Question about Whirlpool WMH1163XVS Microwave Oven
Whirlpool Microwave has an indicator on the display that says "MAX", when this is lit, the number pad doesn't work.
The "MAX" light comes on on the display, when it is on, the number buttons don't work, but some of the function buttons do. I can start the microwave using the "30 Sec" button, but beyond that, I can't start the microwave. IT also appead that after awhile, what ever the problem is resolves it self, "MAX" goes off and everything starts working again as normal. Any idea what causes this or how to over ride it when it happens?
  • 32 Answers
Clean ribbon cable contacts on control board
Posted on Dec 17, 2014
techman
  • 3130 Answers
SOURCE: Stuck Microwave door
The button assembly or the arm thats attached to the push button is broken. With the unit unplugged. Carfully take off the screws from the sides and around the back of the unit around the outside of the cover. Now once apart, DO NOT TOUCH any electrical parts. Look at the mechanism and see if you can see why the buttons not activating an arm to trigger the door latch. If you think you see why, Go to http://www.repairclinic.com and enter your model #.. Answer the questions and then a bunch of parts will come up. If they dont then get the tele # from there and call them. Depending on how old the oven is, you may want to consider a newer oven??. Good luck
Posted on Jul 30, 2006
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave won't work
F6 usually means a fault in the controller or keypad. You could try to unplug it for several minutes, then plug it back in. If it still fails, maybe you or a friend can disconnect the power cord, unplug the keypad strip internally, then plug the power cord back in and try it with the keypad still disconnected. If it does not fail again, you have a wet or shorted keypad and can dry it or order one. If it does fail again, the control board is bad. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your full model number (without the suffix) here: http://tinyurl.com/gv383 Sorry I didn't get to answer this before the bogus answer was posted. I've been tied up and away from the PC.
Posted on Apr 10, 2007
Coldcut
  • 1554 Answers
SOURCE: Light won't turn off, microwave won't work
the door switch is likely stuck open.
Posted on May 12, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Whirlpool AVM 230 Microwave short circuit
If the fuse or breaker blew again, you probably have a shorted high voltage capacitor. If not, then you may have a shorted high voltage rectifier diode.
Here are some links you or someone you know can use (in order given) for test help, but read the safety warnings first:
http://www.gallawa.com/microtech/cap_test.html
http://www.gallawa.com/microtech/diode.html
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Posted on Sep 16, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: my whirlpool microwave model# MH1150XMB-0, light in microwave sta
This is usually caused by either a bad door switch, a loose door switch mount (which are pretty simple problems to fix) or occasionally a problem on the control panel.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If the switch mount is broken, it's usually more economical and safer to add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
If you only need a switch, you can order a universal type here for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases in about a week or so.
Posted on May 26, 2009
Microwave keeps shutting off after a few seconds and error number H97 shows up on display pad. What does this error mean?
Error code H97 is an indication of a possible failure of the Magnetron, DPC board or the High Voltage Inverter board. It could be just a loose wire connection also between the DPC board and the High Voltage Inverter board.
This failure will require a service technician to diagnose and repair.
Jan 24, 2015 | Panasonic Microwave Ovens
Tip
Error Code "d" - Microwave does not heat
The microwave could be in "Demo Mode" - Check your owners manual.
In Whirlpool/Kenmore models this is indicated by a lower case "d" on the right side of the display panel.
Most/All function except the magnatron (heat) work in demo mode so you can can learn to use the oven without actually cooking food
To clear "demo mode" press the "kitchen timer" pad and hold for 5 seconds until the "d" clears from the display... you may hear 2 beeps.
on Jun 16, 2009 | Kenmore 60654 Microwave Oven
MT4110RPQ-0 Built - in microwave in our Camper. (Serial FGR202317) Something happened and all of the sudden the microwave doesn't work at all. I do not know if buttons were pushed prior or not! Now...
Cdfacc, we're sorry to learn that your Microwave is not working. We'll be glad to further review your concerns. Please email your name, contact number, address, model and serial number to Whirlpool_Reviews@Whirlpool.com.
Oct 23, 2017 | Whirlpool Microwave Ovens
No power in the microwave but there is electricity at the wallplug
No power and or NO lights at all,indicate a blown fuse.
Locate and replace the fuse inside the unit.
Feb 25, 2011 | Maytag Appliances Over-the-Range Microwave...
Reads F2 doesnt work
F2 indicates a failure in the touch key pad. The part number for the keypad is 4393916 for white, 4393917 for black and 4393918 for almond color.
The part runs about $77.00. It can be replaced by removing the upper grille, then removing the one screw on top of the touch pad.
Jul 16, 2010 | Whirlpool MH7140XF Microwave Oven
Microwave Whirlpool Model: MH1150XMB The keypad numbers 1,2,3,4and 5 suddenly stopped working. any suggestions?
you'll have to buy a new control pad, or if you can solder you may take display out and see if the connections are broke to those buttons and solder them back.
Sep 16, 2009 | Whirlpool MH1150XM Convection/Microwave...
Whirlpool WMH1163XVS Microwave Oven Logo
76 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
