Question about Panasonic Electronics - Others
After a few minutes ity shows timer and no blowing
Timer not working it blows a breaker when turned on
Describe timer in detail so it can be identified:
http://waterheatertimer.org/How-to-troubleshoot-timers.html
I don't know a timer with error codes... and if breaker blows then timer is wired wrong, or load is too heavy for load rating of timer, or using wrong voltage.
Gene
h
Dec 04, 2013 | Hardware & Accessories
I am wanting to energize a relay for 3 min. then off, whether the power stay's on to coil or not! what I want to do is when a door rises and hits a switch I want to energize a coil for 3 min. whether...
You want 3 minute 'off delay' timer.
When timer is energized with push button or momentary electrical signal, circuit remains ON for set amount of time, and then turns OFF.
http://waterheatertimer.org/How-to-wire-Dayton-Off-Delay-Timer.html
Aug 15, 2011 Dayton/ Grainger website is offline
Most delay timers have 1 amp capacity rating, so circuit needs fast acting 1 amp fuse, and timer controls separate relay or contactor unless Load is equal to 100 watt light bulb.
3-minute off delay pin timer
Omron shows 120Volt 8-pin M-series-(minute) 3 minute delay timer
Part number H3CR-H8L 120volt M
http://waterheatertimer.org/pdf/Omron-timers.pdf
Example 240Volt timer showing timer and base.
http://www.sourcingmap.com/ah33-220v-030-minutes-delay-timer-relay-socket-p-119441.html
Wiring diagram shows on side of timer.
Aug 15, 2011 | Amperite Dayton Solid State Timer On Delay...
We have the Noma Exterior Mechanical No instructions. Shows on and off/dusk and then the hours. Do you turn to dusk and then the hours how do you set it to come at dusk then turn off 6 hours later?
Identify timer on following page:
http://waterheatertimer.org/Woods-timers-and-manuals.html
Page shows instructions and troubleshooting.
That being said, if your timer has a dial with 2 4 6 8, then following instructions probably apply:
Timer turns on automatically at dusk,
Rotate dial to select when timer will turn off.
In your case, rotate dial to 6, and then timer will turn off 6 hours later.
Make sure to keep timer turned away from lights, or where car lights might reach photo-eye located on front of timer.
If timer is exposed to light, it will turn OFF, and then blink back ON few minutes later.
When timer turns ON again, the 6 hour countdown starts over.
Dec 22, 2010 | Garden
How do I program the timer to turn on and off at specified times?
You need to program the timer so it turns on-off at specified times.
But first we need to identify your timer for sure.
Have a look at link below.
http://waterheatertimer.org/Woods-timers-and-manuals.html#59203
If your timer does not show, then add a comment with description of timer.
I have extensive files on timers.
Intermatic DT300, GE 15091, and Woods 59203 are the same timer.
Here are instructions for Woods 59203:
Plug timer in until battery is recharged.
If display will not show, then timer battery needs to be plugged into outlet for 1 hour until internal battery is recharged, or timer is bad, or electric circuit is tripped off, or electric circuit heeds to be tested with circuit analyzer.
Once display shows, then unplug timer for programming.
Set current time:
Press and hold CLOCK button.
Press HOUR and MINUTE to set correct time with am and pm.
Press Day button to set current day.
Release clock button.
Program timer:
Press PROGRAM button until "1 ON" displays. This is program1 ON.
Press MINUTE and HOUR buttons to set ON time for program1
Press DAY button to choose day or group of days for program1 ON
Press PROGRAM button until "1 OFF" displays. This is program1 OFF
Press MINUTE and HOUR buttons to set OFF time for program1
Press DAY button to choose day or group of days for program1 OFF
Press PROGRAM button until "2 ON" displays. This is program2 ON.
Repeat steps above to set ON and OFF time for 5 programs.
When programming is completed, press CLOCK button to exit programming.
Press ON/AUTO/OFF button until Auto displays.
Make sure lamp is turned on.
Make sure bulb is good.
If instructions don't fit your timer, then add a comment with model number or full description and I'll post those instructions.
