Question about Bernina Sewing Machines
While sewing with my Bernina 1030 the machine suddenly stopped. The wheel is very difficult to turn by hand now. I took the bobbin out and cleaned. Now machine still gets stuck after a few stitches. C
Cleaning and oiling hook area
    Top Expert:
  • Bernina Master
  • 22,127 Answers
Check and set the timing.
Posted on Nov 21, 2014
SOURCE: Janome Memory Craft 9500 Troubleshooting
The solution that I found last night was the thread tension. I have never touched the dial, only had it set on 'auto." When I started playing with it, I realized the top thread should be really easy to pull through the machine and it wasn't. I started turning the dial (to 3 or 4) and the thread slid through the machine perfectly. No more birds nest! I really thought it was bobbin initially because of the horrible sound it was making.
Posted on Jun 05, 2008
  • 6 Answers
SOURCE: Bernina 440 stops stitching
see your local dealer and tell them you have a bad power board. or l-print. this is a known issue and bernina is covering it under there 5 year warranty. the 5 volt output is faulty on some some models
Posted on Apr 11, 2009
SOURCE: Bernina 180 Artista sewing machine
you may have to replace the upper thread sensor
Posted on May 22, 2009
SOURCE: Hand wheel hard to turn, won't sew
Machine wheel locked,what should I do?
Posted on May 18, 2010
SOURCE: I have a Necchi 537FA sewing machine. It sill sew
have you checked to see if the needle is bent-lay the needle on a flat surface & roll the needle over,, if the needle does not roll good -replace
blunt needle-if the needle makes a popping sound when the needle penetrates the fabric,,the needle is blunt-replace
sometimes if the thread comes off the thread take-up lever it can jam the thread in the bobbin area
try rethreading the machine
check to make sure the thread isn't wrapping around the spool pin
check the spool of thread to see if the notch on the spool is catching the top thread
check to see if there's a burr on the bobbin case
I hope one of these suggestions helps you
please rate this using the thumbs in upper right hand corner
Posted on Aug 12, 2010
The handwheel will turn manually but it will not move using the foot pedal. The sound it makes when I press on the foot pedal *sounds* like I am filling the bobbin.
foot pedal not moving needle - Home Forums - GardenWeb
ths.gardenweb.com > Home Forums > Sewing
Nov 8, 2013 - We have a Brother Limited Edition Project Runway Sewing MachineRefurbished LS2250PRW. I was trying to sew on a button and was turning the hand wheel to do ... front near the needle where you can run the machine with foot pedal ...just what I would experience when my Bernina was running, or not, ...
Sewing Machine Repair ' ThriftyFun
www.thriftyfun.com/tf/Home.../Machines/Sewing_Machines/index.html
The thread is being picked up from underneath, but will not form a stitch at all. ... Butwhen I push my pedal down my needle won't move, the motor runs, but nothing happens. ... I have a Bernina machine which is sewing OK with the normal foot. ....The hand wheel, the wheel at the end that manually turns to make the needle ...
Help me diagnose and fix a problem with my sewing machine - Sewing ...
artisanssquare.com > ... > Sewing Machines
Jan 11, 2016 | Bernina Sewing Machines
Why bernina electronic wheel won't turn and motor bogs down
You don't mention which model Bernina you have. If it is a Bernina mechanical, ie 930 Record, it sounds like it hasn't been cleaned or oiled in a while and the oil has hardened making it difficult for the motor to move the parts. Pick up some Bernina oil for "mechanical" machines, or for a quick fix a bottle of Tri-Flow Synthetic Oil at the hardware store. Following the diagram in your manual, put one or two drops of oil every place indicated (be sure to oil both the top of your machine and the area below the sewing surface). In your case, pay particular attention to the oil holes located nearest the handwheel. That is probably where the problem is worst. To help loosen things up, you can direct heat from a hand-held hair dryer into the interior of the machine. In the future, be sure to keep your machine cleaned and oiled on a regular basis. My policy is every time I change bobbins, after 8 hours of continuous sewing, or every six months if the machine has not been in use.
Mar 10, 2015 | Bernina Sewing Machines
My bernina 1030 is not feeding the fabric, it is sewing in one place
Make sure your feed dogs are not set for free motion or darning. Once you switch them to regular sewing you will need to turn your hand wheel 1 rotation for them to come up. Also make sure that your stitch length is not set at 0.
Jan 07, 2015 | Bernina Sewing Machines
Bernina 1010 hand wheel problem.
If your hand wheel would have a lock cam/washer probably you have fixed it upside down.
Dec 24, 2013 | Bernina Sewing Machines
Bernina 830 Record foot pedal won't engage sewing unless I turn the hand wheel.
your motor is going out. time to replace or rebuild your motor. both are high skill and should be attempted by a professional. take it to your nearest bernina shop.
Feb 07, 2013 | Bernina Sewing Machines
How can I take the back of my bernina 1030?
Bernina 1030 Service Manual Page 5
If you click the tiny page pictures on this page they expand. Page 5 discusses taking off the back.
Jun 17, 2017 | Bernina Sewing Machines
Hand wheel will not release on my bernina sewing machine what should I do?
If handwheel is difficult to turn manually, it most likely needs cleaning and oiling.
Oct 11, 2012 | Bernina Sewing Machines
When cleaning my Bernina 1030, I took the plate out and cleaned the inside bobbin area, now the feed dogs will not come back up. any ideas?
How about turning your handwheel at least 2 complete revolutions towards you? It works on Singers, maybe you can be lucky and have it work for you. Good luck
Jan 02, 2011 | Bernina Sewing Machines
Bobbin spindle won't spin
Check the bobbin winder rubber, it may be worn or broken and insufficient friction against handwheel to turn.........or a thread jam around spindle is stopping the spin. In this case, carefully unwind, DO NOT cut thread.
Sep 01, 2009 | Necchi 3537 Mechanical Sewing Machine
Just bought my used Bernina 1010;it was sold to me
Heat the wheel with a hair dryer to loosen. If this does not help, you will need to visit an authorized Bernina dealer.
Jul 21, 2009 | Bernina Sewing Machines
Sewing Machines Logo
160 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Derek Massey
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
