes - Room Air Conditioner - LG
www.lg.com > Home > Support > Product Help > Help Library May 19, 2017 - An error code on the display of the room air conditioner can usually be ... P2 or FL; CH34; E1 or CH02; E2 or CH01; E3 or CH03; E4; E5; F1,F2, ...
Pioneer Air Conditioner AC Mini Split ERROR CODES And ...
https://removeandreplace.com/.../pioneer-air-conditioner-mini-split-error-codes-and-tr... Jun 19, 2017 - Pioneer AC Ductless Wall Mount Mini Split Indoor Unit Error Code = E2 What Does The AC Error Code Mean? = Zero-crossing signal detection ...
QSHX-242 24000 BTU Mini Split Air Conditioners With Multi-Fold ...
https://www.pinterest.com/pin/542894930052841690/
Panasonic S22NKU-1 Cooling Only Wall Mounted Ductless Mini Split ..... Room temperature, set point temperature and status codes are all indicated on the ... The Goodman brand is well known for affordable pricing covered by some of the ..... Winchester Air Conditioner Quick Connect System 4rac36q-30 - 36000 Btu 13 ...
Sep 27, 2017 | Heating & Cooling
When the indoor unit is on F4 fault error code display.please help to solve the problem.
f4 mean Air Conditioners Questions & Answers - Fixya
www.fixya.com > Forum > Tags > f4 mean
My gree split type ac error F4 what is problem Name of malfunction = Outdoor tube sensor open or short circuit Display of double eight code = F4 this means
Oct 29, 2015 | Heating & Cooling
F1 08 f2 08 f3 08 f4 08 error codes vulcan comfort control what does it mean
What sort of machine is it? Refrigerated, Ducted, Gas? To do a full reset correctly, you must switch off at the main isolator next to the unit or at the meter box and leave it off for at least 15 minutes. A quick on / off does not reset it properly. If the unit is a refrigerated split system , and the outdoor is running but the machine is not blowing cold outside and hot inside (On heating mode) It could be due to a gas leak / shortage.
May 26, 2015 | Heating & Cooling
What wrong my comfortstar mini **** outside unit not coming on and I am getting e1 error code
I am somehow listed as someone who "solved" a Comfortstar mini problem - but I have not. And the company that installed it cannot. I am really fed up with the stupid thing.
Jun 17, 2014 | Ingram's Water and Air ComfortStar Mini...
The unit after running for ten minutes blows hot air inside the house
Service your unit completely and then check the following. 1. Thermostat setting must be minimum +3 degree from your temp. 2. Check room temp sensor 3. Check your out door unit fan motor. (If the outdoor fan runs with less rpm the compressor will get cut off by overload protector)
Dec 13, 2010 | LG LS-L1210CL Mini Split Air Conditioner
WE have Amcoraire Mini split unit heat pumps. One is
P 4 code means problem with the outdoor unit, Most likely low on refrigerant. Check all copper pipe connections for leaks first, then add refrigerant after checking pressures.
Jan 17, 2010 | AmcorAire UCHW-H12AF2 Split System Air...
May 07, 2009 | Heating & Cooling
E4 in an innovair a/c
Check the Capacitor.
Jan 12, 2009 | Heating & Cooling
Heating & Cooling Logo
194 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