Also you can take advantage of Fixya phone service where expert speaks with you over the phone for a price.
Dec 21, 2010 | RTO Intermatic DT300CL 8.3 Amp Seven Day...
I have a IIIWoods timer #59203WV and have trouble programming it to turn on and off exterior lights. Thanks for your response.
Manual:
http://waterheatertimer.org/pdf/Woods-59203.pdf
59203 plug-in timer: your outdoor lights have to plug into side of timer.
If you want a timer to replace outdoor light switch: buy in-wall timer Aube T1032 or Lowes sells Utilitec 0192773.
http://waterheatertimer.org/Programmable.html#Aube
Add a comment for more help with in-wall.
Here are instructions for 59203 plug-in timer:
Plug in the timer until battery is charged.
Unplug timer so you can program easily.
Press R reset button with paper clip to clear.
Set the time of day:
Press and hold clock button
Press hour button until current hour shows
Press minute button until current minute shows
Press day button until current day shows.
Program review:
Write out ON-off schedule showing hours minutes and days
For example: timer turns ON 6:00 pm all days of week.
Timer turns OFF 1:00 am all days of week.
First step: Set program1 ON > hour, minute, and day.
Next step: Set program1 OFF > hour, minute, and day
If needed, go to next step: Set program2 ON > hour, minute, and day
Next: Set program2 OFF > hour, minute, and day
How to program timer for ON at 6:00 pm and OFF at 1:00 am all days of week:
Step 1: Press PROGRAM button until display shows 1 ON (this is program1 ON)
Press hour button until 6 pm shows
Press minute button until :00 shows
Press day button until all days of week show (MO TU WE TH FR SA SU)
Step 2: Press PROGRAM button until display shows 1 OFF (this is program1 OFF)
Press hour button until 1 am shows
If you want to set another program, you will repeat same steps for program2
Press PROGRAM button until display shows 2 ON
If you are done programming, press clock button
Press ON/AUTO/OFF button until AUTO displays
Nov 13, 2010 | Woods INDUSTRIES 83660 OUTDOOR SECURITY...
Hangs up on timer number "19", sometimes shows
Inlet error. Took longer than 10 minutes to fill OR the central computer control thinks it took longer.
themobilian_35.jpgTake the top off and hunt down the small rubber tube from control to tub, blow out the sediment. Do the water level test as shown in the manual and more here
Nov 03, 2010 | LG WM1815CS Front Load Washer
VCR not timer recording, VCR will not turn on with timer
If no menu, unplug, and let it set a few minutes. Replug and the on-screen menu should appear. Reset the set-up (date, etc). I had the same experience as one of the other posters with JVC customer service telling me the menu button on the remote was malfunctioning, and I should purchase a new remote from them.
After you input your programming, be sure to hit the Timer button on your remote. If you want to change tapes or playback, you will need to hit the Timer button again (take it off Timer) for access to your VCR. Be sure to reset it to Timer afterwards, or you will not be able to record.
Feb 17, 2009 | JVC HR-A592U S-VHS VCR
Air conditioner not working
unplug it for few minutes and then restart it. This shold reset the timer.
Jul 07, 2008 | Fujitsu Heating & Cooling
Toshiba 32wd98b
Hi
Problem is probably PSU REGULATOR, STRF6668B.
I wouldnt recomend you repairing this yourself as there may be other components that will require checking.
You could end up blowing the replacement regulator.
http://dysonmanuals.llc.nu/
Apr 12, 2008 | Televison & Video
MDB7100AWB STOPS AFTER 3 SECONDS OF RUNNING
1. The Maytag sevice centers, if close, are "great". You describe the problem and they supply the part. If far still give them a call.
2. The problem is probably the control. It's a simple fix. Just replace the part. And you can order the part from the service center. Takes 10 minutes.
Tango
Feb 09, 2008 | Maytag MDB7100AWB Dishwasher
Electronics - Others Logo
47 people viewed this question
Top Panasonic Electronics - Others Experts
 Grubhead
Grubhead
Rod
Rod
Tom Chichester
Are you a Panasonic Electronics - Other Expert? Answer questions, earn points and help others
