Question about Dryers
White knight tumble dryer model cl 37 - the drum will not spin but still makes a noise as though it wants to work? It all still makes it usually noises just drum not moving?? Any help to know what pro
Called up for quotes for an engineer.
    Top Expert:
  • Dryers Master
  • 21,522 Answers
Check the drive belt.
Posted on Nov 21, 2014
barkencoa
  • 3463 Answers
SOURCE: tumble dryer makes whine noise but doesnt spin
Sounds like the drive belt has gone,and the noise you can hear is the motor going round.
The red glow you can see, will be the heater element glowing..
To check the belt, remove top cover, and you will be able to see if the belt is on or not, if you can see it round the drum, try to lift it up, if it has not broken,then you will not be able to remove it, and that means the motor or drum could be siezed, try to turn the drum by hand, it should be fairly stiff to turn, but not that stiff that you cannot turn it at all.
Please rate my fixya solution.
Thanks.
Posted on Feb 01, 2009
SOURCE: White knight tumble dryer making
I have this banging problem, it sounds like a plastic ball rolling about inside it
Posted on Dec 02, 2009
SOURCE: White Knight tumble dryer making a clicking noise
red reset button does not click have used this button before and it solved the problem button does not push in anymore
Posted on Aug 02, 2010
richroth
  • 9472 Answers
SOURCE: what is the best way to put a new drum belt onto
Here is a link to a video that will help you with this repair.
http://www.youtube.com/watch?v=BiYFDAZVFaw&feature=channel
Posted on Nov 25, 2010
michiganfan9
  • 179 Answers
SOURCE: my white knight tumble dryer
Your belt probably broke or fell off the motor . The humming noise is the motor running without a belt on it
Posted on Jul 15, 2011
Check engine light came on, within minutes it "powered down" stalled, dies and will not start. What could cause this to happen? Did the turn key off/on to get code and "done" appeared.
Hello
When the service engine soon light a yellow light (Also called the check engine light or engine management light) is turned on this is to alert you to the fact that Powertrain Control Module (computer) has detected a failure somewhere in the systems it controls you may not feel any difference in the way the engine runs, this can be the transmission or the engine or emission system, there are fault codes set in the modules memory for these faults. What needs to happen now is to have the powertrain control module scanned with a special tool called an OBD2 electronic engine control scanner or a OBD2 code reader. Once the code(s) are read then you must perform the diagnostics for each code and make the appropriate repairs based on the findings of the diagnosis that was performed, this is called doing "Pinpoint" testing.
Nov 30, 2012 | 2008 Chrysler Pt Cruiser
Broken water pump bypass hose for a 2002 buick park ave
You will have to remove the belt, altenator and the tensioner bracket. The piece of plastic will be in its bore I've never had one fall in the engine.
Oct 12, 2012 | 2002 Buick Park Avenue
1999 mazda 626 es v6 not starting
First, I suggest scanned the computer car in order to know what fault code is stored there; note this code number and send it us for additional details.
Aug 07, 2012 | 1999 Mazda 626
2002 530i "OIL" microfilter - DOES THIS PART EXIST?
THe microfilter is just the filter. The oil filter is available off the shelf at advance auto parts. It's the original equipment German brand, "Mann". It's about $12.00. The price of $300 you were quoted is more the range for a transmission oil change, not engine oil.
Don't be confused about the word"microfilter". Again, it just means the filter, same as any other car.
Mar 16, 2017 | 2002 BMW 5 Series
1998 ford explorer, 4.0L SOHC. shows no error codes but engine will only rev to about 3000 rpm if given a good amount of throttle. If I back off the throttle, or "feather" it, engine will rev all...
A fault like that should trigger some codes. It also depends on the kind of tool used. Y not try a different scan tool if u used a smaller one earlier. U could try the tool called Launch box. Ur check engine light showed be on by now, if not then someone might have tampered with it. Might even be your TPS (throttle position sensor) acting up. No guesses at this point. Try to get some codes.
Jul 20, 2011 | 1998 Ford Explorer
There is a "collar" of some kind between the oil
its called oil filter adapter it has 2 bolts & some takes gasket or o-ring
Dec 26, 2010 | 1996 Honda Odyssey
ENGINE VIBRATION
take to the aircon shop for a quote...they will test and quote....
Mar 25, 2017 | 2000 Honda Accord
Dryers Logo
147 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
